Question about Car Audio & Video
KRC-703 display does not work, sound does?
The face will flip open and there is no display and the last radio station is on with the previous volume ect. No buttons work. Tried to reset?
  • 3 Answers
Check to make sure the right face came with your unit, I had an alpine once that did the same thing when I accidentally grabbed my friends face plate. Everything worked but the LCD. Check the model numbers to compare
Posted on Jan 31, 2009
Santai TD-V26 user manual
The device has an on/off toggle switch and four control pushbutton switches (left ro right) are:
1. Menu (FM Radio or MP3 Player) select
2. Play/Hold
3. Back/Previous
4. Forward/Next
Inputs and output are:
1. 1/8" External Source Input Jack
2. Micro SD Slot
3. Mini USB 5v External Power Input
4. 1/8" Headset/Output Jack
5. USB Memory Card/USB Cable Input/ (Right Side)
The Menu switch has two functions, MP3 Player and FM Radio as indicated by the display. If the Play/Hold switch is pushed in and held for a few seconds the radio will automatically sweep and put the available local stations in memory. The back and forward switches are used to select the desired station. The display indicates station channel number and broadcast frequency (MHz).
In the MP3 Player function Menu function the Play/Hold Switch starts and stops the player. Back and Forward switches select the previous or next track. Simple as that. The player automatically plays the next file if left alone unless the Play/Hold switch is pressed. The display indicates file number and play time. No other functions, like folder selection, were found. If a 5v dc supply is connected to the Mini USB connector the battery will remain charged and it can be used as a small table radio/player. No tests were made to see how long it would operate on its internal battery.
The sound is good and better than expected for a device its size. Enough sound output to hear it in any part of an small house (With some distortion of course). The volume is controlled by holding the forward or back switches in for a couple of seconds and it will switch to volume level control. The display is LED rather than LCD and easier to view. It is on continuously when the player is working with the charger attached.
Aug 23, 2012 | Santai TD-V26 Portable Mini Digital...
Hi. I have a blaunpunkt CD34 stereo in my car and it seems to be locked into one radio station as no buttons work accept the volume. It will allow me to play a cd but I can only adjust the volume on this...
is your radio come with remote control? you can confirm other function with remote control, if still working, then most likely the face plate connector connection is loose, you have to dismantle the radio out from car, and then open out the side screw secure the face plate to radio body, Unplug the face plate out from body and re assemble back to test.
Aug 20, 2011 | Blaupunkt Car Audio & Video
Kenwood KRC 535 - Faceplate stops halfway when turning off unit. When unit on it will play music, but nothing lights up so you don't know what you're listening to. Also cannot change station. ...
There is a fine ribbon cable that links both the main unit and the face plate. Due to the constant movement of opening and closing some of the conductive tracks develop cracks. That is the reason why when it closes half way it looses contact and the motor stops turning. The display illumination track must have completely broken.
You will need professional help to replace it because its a little complicated to access this ribbon cable.Will cost you about 15$ plus labor.
Jul 14, 2011 | Kenwood KRC 535 Cassette Player
Volume went extremely loud..had to hit reset button..now will still flip but face wont lite up & buttons dont work
sounds like you may have a bad flexible cable. the cables generally last about a year or so on those decks, depending on how often the face flips around.
Jun 07, 2010 | Kenwood KDC-7011
03 chev silverado radio on but no sound
My van radio runs on 2 different fuses- both in the fuse box under the dash. One runs the lights the other the sound. Hope this helps.
Jan 11, 2009 | 2003 Chevrolet Silverado 1500
No display
Did you install the unit with the correct wiring harness, or cut-and-splice the wires from the factory line to the stereo lines? This could be a problem.
Aug 27, 2008 | Car Audio & Video
No display ,no radio
I just looked further on the internet and found other people with same or similer problems and think I have found the answer.
Thank you for your help in this matter .
Louie
Jul 09, 2008 | Toshiba Sony CDXM850MP CD Player
Kenwood krc 479r
If there was no spark and wires hooked up wrong in the first place, your player should work if you find the PWR lead and the Remote lead and ground. Then speaker wires +) and (-
Sep 25, 2007 | Kenwood KRC-479R Cassette Player
Volume, Display and FM stations missing?
This could be a bad ground on the radio, or you have serious circuit problems. if a fuse blew, the radio would not work at all. Check the installation first, replace the radio seconds. Good Luck
Jul 29, 2007 | Sony CDX-L420V CD Player
Car Audio & Video Logo
126 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
