Question about Nokia 1100
My mobile set is dead
As usual I am always keeping my mobile set off after 10 pm and switch on at 7.00 am in the morning.But this morning my mobile set could not get on in spite of checking battery connection. When it was taken to a technician, he suggested me to reformat the software of set. Please help me to solve the problem Thanks Kezang
  • Kezang Thinley Jul 31, 2007
    Warranty period of my set has already been finished in 2006 and I have not even insured. Please advice me how to get the power on.
  • 3 Answers
Change power ic
Posted on Sep 16, 2011
    Sniper:
  • 133 Answers
1-888-NOKIA-2U or http://www.nokiausa.com/A4433809 I would first check to see if its under warranty or if you have insurance on your mobile use it. sounds like its dead Mate. you really cant reformat or reset without turning it on, try powering it on while its plugged in the wall also.
Posted on Jul 30, 2007
Charge overnight and the charge runs out without ever being used??
If the battery is good
You have a parisitic draw somewhere:
Switch your Digital Multimeter to DC AMPs. Amps is usually indicated by an "A" on the Multimeter Switch. AC is usually shown as a "~" symbol and DC shown as a "-" symbol. You usually have to move the Multimeter positive lead to a separate socket on the Multimeter. Sometimes there are 2 sockets, a high range and a low range. Always test on the highest setting first. For example: high setting on your multimeter may be 10 Amp. Test on the 10 Amp setting first, then if the current drawn is less than your Multimeter Low setting, move to that setting and keep testing. In my example my Multimeter low setting is 0.3 Amps. Also indicated as 300mA (mA x 1000 = A).
WARNING! Once the multimeter is on Amps do not connect it directly across the battery and do not hit the starter button while testing for current Amps. This will cause the internal fuse in the multimeter to blow! A multimeter set on current is a very low resistance, almost a short circuit and will draw as much current as your battery will supply till something melts. Always plug the Multimeter leads back to volts when you have finished testing to avoid blowing the fuse next time you use your multimeter.
Voltage ReadingTo test for battery drain: Switch everything off on the car. Disconnect just one battery lead. For example disconnect the Positive Battery Lead. Set your Multimeter to Amps as described above. Connect the Positive Multimeter Lead to the Battery Positive terminal. Make sure the Positive Lead you removed from the battery does not touch anything grounded, like the car frame etc…. Connect the Negative Lead from the Multimeter to the Positive Lead you removed from the Battery. You should now see current drain measured in Amps. Move to the lower Amp setting on your multimeter if the current is lower than the setting on the Multimeter Low setting. Start to unplug the wires or fuses around your car and see if the current reading goes to zero. This will point you in the direction of the current thief. You can convert to Power measured in Watts by multiplying it by the Battery Voltage. Power = Volts x Amps 4.2Watts or (12Volts x 0.35Amps).
Mar 24, 2017 | Cars & Trucks
How to Lock all the Mobile including Theft Mobile
Gather them all; and keep all of it inside an iron box, and keep it deep under any pond.
Aug 05, 2016 | Sansui Televison & Video
I awoke this morning to find the sound on my Apex Digital LD4088 LCD tv is dead. The picture is fine, but sound is dead, how do I solve this?
Download the user manual to your TV. Clik here to download it. See whether audio options to it are set right. If all are right, check its speaker. If speaker is OK, the audio output circuit section should be troubleshooted.
If you feel any difficulty in downloading the manual, send your email address to me. I'll send a copy of it to you by return mail.
May 16, 2012 | Apex Digital LD4088 LCD TV
Cuisinart dc 1200 coffee maker auto start mysteriously shuts off
Sounds like the switches got damp when you cleaned it. Let it dry out very thoroughly before you plug it back in. Then set the TIME OF DAY first, and be sure you pay attention to AM/PM if you are not in the 24-hour mode. Next, set the BREW TIME. Once again, heed the AM/PM or you will have nice hot coffee either 12 hours early, or 12 hours late! (I don't know which would be worse.)
Mar 18, 2012 | Cuisinart DCC-1200 Coffee Maker
Date changes at mid day not at mid night.
Your watch is 12 hours out of step.The date changes ever second rotation of the hour hand.
If you advance the time 12 hours, the date will change at midnight.
You may have to re-set the date.
Sep 16, 2011 | Tissot PRS 200 Wrist Watch
We have a honeywell cm921 and we cant set the therm astat to come on in the mornijng and then go off then come on again in the afternoon on timer please can you help
Your CM921 has 6 built in temperature settings based on time of day:
1 - 6:30 AM
2 - 8:00 AM
3 - 12:00 PM
4 - 2:00 PM
5 - 4:00 PM
6 - 10:30 PM
meaning that at 6:30 AM the themostat will change its temperature setting to setting 1, at 8:00 AM it will change the temperature setting to setting 2, and so on. To schedule temperature settings which best fit you, determine which time periods you would like more or less heat.
For instance, to fit what you requested in your question you could program a temperature you would like to maintain in the morning and afternoon times when you would like it to be on, and in the time periods in between set a lower temperature as follows:
1 - 20C
2 - 16C
3 - 16C
4 - 20C
5 - 20C
6 - 16C
With this example your thermostat would turn on at 6:30 AM as long as the temperature was below 20C and maintain that temperature until 8:00 AM. At 8 it would change its setting to 16C allowing temperature to drop from 8 AM to 2 PM to a lower setting to conserve energy until afternoon time when the setting would change back to 20C from 2 PM to 10:30 and then change back to 16C to save energy throughout the night. The actual temperatures would be at your discretion based on your individual comfort level.
Pages 5 and 6 of the following link will guide you in setting each of the 6 temperature settings.
http://www.wolseleysbc.co.uk/_STEPData/Assets/Honeywell%20CM921%20Room%20Thermostat.pdf
I hope this helps. Let me know if you have any additional questions.
Dec 10, 2010 | Honeywell Programmable Thermostat Heater
Contact service error in my nokia 5220 express music phone
my nokia mobile 5220
problem: contact service
(switch on ,mobile main display NOKIA wive and contact servic pls help
Mar 19, 2010 | Nokia 5220 XpressMusic Cellular Phone
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
My cell fone is Unreachable inspite of being switched on
Mine is a nokia E71 locked to three. Three do all kinds of things to the cellphone which i believe renders some applications unusable, i am unable to install games via cable or via 3G, it wont let me call from abroad and the signal is always very erratic...cant wait to get away from three and their stupid mobile... fixes
May 19, 2009 | Nokia E71 Smartphone
Nokia 1100 Logo
82 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
