Question about RCA D52W19 52" Rear Projection Television
RCA D52W19 intermittently powers off - green pwr light flashes
I came across your posts while searching for a solution to my problem. The PTV is intermittent. It powers down and after I press the power button it starts the power light flashes a few times then powers down. If I unplug the TV for 30min it will come on and work. Sometimes it goes weeks, some times days before the problem comes back. It seems to be getting more frequent in the last month. I saw your post about caps CP150, CP120 and I had another google that had CP114. As of now all these caps look normal. Is there a TP where I could take a voltage measurement when the power light is flashing? or should I just replace those caps. If I hit them with freeze mist and the TV powers up would that be a good indication that the caps are going?
Thanks for insight you may have.
  • RCA Master
  • 5,138 Answers
Yes cp 114 is another one replace all 3 capacitors.
Posted on Feb 07, 2009
My RCA D52W14 wont turn on it makes a weird noise and the power light blinks as it's making the noise three times than the blink stops and noise too
Hi
Thanks for using FixYa. On the Deflection board there are 3 capacitors CP 114, 120 and 150. 3 blinks occur if any of them is puffed up on top. To resolve this issue you'll have to replace all the 3 capacitors CP150 2200UF 16, other 2 are 220UF 35v they will be green with gold writing on them. Also re solder all pins on Fly Back Transformer (FBT). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 12, 2010 | RCA D52W19 52" Rear Projection Television
I have a RCA D52W17 rear projection T.V. When I turned the power on the green light flashed 3 times then shut off and now it won't go on at all.
Hi
Thanks for using FixYa. 3 blinks in your RCA D52W17 rear projection are caused due to 3 capacitors (CP114, 120 and 150) which are located on the deflection board. If any of these capacitors goes bad you’ll have to replace them with the exact same ones. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | RCA D52W19 52" Rear Projection Television
TV will not power on. Button slowly flashes green several times
CP120, CP114 and CP150 need replacement. You can get replacements at the following link under the RCA parts catagory.
http://servicemanuals.vstore.ca/
Aug 22, 2009 | RCA D52W19 52" Rear Projection Television
Tv will not turn on
I turn on tv green light comes on and gos off and no picture.
Feb 04, 2009 | RCA D52W19 52" Rear Projection Television
RCA 52" shut off, green light flashing constantly
i think you should call a repairman in since he will be better at telling you for sure what the problem is and getting it fixed.you dont want or need alot of guesswork and even the gurus cant tell you for sure what the problem is.
Jan 08, 2009 | RCA D52W19 52" Rear Projection Television
52 inch rca big screen tv will not come on
ck capacitor cp150 if it is bad replace 2 other caps in same circuit 2200uf 16v -220uf35v cp111 cp114?
Dec 09, 2008 | RCA D52W19 52" Rear Projection Television
My Rca 52 inch D52w19
Check cp150 2200uf 16v ,if bad there is 2 more capacitor that must be replaced also 220uf 35v cp111 cp114 they are green caps with gold writing on them.
Dec 01, 2008 | RCA D52W19 52" Rear Projection Television
RCA = flyback?
I just posted a reply to you. Its most likely not the flyback causing that symptom.
Oct 05, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
136 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
