Question about Logitech Cordless Desktop MX3200 Laser Keyboard Mouse
My keyboard will not type!
I've been tyring to fix it by reconnecting and stuff but I can't fix it
  • 214 Answers
This seems to always work for me as my Logitech does this too. I plug in the wired keyboard & use it for about 2 hours, then I turn off the PC & plug in the Logitech again and it usually works. I can't explain why this works but I'm always happy when it does. Good luck.
Posted on Jan 31, 2009
Why when i type some of the letters dont show up
That would be due to a faulty keyboard, due to old age, lifespan of keyboards or maybe during typing you are missing the key and the keyboard results in not recognizing that command. If it is happening with a deliberate press (even when you press harder) it is due to the contact panel underneath that is making your letters appear. Maybe a cleanup of dust and stuff will fix it, or as a more expensive solution a new keyboard. Ebay ranges keyboards for vaios at around 25dollars
Oct 22, 2012 | Computers & Internet
Wireless Keyboard HP RK713A not typing correctly
Try going to Device Manager. Right click on the Keyboard and choose Properties. Click on Update Driver as it might find something (let it look online also). Reboot the computer. If that doesn't work, go to Device Manager, right click on the keyboard, choose Uninstall, and reboot the computer. When the computer starts up and sees the keyboard and loads a driver(s) for it, it might fix it. Good luck.
Jan 15, 2018 | HP Computers & Internet
My computer seems to boot up fine but my monitor says no signal and my keyboard doesnt work
You can try tighten up the cable behind the monitor or disconnect the cables and reconnect. You can try another monitor to see whether the mother board and the cable works. Some settings in BIOS may be changed to use on-board video card (the one embeded on the mother board, which is connected on the ports out of the card slots) on your computer so make sure it is using the graphic card that is connected to the monitor. For keyboard, if may be mechanic issue on port or keys or cables if you will not see anything wrong about the keyboard. You can try to use another USB port if it is an USB keyboard or use a USB/PS2 converter if the PS2 keyboard port is not working. If it is a PS2 keyboard, you can check whether the pins are bent and reconnect it. Sometimes that helps. If it is a wireless keyboard, then you will need to fix the monitor and then maybe fix the driver and stuff. You can remove all objects beneath the keys by putting it upside down and shake it or use a blower.
Jan 05, 2011 | Computers & Internet
The keyboard completely stopped working. Unable to type at all...any suggestions? I have disconnected and reconnected the keyboard and restarted the computer.
Turn off the computer, disconnect and reconnect the keyboard, restart your computer. If that does not work, try a different keyboard. If that still does not work than try a usb keyboard instead of a ps/2 keyboard or vice-vers. Good luck and let me know how it goes.
Aug 29, 2010 | Compaq Keyboard
When i try to type on my computer the keys arnt working and they are all messed up wen i try to tyre on it how do i fix that?
The options you have to fix your keyboard problems are:
  • try to re install the drivers for the keyboard
  • if that doest work try using a different keyboard
Cheers!!!
Aug 10, 2010 | Microsoft Windows XP Media Center Edition...
I;ve got a hole in the bottom of my Sevelor Colorado, is there any way to fix it? other than going to someone who can vulcanise the hole.
Depending on the material type, a standard bike tyre tube rewpair kit may work very well! Just follow the instructions int he repair kit and see how you go. At any rate you are not going to cause any more damage than what is already there and there is a good chance the bike tyre tube repair kit will repair the hole (assuming it is not too large of course)
Mar 30, 2010 | Sevylor 48 in Inflatable River Tube
My laptop goes crazy, the keyboard selects random things when i type, windows open and close, stuff goes sidways when i garb windows, and stuff like that this happens when i touch my laptop, just when i...
Hello my friend,this is probably virus or keyboard hardware problem.Update your antivirus and make full scan.If this still doesnt fix your problem go to device manager(Right-click My Computer then select Properties,select the Hardware tab,click the Device Manager button) for windows xp or click Start -> in the "Start Search" box type "Dev" (without pressing enter); wait for a list to show up and click Device Manager for windows vista.Next go to Keyboards right click all the keyboard you see and press unistall
Feb 06, 2010 | Dell Latitude D520 Notebook
Wireless keyboard wont work!
Once the batteries are replaced, you need to "reconnect" your devices. Under the keyboard, there's a "Connect" button. Press it, then press the "Connect" button on the receiver that connects to your computer. That should get it going again.
Aug 26, 2009 | Computers & Internet
Frozen laptop
hmm try to reconnect the ribbon cable to you keyboard and pointer but both is bad. it is probably a broken MOBO or motherboard
no worth fixing. if that data worries you then find a computer that can read that harddrive and use that one instead.
Nov 29, 2008 | Computers & Internet
Mx3200 keyboard stoped typing
Unplug the USB (or PS/2) plug for a couple of seconds and reconnect them. That worked for me when this happened on my older Logitech keyboard.
Jul 05, 2008 | Logitech Cordless Desktop MX3200 Laser...
Logitech Cordless Desktop MX3200 Laser Keyboard Mouse Logo
63 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
