Yes I just recently bought a new clarion marine head unit to replace my existing stock stereo in my boat. I replaced all 4 existing stock speakers with new Polk audio speakers. After wiring the head unit, everything is fine and operational except when I turn the stereo up it does not distort as normally would if the speakers were not getting enuff power from the stereo. Well I turn it up and it makes this noise like it's clipping or as if a cd was skipping here and there but it's not the cd tried a couple as well as the fm radio does the same thing but only when the stereo is turned up. I got ahold of the people I purchased the unit from by email and he said to try and ground it differently. Now i'm not sure why this would cause it to clip cuz I just used the same stock ground wire that was going to my old stereo...please help
-   I just installed a Clarion M275 and I am having the same exact problem. I have installed numerous stereos in the past and this is the first time this has ever occured.-   plyons
if your radio is puiing more power your ground might not be good enough, use the same spot but remove the ground and rough it up a little on the base with some sand paper or add a metal o ring to get a better ground.
I just installed a clarion M275 in my boat and had the same problem. I ran a heavier gauge power wire to the battery and the problem is solved. Try doing the same and it should be the remedy.
all the songs play when it is connected to my computor,but when i connect it to my car stereo usb...
(More)
all the songs play when it is connected to my computor,but when i connect it to my car stereo usb port not even half the songs play.Any suggestions?
My boat has fairly good quality of sound when listening to a radio station, but when i put a cd in,...
(More)
My boat has fairly good quality of sound when listening to a radio station, but when i put a cd in, i only hear the sound coming out of the speakers on the right side of the boat. Then if I plug an ipod into the aux outlet I can hear out of both sides of speakers, but it is very scratchy. How can I fix this?
An Ipod will play the songs but my USB 8GB Kingston Data Traveller device wont Niether will my Cowan...
(More)
An Ipod will play the songs but my USB 8GB Kingston Data Traveller device wont Niether will my Cowan D2 2GB. i bought this HU from Kenwood so i can use it this way and not to be able to use it sucks. Do i need to format those devices in some other way?
