Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I have a mits wd-52525 i got it from my neighbor, he said it needs a new screen,but the outside looks fine, i hear glass when i move it, someone said the mirrors are broke.could there be anything else, and how and where can i get the mirrors
  • 68 Answers
The mirror is a single unit and can be purchased from mitsubishi however you will probably have some scratches in the optics eye and this will show in your picture
Posted on Feb 03, 2009
Blue screen and steady green status light.
mitsubishi will rebuild the chasis for $200 with a 6 month warranty
mits.parts 1-800-553-7278
fax 1-706-654-4299
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Wd-52525 can no longer connect with any input deviced, and is fuzzy in the middle of the screen.
I would "reset" the entire tv (like when you first got it) and make sure all input devices are ASSIGNED correctly and each of those has a physical connection that is good. Can you access "setup" OK?? If OK, there is a known problem with the "input board" on some Mits...not an easy or cheap repair.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I bought A 65" Mits and had it two days approx. 2hrs. of run time
check the lamp. it sounds like it failed. you will probably see the broken glass inside the lamp housing
Jan 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP WD 52525 has small green lines on the screen
do the lines go from top to bottom, and are they about 1 inch apart? or do they move diagonally across the screen?
Dec 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Can't get power to the screen
the chassis needs to be repaired. check out www.tv-techs.com
Dec 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Replacement Caps for Power board WD-52525
You can check out www.tritronicsinc.com just look for correct values VOLTAGE, VALUE, TEMP 100C or call 800-638-3328
Dec 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Black Screen with White Randomized Pixels
Bad FMT (Formatter) circuit board. No longer available for purchase from Mitsubishi.
The electrical chassis will need to be sent to Mitsubishi for rebuild.
Wait time: 4-8 weeks
Cost (including labor to uninstall it and reinstall it: $800 +)
Nov 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Removing front screen.
Good Day;
You say you want to find LCD panel? On a WD- 52525 MIT's. Why do you want remove panel? What Brand & model do you have??
Sep 30, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
71 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
