Question about Creda W120VW Front Load Washer
Creda machine won't agitate with clothes in it
This is a very simple creda machine, about 17 years old. It has a problem that is driving me crazy. Essentially, it won't agitate the clothes. It will fill with water (but only about 1/5 or 1/4 of the drum fills), and will spin properly at the end of the wash cycle, with or without clothes in it. IF there are NO CLOTHES but only water, it agitates correctly. But if there ARE clothes, it moves back and forth just barely. There appears to be no problem with the belt. If the motor is defective, why would it spin fully at the end of the cycle, even with clothes in it? Why would it agitate with only water in it, but not clothes AND water? Thanks in advance.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 133 Answers
Your load is prob to heavy for the older washer. it just doesnt have the power to handle it no more. time to replace it, sorry.
Posted on Jul 30, 2007
SOURCE:
Washer won't agitate with clothes in. Will agitate when empty with water
It's a whirlpool top load and 17 years old.
I checked the lid switch, water level switch and they are okay. I replaced the motor coupling. The old one was chewed up and crumbling.
When I put everything back together and turned it on to check if it would spin, I heard a buzzing sound and after a few minutes there was a burning smell.
What should I check to diagnose this problem? would help to have make or model numbers to show age of machine
Nov 26, 2012 | Whirlpool Washing Machines
The fast spin cycle on my creda 1000 will only spin slowly,leaving clothes wet,any thoughts
This machine has a variable spin-speed setting. You can set the spin-speed RPM (between OFF and 1200RPM) using the smaller dial located next to the main wash programme selector dial.
I hope I'm not stating the obvious, but appliance "faults" are often simple and don't require taking the machine apart or calling a service engineer. If you've already tried the above suggestion and your washing machine is still spinning slowly, please post back and I will try to assist you further.
Regards,
BElectric
Nov 27, 2010 | Creda W100FW Front Load Washer
My creda reverseair tumberledryer won';t work. my
Hi
If you can hear the motor running and have also checked the belt tension and they are O.K., then the only thing I can think of is the Motor pulley, where the belt sits on.
Check that out and make sure it is not loose on the motor shaft, so that the motor turns but the pulley slips.
Regards
Ash
Nov 09, 2009 | Creda IWD12 Front Load Washer / Dryer
My creda iwd12 front load is not working
If the m/c completed the wash cycle, it may be that the clothes have not rinsed, or incorrect prog selected, or incorrect temp selected,
Check to see if the drum actually goes round with clothes in, as a worn or broken belt will obviously stop the clothes from being washed.
Plz rate my solution.
Thanks.
Dec 16, 2008 | Creda IWD12 Front Load Washer / Dryer
Old Creda double oven keeps runing when switch off
sounds simple but look at the knob to see if it is cracked and hence not turning the shaft
Jun 22, 2008 | Creda C362E Electric Kitchen Range
Problems with creda washing machine
try your carbon brushes and drop your sump ie the pipe that connects to the pump on the inside of the machine and goes to the bottom of the drum this is the sump that sometimes blocks or may be a weak pump but try the other 2 options first good luck dont forget to unplug
Apr 14, 2008 | Creda W120VW Front Load Washer
Bearing replacement on Creda IWD 12drum DIY or not?
no im afraid thisis not a DIY job and i charge £120 pounds to supply and fit new bearings and spider  and you should also get @ least 6mths g/tee on parts fitted         good luck
Mar 03, 2008 | Creda W100FW Front Load Washer
Creda 1000 simplicity washing machine
try
www.theservicecentre.co.uk
creda and hotpoint website
good luck and rate me
Feb 17, 2008 | Creda W100FW Front Load Washer
Operating instructions for creda storage heaters
how do you regulate the heat from creda storage heaters model No 79163 /79151 /79141 they have 2 dials on each heater,I was told the dial on the right turn up to 6 its highest point & the left dial to its lowest number 1 .But i got up this morning & its like a sauna
Jan 03, 2008 | Heating & Cooling
Creda W120VW Front Load Washer Logo
179 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
paul
paul
jimorris77
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
