Question about Canon MP140 PHOTO AIO All-In-One InkJet Printer
Can't insert ink cartridges
I have just bought the Canon MP140 and can't believe how complicated it is to insert the cartridges. If I position them according to the manual's diagrams, they just wobble about and there is no where for them to click into place. The hood above the cartridge place hides everything and I can't see where they may be inserted. Should the cartridges 'stand up' with the gold technical information dots pointing upwards, or should the cartridges lie down with the cartridge number facing upwards? This is very frustrating. Please help!
  • steveor83 Feb 06, 2009
    I have the same problem. There is nowhere to attach the cartridge. I'm all ouit of ideas.
  • copper2000 Mar 05, 2009
    when trying to get old cartridges out I try lifting the top of the computer while the power is on but they do not move to the place where they need to be in order to get them out
By default, when you open it the dock for the cartridges is parked at the far right. And with the power off (which is how I tend to open up machines) it stays there.
Try powering the printer on, THEN open the main cover: the docks slide to the left. Then it's simple enough to put the cartridge tilted with the 'smile' lower and facing you, push it along the channel until it clicks into position.
The envelope with manuals/CD was missing for my printer so this was not easy to guess...
Posted on Feb 15, 2009
Follow the instructions poted by this user thames_sider..... brilliant , sorted in a mo` Thanks....
Posted on Mar 02, 2009
  • 214 Answers
Are you lifting the entire top of the printer 1st? I just looked at the user guide. It shows lifting the entire top. Then put the cartridge in at an angle while inserting the rear of the cartridge hold the front of it slightly tilted down then push in until it clicks.
Here's a link to the site where I downloaded the user guide, maybe it will have better pictures that yours. Good luck. take a deep breath, don't let the machine get to you :-)
Posted on Jan 31, 2009
Error 19
Hi there-
Below are a list of the error codes for this model.
E16-E19 = Failed to scan head alignment sheet.
You can find this information at http://www.usa.canon.com/cusa/home
CANON MP140, MP145, MP150, MP160 RESET ERROR CODES
[Info140] pixel_trans.gif RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge
is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera
Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Nov 29, 2013 | Canon PIXMA MP150 All-In-One InkJet...
MP140 can't recognise the black cartridge that I've just installed. Error code 4 - any ideas? I've tried the manual - nothing, and not much luck online - Thanks
Error code 4 normally indicates that there is no unk, and the solution is by installing a genuine cartridge, Try to use Black PG40 remanufactured Canon printer ink cartridge. This cartridge is a high capacity cartridge which has been filled with 23ml of ink compared with the 16ml (Black) that you get with the originals. Compatible with: Canon Pixma MP140. if this error still occur it is better that you try the following procedure below:-
When you insert a refilled ink cartridge into your Pixma MP140 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won’t get the warnings again because the ink levels won’t be monitored by the printer.
Thanks
Oct 12, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
CANT PUT INK CARTRIDGE IN CANON MP140
For a tutorial (with images) on how to replace the ink cartriges, click on this link (CANON FAQs for your printer) :
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15294&kbpage=yes#
Then, in the "Please enter your question..." textbox, type "replace ink cartriges".
Click on the link that says "How do I replace ink cartridge(s)?"
Aug 16, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Just got new mp140 cant figure out haow to put in
After inserting them.... you have to lift them in an upwards direction and you hear them click into place.
Apr 28, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
My canon mp140 shows E4
From CANON FAQs for your printer:
Issue: ERROR LED: E, 4
Solution: Press and hold Stop/Reset button for at least five seconds.
Clearing the Ink Error If you want to continue printing in this condition, press and hold the <Stop/Reset> button on the printer for at least five seconds, and then release it. Replace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress and you want to continue printing, press the Stop/Reset button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
Apr 01, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Cannon mp140 reset
In order to get the machine works properly, you must insert with genuine ink cartridges.
Mar 27, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Just want to scan, no ink cartridge
Just press the Reset button for 5 sec till it displays "1" then u can scan without replacing the ink.
Mar 13, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
I placed a re-filled ink cartridges in my canon mp140 printer and
Computer chips in cartridges must be reset before the printer will recognize them as full. If you paid a shop to refill your cartridges take them back and complain. The best places will test the refilled cartridge before giving it to you.
Please note durability of prints using cheap ink is usually very poor, and as a result the manufacturers ink is usually much the better choice.
Mar 05, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon mp140
Replace the ink cartridge or press OK
Jul 28, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon MP140 PHOTO AIO All-In-One InkJet Printer Logo
121 people viewed this question
old marine
old marine
