Question about KitchenAid Superba Architect KSCS25IN Side by Side Refrigerator
Water filter I have a light on that says I need to replace my water filter, but I can't find it. I also misplaced my user manual. I need assistance locating the filter so I can replace it.
  • 2 more comments
  • Steve Karrmann Jul 30, 2007
    Great help!
    Thank you!
  • Anonymous Feb 01, 2008
    I have successfully replaced my water filter but the light is still on indicating it needs to be replaced. There are no leaks and the refrig is fully operational except for the continued illumination that the filter needs changing. Any suggestions?
  • Chris Pickett Nov 27, 2008
  • Anonymous Feb 21, 2009
    I cannot locate the Whirlpool Gold - Conquest Model 6565HE/
    Sniper:
  • 133 Answers
Its on the bottom left of your fridge. 1. Press the eject button to release the filter from the base grille. 2. Pull the filter straight out. 3. Turn the cap counterclockwise to remove it from the filter. IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter. 4. Align the ridge on the cap with the arrow on the new filter and turn the cap until it snaps into place. NOTE: You can run the dispenser without a filter. Your water will not be filtered. Simply insert the cap all of the way into the base grille and rotate the cap until it is firmly in place. 5. Remove the protective covers from the O-rings. 6. Push the filter into the base grille. The eject button will pop back out when the filter is fully engaged.
Posted on Jul 30, 2007
Filter light on
Water Filter Status Light and Filter Reset
The filter reset control allows you to restart the water filter status
tracking feature each time you replace the water filter. See "Water
Filtration System."
After changing the water filter, reset the status light. Press the
OPTIONS button to enter Options mode, then press LOCK to
initiate the reset, then press MEASURED FILL to confirm that
you want to reset the status light. When the system is reset,
the "Order" and "Replace" icons will disappear from the
display screen.
These instructions can be found in the=> GZ25FSRXYY2 User Manual . As for the dispenser and ice dispenser problem this could be related to a loose connection in the door where wiring attaches to control panel and/or where door wires go from door to cabinet also a defective pressure switch where glass is pressed to get water or ice. Can you tell me when this additional problem began?
I am here should you need me, Thanks John Tripp Appliance 911
Apr 21, 2014 | Whirlpool Refrigerators
SRS580DW Water filter indicator red light is on. Where in the fridge do I find it to take it out to replace pleace?
Resetting the water filter indicator light can also be found in the user manual for your SRS580DW Refrigerator User Manual page 8 The water filter indicator initially lights up green. Press the ICE TIMER and ICE MODE buttons at the same time for about three seconds to reset the water filter installation date. • The green light changes to orange after five months to indicate that you should soon change the water filter. It changes to red after an additional one month (six months after the water filter was changed or installed) to indicate that you must change the water filter. • If you wish to turn off the filter indicator lamp or the filter is not connected, press the ice timer & ice mode button simultaneously for 5 seconds. If you wish to turn on the filter indicator lamp again, press the ice timer & ice mode button simultaneously for 3 seconds. Click Here for the SRS580DW User Manual I am here should you have questions Thanks Sea Breeze
Jun 03, 2013 | Refrigerators
How do I change the water filter for the refrigerator, Samaung RF323TE
Page 13 of the User Manual explains where and how to change the water filter RF323TE User Manual
Click link below for instructions
Where Is The Water Filter And How Do I Install It on my French Door or Side-By-Side Refrigerator?
Or click HERE If you have questions or trouble navigating the Samsung site please ask questions and I will try to assist you, Thanks Sea Breeze
Mar 31, 2013 | Samsung RF323TE 31.6 cu. ft. French Door...
Water filter light
Instructions on how to reset the water filter status light on page 14 of your GZ25FSRXYY User Manual
Reset Water Filter Status
After changing the water filter, reset the status light. Press the OPTIONS button to enter Options mode, then press LOCK to initiate the reset, then press MEASURED FILL to confirm that you want to reset the status light. When the system is reset, the "ORDER" and "REPLACE" icons will disappear from the display screen.
If the above is not your model number then click HERE to enter the correct model number Questions please let me know, Thanks Sea Breeze
Mar 01, 2013 | Whirlpool GZ25FSRXYY
After i change the water filter de button of water still red
The water filter status light, located at the top of the refrigerator
compartment, will help you know when to change your water
filter cartridge.
Style 1 - Standard status light (on some models)
When the water filter status light changes from green to yellow,
this tells you that it is almost time to change the water filter
cartridge (90% of the filter life has been used). It is recommended
that you replace the base grille water filter cartridge when the
water filter indicator light changes to red OR water flow to your
water dispenser or ice maker decreases noticeably. See
"Changing theWater Filter Cartridge" later in this section.
After changing the water filter cartridge, reset the water filter
status light by pressing the light switch 5 times within
10 seconds. The water filter status light will change from red to
green when the system is reset.
If you need Adobe Reader Click=> Adobe Reader X (10.1.0) (50.25 MB)
If helpful please rate this solution, Thanks Sea Breeze
Click Photo Below for User Manuals
Jul 29, 2011 | KitchenAid Superba KSRG25FK Side by Side...
