Question about Coby MP-C883 MP3 Player
Won't turn on
Player is brand new--worked for 3 days; fourth day added some songs; 5th day--won't start. Changed battery--no good. Connected to computer--light on but will not play. Note--not headphones.
    Problem Solver:
  • 13 Answers
Tetasonja40 , your problem may be the same as some of the other players. IF you don't have a license in the music you are copying the player loads it and it is visible but will not play and may even lock up the unit that it will blink on then when you hit play it shuts off or the light remains on but solid and will not play. Try removing the songs one at a time till the offending file releases the unit. I spent hours resovling this on other units. another problem that occurs is the players stop recognizing mp3 files for replay. converting them to a wma may resolve this problem.
Posted on Mar 20, 2009
Trac phone won"t turn on or charge. Any ideas?
What model phone? How old is the battery? You may need a new battery.
Jun 26, 2014 | tracfone.com
My 1999 Chevy Silverado 1500 V6 Standard one day fine next day nothing turn key won't start batterys good
Through your own admission, you need
to go to a repair shop, which one would
assume, you always go to
Mar 20, 2013 | Cars & Trucks
Fuel pump cycling long time bike won't fire,has good spark.
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
What to do When Your Motorcycle Won Start
1098 won start
Ducati 907 906 Paso Workshop Service Repair Manual 1988 1993 Searchable...
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Mar 14, 2013 | Ducati Motorcycles
Battery keeps draining already put in a brand new alletantor and brattery still draining and battery lights comes on and truck won't start
You would have checked the charging system before replacing the alternator, so I will assume the charging system is good.
If the battery is being discharged overnight or over a few days, you would need to disconnect it and check every circuit on the truck to find the drain.
Oct 10, 2012 | 1990 Ford F150
2000 Lincoln Navigator won't start. First time in 12yrs.
im a import guy ..im tell u its your battery post tht went b ad they cost 10 dollar ez fixs good luck
Aug 30, 2012 | 2000 Lincoln Navigator
Won't crank has new battery
if the lights come on you'r getting juice from the batt,if they go out when you crank the motor over batt is bad or you have bad batt connections
Aug 27, 2012 | 2000 GMC Jimmy
1998 Ducati Monster 750 won't start. Ticks over ok, but won't "fire". New fuel in tank only two days ago, ran several trips since, just won't start now. Tried push-start, sounds like...
Hi, Mlyndon and the usual suspects are:
1. Fuel tank empty.
1999 750SS engine turns over but won start Ducati ms The Ultimate Ducati...
Ducati Monster won start fixed see how
Free Ducati Motorcycle Service Manuals for download
Ducati Maintenance
Aug 31, 2011 | 1998 Ducati Monster 750 - Dark - City -...
Coby MP-C883 MP3 Player Logo
75 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
