Question about Saeco Magic De Luxe Espresso Machine
Trouble light goes on when we turn machine on
There are six trouble lights on top bar, second from left goes on and we do not know what it represents
  • 3 Answers
This light tells you you need to descale the machine.  It is all explained in the instruction manual.  Once descaled you turn it off by holding down the steam button for more than 5 seconds.
Posted on Feb 19, 2009
Red light blinks six times. When I hit power button green light stays on for a few seconds, turns off the on for a few more. Then goes back to pattern of red light blinking six times.
the kill switch is open ensure the lamp cover presses firmly on the kill switch when u close the lamp chamber door the red light will stop blinking and u can now turn the tv on
Jul 06, 2013 | Televison & Video
Can't establish connection to modem or internet
contact the source provider for the modem such as your service provider or the manufacturer for a trouble shooting walk thru
Jan 15, 2018 | Arris Computers & Internet
Printer won't print. one of the lights is on, but I'm not sure what the symbol means. Cannot locate user manual.
Can you provide us information which light is on on the printer? the printer lights is represented by six light. starting from the left is error light, paper jam light, load paper light, toner light, ready light and continue button (green button). The light sequence will indicate a specific problem on the printer.
For further assistance, please contact Lexmark Technical Support.
Jan 26, 2011 | Lexmark E260dn Laser Printer
My saeco machine is not functioning in the right order, it grinds after it makes the pad. So I first hear the clicking sound (meaning it is making the pad first with old grinded coffee) and then it grinds...
HI
Read the first then go to the bold letters.
To program your Magic Dlx: Press and hold the steam and small espresso buttons at the same time, then push the energy saving button (top right). Water Hardness. The large coffee button programs the water hardness. Press the button once and you will have one light in the top row, left side. Press it again and you should have two lights lit. Press it three times and you have three lights lit. Four and you have four lights lit. Press it a fifth time and it goes back to one light. Each light represents your water hardness. So if you have a water hardness of 3, press it until you have three lights lit. Press the energy saver button to exit the program and save your hardness level in the machine’s computer. It will now tell you when you should descale your machine. Pre-infusion. Press the medium coffee button to activate and you should see the light come on. Press the button and turn the light off to deactivate the pre-infusion. Pre-grinding. Pre-grinding is turned on with the cup warming button. When it is lit, the pre-grinding is on. Press the button to turn it off.
Nov 14, 2009 | Saeco Magic De Luxe Espresso Machine
We have a 2007 Palamino Yearling Model 4101 Pop-Up Camper and recently it was vandalized and the wires from the camper to my vehicle were cut and destroyed so we have to replace the vehicle end plug to the...
Is this a six way plug (six round holes)? If there are six wires coming from the trailer, then the color code should be as follows:
White - Ground
Brown - Tail Lights
Yellow - Left Turn
Red - Stop
Green - Right Turn
Blue - Auxiliary Circuit (Battery Charge, Electric Brakes, etc...)
If you open the plug up that was cut, it is labeled as to which goes where.
TM = Tail Lights
RT = Right Turn
LT = Left Turn
S = Stop
G = Ground
Center = Auxiliary
Jun 27, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Pulling the trouble codes using a volt meter.
Self-Test with Analog Voltmeter DTCs will be represented by pulsing or sweeping movements of the voltmeter's needle across the dial face of the voltmeter (Figure 9). A single-digit number of three will be reported by three needle pulses (sweeps). However, a DTC is represented by a two-digit or three-digit number, such as 2-3. As a result, the DTC of 2-3 will appear on the voltmeter as two needle pulses (sweeps). After a two-second pause, the needle will pulse (sweep) three times.
The Continuous Memory DTCs are separated from the Key On Engine Off DTCs by a six-second delay, a single half-second sweep, and another six-second delay.
Using an Analog Volt/Ohm Meter (VOM)
  1. Turn the ignition key off.
  1. Set the VOM on a DC voltage range to read from 0 to 15 volts.
  1. Connect the VOM from the battery positive post to the Self-Test Output pin of the large Data Link Connector (DLC) (Figure 3).
  1. Connect the timing light.
17fa78e.gif Using the Malfunction Indicator Lamp (MIL) No special equipment hookup is required. STI is jumpered to SIG RTN at Self-Test Input (STI) connector and the Data Link Connector (DLC).
Self-Test with Malfunction Indicator Lamp (MIL) During Self-Test, a DTC is reported by the Malfunction Indicator Lamp (MIL). It will flash the "CHECK ENGINE" or "SERVICE ENGINE SOON" light on the dash panel (Figure 10). A single-digit number of three will be reported by three flashes.
However, a DTC is represented by a two-digit or three-digit number, such as 2-3 or three digit. As a result, the Self-Test DTC of 2-3 will appear on the MIL as two flashes, then, after a two-second pause, the MIL will flash three times.
The Continuous Memory DTCs are separated from the Key On Engine Off DTCs by a six-second delay, a single half-second flash, and another six-second delay.
Feb 23, 2009 | 1994 Ford Thunderbird
Dualit 889 espresso coffee maker problem
To pull a shot
1) Turn machine on (innermost right switch)
2) Red light goes on (power on)
3) Yellow light goes on (thermablock heater)
4) Wait for yellow light to go off
5) Detach handle (pull to left)
6) Clean handle, remove crema sieve, clean with soap & water
7) Put crema sieve in handle (you should have a choice of two)
8) Put espresso ground coffee in with brown handle
9) Tamp coffee down FIRMLY with handle
10) Place handle back into machine (push to right)
11) Ensure flip switch on leftmost side is at top position
12) Flip down rightmost switch to infuse coffee into handle
13) Wait 18 - 24 seconds
14) Flip up rightmost switch to turn off infusion
15) Put milk into container (about 200ml in a 600ml container)
16) Flip down rightmost switch to bottom position = steam
17) Keeping tip about 5mm from top of milk, foam to ~400ml
18) Place sugar in coffee, if desired
19) Pour milk in coffee
LATTE
YUM
May 06, 2008 | Dualit Espresso 889 Espresso & Coffee...
2nd light on the left is steadily lit
descaling time to reset the light i think you have to press the on buttom for 5 second if it doesnt reset let me know cheers
Jan 21, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Deluxe - trouble light on
Not sure which light you are refering to because the far right light shuld be temp ready light. The one you describe slunds like the descale light but that shouold be second to from the left. In which case it is telling you to descale. I can't attach a manual here so do a search for saeco repair and an authorized repair center should be able to get you one.
Aug 09, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
122 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