Just wondering if this unit has a filter or filters that need to be changed?? (Frigidaire 70)
Yes, your unit has an air filter, that should be removed and cleaned at least once every two weeks, while in operation, The filter is located behind the louvers on the front of the unit. To access and remove it, remove the water bucket and just inside the bucket holder at the top of the opening, you will see a tab type of handle. This handle is part of the filter frame. Pull that down and out and the filter will come with it. Back flush the filter with clear warm water. Dry it thoroughly, before reinstalling it in the unit. Never operate the dehumidifier without the filter installed.
To assist you further, in case you have misplaced your Owner's Manual, I have included a link to the Manual for your model. You can download and print the manual for future reference.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0180en.pdf
Hope this helped you. Please let me know. Thanks.
Jun 25, 2011 | Frigidaire FDF70S Dehumidifier
I've got a side by side Whirlpool refridgerator. The Water Filter status light is not indicating. What could be the problem and solution?
There are several pages that explain dispenser programming. This is on page 10 of the owners manual.
Water Filter Status Light (on some models)
The water filter status light will help you know when to change
your water filter. When the water filter status display changes from
"GOOD" to "ORDER," this tells you that it is almost time to
change the water filter cartridge. Replace the water filter cartridge
when the water filter status display changes to "REPLACE." If
water flow to your water dispenser or ice maker decreases
noticeably, change the filter sooner. The filter should be replaced
at least every 6 months depending on your water quality and
usage.
After changing the water filter, reset the status light by pressing
and holding the FILTER button for 3 seconds. The status light will
change from "REPLACE" to "GOOD" when the system is reset.
Changing the Water Filter
5. Remove the covers from the O-rings. Be sure the O-rings are
still in place after the covers are removed.
7. Flush the water system. See "Water and Ice Dispensers."
Water Filter Status Light:
The water filter status light will help you know when to change your water filter.
When the dispenser control panel's water filter status display changes to "ORDER," this tells
you that it is almost time to change the water filter cartridge.
Replace the water filter cartridge when the water filter status display changes to "REPLACE."
The filter should be replaced at least every 6 months depending on your water quality and usage.
NOTE: If water flow to your water dispenser or ice maker decreases noticeably, change the
filter sooner. After changing the water filter, reset the status light.
Details:
Pressing and holding RESET FILTER starts the 3 seconds countdown. Using the dispenser
cancels the countdown AND no dispensing is permitted. The number '3' blinks 3 times and the
'invalid' tone sounds 3 times and user has to release both the pad and the button and press
the button again to start it over
After 3 seconds, the BLUE WATER BARS in the Icon flash and an audible tone sounds 3
times. When the system is reset, the "ORDER" and "REPLACE" icons will disappear from the
display screen. See figure 16.
Note: Users can reset the filter status at any stage.
If you should need the complete and exact model number and manual with parts manual you will need to enter the Model Number here=> sea_breeze_132.jpg Manuals, Guides and Instructions Please rate this solution, Thanks, Sea Breeze
User manual click HERE
Apr 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Where is the water filter located on the Samsung SRS2028CSS
The water filter is located in the
upper right-hand corner of the fresh
food compartment.
1. Remove blue bypass cap and
retain for later use.
2. Remove sealing label from end
of filter and insert into filter head.
3. Rotate gently clockwise until
filter stops. Snap filter cover
closed.
4. Reduce water spurts by
flushing air from system.
Run water continuously for
two minutes through
dispenser until water runs steady. During initial
use, allow about a one- to two-minute delay in
water dispersal to allow internal water tank to fill.
Sep 10, 2009 | Jenn-Air JFC2089HT Bottom Freezer French...
The warning light to reset filter came on. I've
Resetting your Refrigerator filter indicator light after changing your water filter Some people are not aware that after you change your refrigerator water filter, there are two more steps that should be taken to complete the water filter change process.
Step 1:
Reset your water filter indicator light - Most new refrigerators come equiped with an indicator light that notifies you when it is time to change your water filter. This light does not automatically reset when you change your water filter. Here is a list of refrigerator manufacturers and how to reset the indicator light.
Amana Refrigerators - Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire Refrigerators - Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
HotPoint Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Kitchen Aid Refrigerators - Press and Release the Light Button 5 times Quickly.
Maytag Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung Refrigerators - Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool Refrigerators - Press and Release the Light Button 5 times Quickly.
Step 2:
Flush a couple of gallons of water through your new filter. Since most refrigerator water filters are made of carbon, some carbon residue is present in the first gallon or two of water. This will leave a bitter taste and residue in your water. If you continue to have these problems after flushing a couple of gallons through the filter, it is possible that you have a defective water filter.
Once these two steps are completed, you are all set to enjoy great tasting ice and water through your refrigerator. If you don't see your manufacturer listed or the insructions don't work for your model please post a comment with your make and model number so that we can provide exact instructions for your model.
May 06, 2009 | GE PDS22LBN Bottom Freezer French Door...
KitchenAid Superba Architect KSCS25IN Side by Side Refrigerator Logo
248 people viewed this question
Top KitchenAid Refrigerators Experts
vince
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
