Question about NetGear WGR614 Wireless Router
I had to disconnect my NetGear WGR614 Wireless Router bc it wasnt working with my cable modem and now i want to reconnect but i dont know where the instructions are? can u tell me where to find instructions?
  • 3 Answers
Did you get an install disk for your unit? Should have, if not go to the site on your wired computer and check to see if they have a printable manual for your unit.
Posted on Jan 31, 2009
My Ethernet lite will not come on on my modem, cannot get online thru this wireless router, tried reconnecting cables and power down the modem per set up instructions that came with the netgear router,...
if your modem has an ethernet connection the drivers should be on the disk provided by the internet provider
control panel admistrive tools,computer management,device manager scroll down network adapters +expand Ethernet driver right click update driver,disable,uninstall or select properties general you can trobleshoot or driver to update,rollback or uninstall
hope this helps
Nov 30, 2010 | NetGear WGR614 Wireless Router
I dont have the drivers for NETGEAR 54 Mbps wireless Router WGR614 v7. I want to connet my BroadBand connection to my Router I want to use my LAPTOP without wireless. kindly assist me about the...
Hello, I dont think you need the drivers for Router. And first of all you need to connect your modem to your router through ethernet cable. And after connecting your modem, configure your wireless router by typing this IP address in internet explorer: 192.168.1.1 The user id is admin and the password is password. Then detect your broadband connection by using the option in the router. Try connecting your Laptop to wifi after setting the connection.
Nov 02, 2010 | NetGear WGR614 54Mbps Wireless Router...
HAD UNPLUG MY PERSONAL ROUTER TO GO WIRELESS WITH THE CABLE COMPANY , NOW WAS VERY DISSATISFIED WITH THE WIRELESS AND ASKED TO JUST CHANGE TO TURBO AND I WOULD RECONNECT MY NETGEAR WGR614 WIRELESS ROUTER....
Connect Modem to WAN Port on Router
Connect Computer to LAN port
Checked Lights on Router
if the i-Lights amber Powercycle the Whole N/w
then if i-Green check Internet for Wired
then Loginto Router and Do Wirelesss Settings
Scan and Connect to Wireless N/w
Sep 29, 2010 | NetGear WGR614 Wireless Router
Hello I have a netgear wireless router WGR614 V5 which is connected to a cable modem and since several weeks I have many unexpected and random disconnection. So I must turn off my wireless router and...
HELLO,
Why are you using two routers,these might be conflicting with each other? Somtimes the drivers need updating.Try this first,and if this fails,disconnect the cable modem and just connect the wireless router to the main phone line socket via a modem filter and connecting a wireless adapter to your pc and install the driver for this adapter.The signal from the phone socket connection to the wireless router situated close to the main phone socket.Then connect the adapter to the usb port on your PC,and let the driver software and PC do the rest.That's all I've got on my PC.
Aug 07, 2010 | NetGear WGR614 Wireless Router
PS3 and Netgear WGR614 V7 Router
Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
For details on how to configure the PS3 click on the WEB link :-
wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 20, 2009 | NetGear WGR614 Wireless Router
Cannot connect to internet through the router. Working fine last week, not working now. What's up? Can you help?
Power off ur Router > disconnect all the cables>
find a button that says RESET or it can be a pinhole> press and hold on it for 30 seconds > reconnect the power and wait till all the lights come on> reconnect all the cables try connection> if still no connection>
do the same for the modem( and do check if a Wired connection is working with both the devices)
Oct 20, 2009 | NetGear WGR614 Wireless Router
Same old question, but I cannot get a connection between my Netgear wireless router WGR614 to my cable modem.I follow the set up via the router's wizard. But no luck. Even unplugged the modem for 15 mins...
Can you pls confirm if you have cable or PPPoE connection. Also, please connect the modem directly to the computer and let me know the results:
A. Click on Start—Programs—Accessories—Command Prompt.
B. In Command Prompt window, type in 'ipconfig' and hit 'Enter'. Note down the IP Address, Subnet mask & Default Gateway here.
Once I have this information, it will be quite easy to configure the router.
Oct 09, 2009 | NetGear WGR614 Router
Switched from comcast digital cable internet service to at&t dsl. got the motorola 2210 modem from at&t. am ok with just internet through the motorola modem. problem occurs when I attempt to...
Apparently the issue is caused because the motorola 2210 is also a router. To solve the problem the motorola must first be placed in "bridge" mode. Complete steps are available at: http://www.dslreports.com/faq/15855
Aug 01, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Problems with netgear wireless router
picolas and nannysboy,
You can setup your router any way you like after accessing it. You don't need software for NetGear. All you have to do to access the control panel is:
  1. Open your browser.
  2. Type in this ip address - http://192.168.1.1
  3. Configure the router as you see fit. It's fairly simple and has built in help guides.
If you cannot connect by wireless, do the above while connected by a LAN cable (looks like a telephone cable, only fatter and wider).
The router should be connected as follows:
  1. WAN port directly to cable/dsl modem.
  2. Any port (1-4) running out to your computer.
Please let me know if this helps. Good luck!
Feb 24, 2008 | NetGear WGR614 Wireless Router
Netgear 108 Mbps Router WGT624 v3
As you say that, you are able to go online with the modem, connect your modem- router and laptop witha cable and check if you are able to go online with the router wired first, if yes, then the w/ls settings has to be checked..open your w/ls network connection, remove your preferred wireless network and then try to reconnect again and check.. if you are not able to gon online wired with the router, disconnect power cables from modem- router , wait for 10 sec, and reconnect it , wait till all the lights come up and then reconnect, check if you are able to go online if not your router has to be reconfigured,,
plz check and revert back in case of any issues
Nov 27, 2007 | NetGear WGT624 Wireless Router
NetGear WGR614 Wireless Router Logo
42 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
