Question about Garmin nuvi 205 GPS Receiver
I would like to get new vehicle indecators
I would like a red car
  • srowan33 Jan 31, 2009
    can you tell me how to get the different voices.. i download them like i did the cars but its not on my nuvi
  • 214 Answers
Here's a link, when you get there, click on the last link "Garmin Garage". They have a lot of fun cars ect. Have fun!
http://www8.garmin.com/vehicles/
If this helps you plz rate this. Thank you kindly.
Posted on Jan 31, 2009
Putting indecators seperate to brake light
Depending on model and year of car the only way to separate the brake and turn signal lights would be to re-wire one of them completely. The older vehicles, and some newer ones, just use a double filament bulb that handles park / run lights on one side of bulb, and the turn signal / brake light is the other. Newer cars sometimes have the turn signal split to a different set of light sockets which are usually yellow in the tail light housing. But if car is not wired like this you will have to run all new wire for the turn signal system. Some newer vehicles have a sensor in system that detects light bulb failure so if you change the system you may run into issues with this also.
Jan 17, 2015 | Cars & Trucks
Transmission indecator light does not light up and truck will not start
It sounds as though you have a faulty Transmission Range Switch. More details on the vehicle is required to be certain. Year and model would help.
Dec 02, 2013 | Dodge Pickup Cars & Trucks
"ABS" indecator light is on
Most common problems are front wheel bearings they are integral to the wheel speed sensors for ABS system. I'd get it scanned to see which side is faulty.
Jan 26, 2011 | 1998 Pontiac Sunfire
No turn signallights fuse good
IF your indecators are not working none of them then your problem is either a relay or a FLASHER can (the thing that goes click click )every time you switch from side to side, and it should be found under the dash board .
w hen you have found it turn on the key and the left hand indecator and then tap it slightly with a pen or your hand and if it works replace it Other wise unplug it and get it checked out before buying a new one.
Ron....
Nov 02, 2009 | 1999 GMC Yukon
Red light indecator keeps flashing red
Flashing red is a fan fail . It is probly blinking like 3 short and 1 long blink. If so then most likely your tv needs to have a new dmd fan installed.
Also once that tv detects a stopped fan it must be unpluugged from the wall outlet and plugged back in to get it to even try to turn on again. Sometimes fans will kinda work after a few trys or when the tv gets moved around.
Oct 11, 2009 | Mitsubishi WD-52327 52" Rear Projection...
I have a problem with my trailer wiring for my 98
Hi There,
There are so many plug /trailer type combos that I finally made a list and posted them as a tip.
Click here for the Trailer Wiring Cheat Sheet.
Hope you find this very helpful
Mike
Sep 23, 2009 | 1998 Ford Expedition
Phone wont turn on
first thing connect your phone to AC power (electricity) then see if the charging indecator is red or orange or green ,
then try to start your device if it's not working the problem is hardware and go to a pepairmant workshop ,
if the indecator doesn't work and there is no light try to change the battery with a new one and then do the stpes agian
Nov 05, 2007 | i-mate JAM Pocket PC
Garmin nuvi 205 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
