Question about Nokia 6600
Joystick porblem I have nokia 6600 its joystick is not doing 'OK'(its not working while pressing joystick)but it moving (up,down,left and right) properly.Plase tell me solution. thanks.
When u getting that problem just switched off and restart it work autometically...or else open the front cover and clean it.
Posted on Jul 30, 2007
SOURCE:
Joystick
Hello, welcome to Fixya!
Do you mean your phone is having a joystick problem? If yes, disassemble the phone, free the joystick with your hands by using your finger to navigate it up-down-left right severally.
Assemble the phone and check the joystick. If problem persist, take the phone to a repairman.
Good luck.
Nov 28, 2011 | Nokia 6600
How can I use it as a camera? I have it all plugged in and installed but it won't regester as a webcam :/
Connect camera to PC with USB cable. On camera switch on and press joystick/OK to get menue on screen. Move joystick to get the set-up icon highlighted and press in OK. Use joystick down arrow to move down menue to "USB mode". Use joystick right or left arrow to change setting to PC CAM. Press OK and you should now have camera acting as a webcam.
Mar 16, 2011 | Fuji FinePix F601 Zoom Digital Camera
Most of the time my the left button joystick remain unactive
ur set must be old. actually ur joystick needs a cleaning. it might be due to lot of dust.. but there r more chances tht u will have to get ur joystick replaced. it is a common problem in nokia 6600. mine 6600 down joystick was inactive and when it was active it moved thre 4 times all together. so i got it replaced.. pls rate
Aug 12, 2009 | Nokia 6600
Joystick
It is rather frequent problem with Nokia.
If your mobile warranty is expired then try to disassemble your phone and clear you joystick of dirt.
If it doesn't help then nothing can be done but bringing it to service.
As far as I remember menus on 6600 are not recurring so you can not use only up direction to reach icons that are below. I did so on E70 when had he same problem with joystick.
Jun 29, 2008 | Nokia 6600
Nokia 6600 joystick
make a jumper w/ a jumper wire joystick #4 to flex #4
skilled technician can performed the jumper'
or replace it w/ new keypad joystick of 66..00
Oct 21, 2007 | Nokia 6600
Joystick problem
see budy what u cud do is open up the cover of ur handset blow some air into the part of joystick might have some dust particale stucked there, otherwise change ur joystick.
Oct 20, 2007 | Nokia 6600
Cant go left on joystick last solution no good
see buuddy if u have allready triesd with blowing out the dust from joystick part than go for the change of the keypad(joystick). the problem might be with the joystick it might have got broken so change the joystick and than try.
Oct 11, 2007 | Nokia 6600
Cant go left with the joystick more in msg
remove joy stick rotate it by 90 degree & insert it again.there r 4 points beneath it for 4 directions ,it is not sensing the left one .otherwise u can replace the joystick from nokia care centre.
Oct 09, 2007 | Nokia 6600
Nokia 6600 joystick (to the left) not working
I HAD THE SAME PROBLEM WITH MY NOKIA 6620 FOR 3 DAYS. AND I OPEN THE PHONE AND PLAY WITH THE JOYSTICK AND IT STARTED WORKING. TRY THAT...
Sep 10, 2007 | Nokia 6600
Nokia 6600 joystick problem
i have a friend in the Philippines, a known celfone technician in his own right, but he has a knowledge in replacing joystick of several phone models/brands. this is his e-mail address [email protected] He could be of great help to you.
Jun 06, 2007 | Nokia 6600
Nokia 6600 Logo
144 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
