Question about Compaq Refurbished 280WATT POWER SUPPLY FOR PROFESSIONAL WORKSTATION 5100 Power Supply
DO ANYBODY KNOWS WAT TO DO IF DISPLAY NOT APPEARS
    Problem Solver:
  • 10 Answers
Plug off the Monotor Data cable from CPU and power the Monitor. If anything display like no signal or in old monitors, Bright/Contrast/Color switch light up display, Then monitor OK But CPU Defective. If monitor not power up even LED not glowing, Monitor power supply unit problem.
If CPU Problem, then just open the RAM and here if any beepcode occurs. If beep code gives then your Motherboard & Power Supply (SMPS) is OK. If not open all cables from Motherboard Except power switch and SMPS power and reenergize and here. CPU Failure or RAM failure will be isolated in this test. Like on you can pinpoint the fault.
Posted on Jan 30, 2010
  • 80 Answers
The 280W may not be supportive enough for the computer requirements and is not diverting its power correctly to power the VGA part of the motherboard.
Posted on Jan 31, 2009
Hello ,Anybody know how to fix the display of a philips soundbar HTS6100
You will have to replace the neon bulbs or the ballast of the display.
Sep 03, 2014 | Audio Players & Recorders
Protherm
What is the make and model of the boiler?
Jun 03, 2013 | Protech Systems FasNSeal FSWMKE4 4" Vent...
My gateway laptop wont charge at all i even bought a new battery and charger for it but it still wont charge or power on at all. if anybody knows wat is wrong please let me know.
This can be caused by either your motherboard or a broken power jack. Most common is the broken power jack. These can be replaced some will be separate from the motherboard and plug into it while others are soldiered to the motherboard and will require adept soldering skills so as to not over heat the circuits near the power jack. Most parts will be available on Ebay or online laptop parts stores including the power jack and if needed the motherboard.
Feb 19, 2011 | Computers & Internet
Does anybody out there knows anything about R1's I'm having problems with code error 17, and Exup motor not working.... Is there a way maybe connecting the wires to the lil motor that control the intake...
If the code is coming up then your exup valve is probably stuck open or closed and needs to be removed and greased. when you turn the ignition on the bike will do a exup check and preform a cycle which is the noise you can hear so watch the valve cables and see if they move, if they dont then the exups deffinately stuck!
Jan 03, 2010 | 2006 Yamaha YZF-R1
Creative ZEN 4GB
Hi, I had the same problem with my Zen V Plus. I held the volume + button in and connected the Zen to the computer using the USB cable and the Zen came back to life ! Try it - it might just work like it did for me.
Jun 19, 2008 | Creative Labs ZEN V Plus MP3 Player
Green line on each side of the plasma display.
Anybody knows how to reapair about vertical color- stripped lines appeared on screens and some trace of greenish images exist after each images changing, my TV is Toshiba Plasma Color 42HP83, I appreciate , thanks
Jun 05, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Nokia 6600 keypad problem
Dear sir,
pls change the original UI ,if it is not solved than change the key pad IC (both), it will solve the key pad problem.
Jan 18, 2008 | Nokia 6600
Xbox360 connection problems
It appears we need to buy a different router. There is no way to change the MTU on the Blitzz BWA711
Nov 01, 2007 | Blitzz Technology BWA711 (B3WL000900)...
TURNS ON BUT NO SOUND
if the amplifier integrated circuit is busted that will not sound even the power will display the front panel.
Sep 13, 2007 | Yamaha RX-V420 Receiver
Computers & Internet Logo
138 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
