Question about Samsung HT-Z310T Theater System
Keeps going off.
The unit shuts itself off,when I turn it on.Its reads protector,and then off.help
  • lunkheadtoo Jan 31, 2009
    yes, tried wall and power strip.
  • 636 Answers
Do you have it plugged into a power bar ?
Posted on Jan 31, 2009
My Sony KF60XBR800 keeps shutting off while also triggering the surge prootector. What is causing this and is it do it yourself fixable?
surge protectors only work in one direction--from the power supply to the machine and are there to dampen a sudden over voltage surge in power supply-- lighting strike or power surge after grid failure or outage
I am thinking that the unit you keep switching on is an earth leakage unit or circuit breaker that is in the system to prevent electrical shocks from bad insulation or low performing components
if that is the case you have a potential short in the unit and should have the machine checked out at an appliance shop
Jul 17, 2015 | Sony Grand WEGA KF60XBR800 60" Rear...
My window air conditioner keeps turning off. I reset the surge protector and it goes back on and then shuts off
remove the surge protector it over heating . your unit is probley experencing a low voltage condition due to total demand due to the heat wave
Jul 22, 2011 | Heating & Cooling
When home theater is turn on, protector push power is flashed on thee screen. player will not function further. volume level is 9. currently can't be turn down.
Protector means there is a short circuit somewhere in either the speakers, the wiring or inside the unit itself....you can try disconnecting all the speakers and then turning on the unit...if the protector goes away, then you have a bad speaker or bad wiring to the speakers....if the problem stays, then there is a faulty circuit in the receiver itself and will need to be serviced
Feb 05, 2011 | Audio Players & Recorders
It keeps blinking protetor
The protector circuit protects your amplifier from shorted speakers . One of your speakers , or more speakers are shorted out . To figure it out easily follow these instructions . Turn the unit off . Now unplug all of the speaker wire connections from the back of the unit . Turn the unit on . Make sure the volume is turned all the way down . The protector light should not light up . If it does , the problem is inside the unit itself and we'll have to be repaired at the shop . If the protector light is off than continue on as follows . Connect the speakers one at a time to the unit . Each time you connect a speaker , turn the volume control up and back down making sure the protector light does not come on . When you connect the bad speaker , the protection light should come on . Whichever speaker makes the lights come on when connected is the bad speaker and should be replaced .
Oct 21, 2010 | Sony STR-DA2ES 6.1 Channels Receiver
The radio powers up but turns off after a few seconds
disconnect the speaker wires at the unit and tape them off one by one. Then re-power up the unit, if it still shuts down, it is an internal problem and needs service. If it stays on, re-connect one speaker at a time and test power again. When you find the speaker with the problem it will shut off. It's going into protection and keeping itself from damage. Once you find the bad wire or speaker, check the wire by disconnecting it "at the speaker" and turning the unit back on. if it still cuts out, replace the wire. If it stays on, meter the speaker by checking it for resistance, if your meter reads 1..... the speaker is blown and needs to be replaced. If your not handy with a meter, go to any car audio shop with the speaker and they can test it for you, usually for free. Hope this helps.
Jun 18, 2010 | JVC KD-S6060 CD Player
I hava an accurain 5048,reciever sound shuts off,protector reads
as you have described the unit is in protect mode. disconnect all cable/wires to this unit. - and try again. if it is still in protect-a definate short within this unit.
Mar 06, 2010 | Audio Players & Recorders
No heat and turns itself off after 4 secs
1)Turning itself off can be as a result of the sensor getting feedback of not enough ventilation.Ensure unit is able to breathe by bringing it away from the wall to allow airflow. If that doesn't fix it THEN>>>>>
2) The Magnatron which is the heart of the unit is damaged and so the sensor reads overload and shuts down as a protection against fire.
Repair of the magnatron often exceeds the value of the machine and in your case is not worth repairing. You can buy used ones and refurbished trade ins cheaper than your repair costs will be
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 13, 2009 | Panasonic Microwave Ovens
Hp psc 2200 printer will not turn on.
If connected to a power surge protector, turn the protector strip off / on.
Jun 10, 2009 | HP PSC 2210 All-In-One InkJet Printer
Tv shuts itself down
This is due to bad caps read here what a cap is www.badcaps.net see you tv is getting hot as normal but the caps cannot stand it any more thus shutting the tv down. The bad caps would be more or less in the power supply unit of this TV. So you can buy a new psu or get it repaired by a expert.
May 25, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Samsung HT-Z310T Theater System Logo
183 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
