Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Hard disk very slow and restart.
My disk is very slow and restart and some hard disks are not dedected the biossetup.the message is the disk boot failier.
  • 80 Answers
Seagate is known for hard drive failures. The S.M.A.R.T. feature may warn you that the drive is failing. This is not uncommon and is most likely the case of why it is going slow now. You should contact seagate ASAP to see if they can give you a replacement.
Posted on Jan 31, 2009
Hi I've got this problem with my Acer Apires laptop "a disk read error occurred, press ctrl+alt+del to restart. I keep pressing those buttons and the same things come over and over again what should...
Hi
that seems your computer cant boot from hard disk '
you can solve it by :
- be sure that nothing in cd drive and there's no flash memory in notebook.
- when you press start button , click F2 to enter set up and go to boot options and assign the first boot to Hard disk drive.
- if that don't help try to repair your windows ... or re install it
- final may be your notebook hard drive corrupted.
I hope that helps you
Apr 25, 2011 | Acer Aspire One PC Notebook
Hi! I need help with my computer. I use a seagate ST380811AS hard disk in my desktop computer. The problem now, is that everytime I start my computer "A non system disk" appears on the monitor or...
1 Remove any floppy disks or bootable CDs, DVDs, USB flash drives or other bootable media from the computer. Attempt to restart the computer again. Proceed if you continue to receive the error.
2 Restart the computer again. Press the key required to enter your BIOS setup. (The monitor usually displays a "Press [key] to access BIOS" right after restarting your computer. Press the key shown on your screen.)
3 Navigate to the "Boot Options" or "Advanced" menu by using the arrow keys. (The precise menu terms will vary according to your computer and BIOS type.)
4 Select the hard disk that contains your operating system (usually C:) as your primary boot device. Select your CD/DVD drive, your floppy drive or another hard disk as your secondary boot device.
5 Save and exit the BIOS. Proceed with the next step if you see the "Non-system disk error" message again.
6 Restart the computer. Return to the BIOS' "Boot Options" screen by following the steps above, then set the "CD/DVD drive" as the primary boot device and the hard disk as the secondary boot device. Save and exit the BIOS.
7 Insert your Windows installation disc. Restart the computer. Press any key to boot from disc. Follow the on-screen prompts to reinstall Windows.
8 Replace your hard disk drive if you cannot install Windows.
Thanks for choosing Fixya
Sandeep
Mar 19, 2011 | Computers & Internet
Acer 5534 will not boot up....tried recovery disk....but nothing......error message PXE-E61-media test failure..........no bootable device
Hello:
Your Acer laptop is not detecting a bootable device, for sure your hard disk is:
1.- Malfunctioning and has lost its master boot record.
2.- It can be ruined and must be replaced.
In the first case, primary and recovery partition are bad, as you mention the recovery process failed (ctrl +F11). First, press F2 during POST, when "a enter Setup message" is prompted on the bottom of screen to check if the hard disk is listed on the Main BIOS properties. If detected, the hard disk can be recovered booting from DVD-ROM. In the BIOS setup utility, you need to select boot from de DVD-RW. Insert Windows 7 setup disk and it will check for possible boot errors, choose repair when prompted. Follow the instructions. The system will restart.
If the hard disk was not detected in BIOS properties, you should ask Acer for guarantee.
You may review this link for further information: http://www.acerlaptoprepairs.info/aspire-5534/
I hope this helps. Thanks
Jan 30, 2011 | Acer Computers & Internet
Computer is slow. Hangs in between.
There is hardware problem, first of all you should check your hard disk. It might be possible that your hard disk have bad sectors. Onother hand it could be possible your hard disk partition table has disorder.
If you have FAT32 file format of your drive then you should must run scandisk on your hard drive.
Good Luck
Aug 13, 2009 | Computers & Internet
A disk read error has occured press CTRL-ALT-DELETE to restart.
check power chord or port of hard drive if u dont find any prob. pleace re insert power cord with card board packing. definetly u solve the problem.
Jan 10, 2009 | Seagate (ST3160827AS) 160 GB Hard Drive
Takes a very long time to boot
try to replace your Hard disk. maybe your hard disk is damaged and need to be replace
Aug 14, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
Wont start up
Hello rfb640,
This is Romeet, i would like to help you with this problem. Please go into the BIOS and check if the hard disk is detected? if it is then remove the hard disk from the laptop and turn on, check if you get any error message for " disk boot failure" or something of that effect or you continue recieving the white cursor?
B.Regds
Romeet
Dec 01, 2007 | Toshiba Satellite M30 Notebook
Seagate harddrive diskread error
go to bios and see there whether it is showing showing your hard disk or not if it is showing then re-install your XP again format your hard disk with the slow formating option,while re-installing it.
Nov 23, 2007 | Asrock GE PRO-M2 Motherboard
Pc cant boot
Is the BIOS settings ok? Try changing the Molex power Connector or Change the power Supplies. Hope this helps
Sep 17, 2007 | Computers & Internet
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
447 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
