Question about Epson RX620 All-In-One InkJet Photo Printer
RX620 Error Message
After replacing a couple of ink cartridges, I got an error message on the printer display, "Service Required, Parts insider your printer are at the end of their service life" and the printer was locked up. I went on-line to Epson.com and use the trouble shooting procedures which led me to call Technical Support. Technical Support was of no help, I got a foreign speaking woman who kept repeating for me to go to the WEB site www.epson.com/loyality, whic I tried but it did not appear to be on the internet. I then researched RX620 Printer problems and found one, which I tried. To clear the error message and reset the printer - Hold down the STOP and the B&W Start buttons while powering on the printer. This cleared the error message and reset the printer, I'm now back up and running
  • 15 more comments
  • Anonymous Dec 21, 2007
    I just wanted to tell you that the suggestion of holding down the B&W StartButton and the Start Button, while powering up, cleared the stupid "parts in your printer have reached the end of their useful life message".
    THANKS THANKS THANKS !!!!
  • eileenalana Feb 13, 2008
    Although my RX620 is working perfectly well - this message came up and I contacted Epson. They suggested I buy a new printer from them for £79.99. When I looked up the same printer it was on sale from Amazon for £49!!
    Thanks to Georgy's solution, I am now using my trusty RX620 without any error message. Thanks a lot.
  • Mattak Feb 16, 2008
    This reset worked for me. I suppose it was just a counter by the now infamous Epson Ink cartridge team as a way to force people into buying more product or services. Luckily for me the service center is 1,500 miles away so I did a little digging with Google. I am not happy at all with Epson and do not plan on buying another product from them. They are an ink company not a printer company.
  • Anonymous Feb 26, 2008
    Just a quick note to say the cancel b&w & start up buttons sequence worked for me too. Thanks for info.
  • Andy L Mar 01, 2008
    I had exactly the same problem 12 months ago and got told by Epson to take it too my local repair center where I was charged £60 for a "service" Have have just had the same message on my printer today and tried your fix, the printer now works perfectly - thanks very much for saving me 60 quid!
    Does anybody know roughly when the waste ink pads will actually need replacing based on the fact that this service message has now appeared twice only 12 months apart.
    Andy L
  • Anonymous Mar 24, 2008
    I have the same printer and the same problem, however holding down the Start & B /W buttoms does not fix the problem. I different error message shows up. Any ideas?
  • cleverbuggr Jun 29, 2008
    Thanks to georgy's that my exactly the same problem existed and is now reset OK. I could not help but notice however that someone a little further down the page did not carry out the proceedure as instructed and instead of pressing together (simultaneously)-STOP and B&W pressed START and B&W henceforth it did not do what Georgy instructed. I hope all of you don't mind me noticing the error. Sincere Thanks ( the good advice saved me money no question about that!!!) **** the oil firing tech.
  • angie_meakin Jul 07, 2008
    wear is the stop and baw buttons please
  • Anonymous Aug 08, 2008
    I had same problem until I followed Georgy's advice on resetting printer.  Back in business.  Thanks. Dominic
  • darymave Aug 31, 2008
    Have had the exact same problem,I have sent a snotty email to epson,our machine is just three years old with very moderate usage.
    Thanks to Georgy we are up and running again.
    Thanks Georgy
    Regards Dave M.
  • Anonymous Nov 30, 2008
    ok I have the same problem. The ink pad needs replacing. No one seems to know how to do this. I am confident with the right instructions i could do this myself. I have not even had this printer 2 and a 1/2 years when this message occured. I know I can reset the counter however I would like to know how to replace the ink pad. If anyone has instruction that would be so great! Thanks for all the other great info.
    Stephanie
  • Anonymous Dec 04, 2008
    Same error came up.Your solution worked.Pressed blk/wht button & stop button whilst powering up. Brilliant.Thanks!
  • Anonymous Jan 22, 2009
    I had the same problem. This advice was awesome!
  • Anonymous Mar 14, 2009
    Thanks Georgy, it worked, you're a lie saver.
  • Anonymous Apr 13, 2009
    this worked perfectly, thank you!!
  • plafferty39 Apr 15, 2009
    Printer err occured see documentaion. holding the buttons down did not fix it
  • Anonymous Apr 29, 2009
    Dear Gregory,
    I had the same problem with my Epson rx620 on the error service required. I just happened to find your Fixya, held down the stop
    and black button at same time and it worked.
    THANK YOU THANK YOU!!!!!!!!!!!!!! I also talked to epson support
    and I was going to have to drive 50 miles to get help.
    Shelley
  • 3 Answers
This message comes up after about 40000 registers on a use counter. I posted what I did on the Epson RX620 forum. Look it up. Basically I bought a repair manual on the net for about $10.00 I used this to take the RX620 apart down to the waste ink catch pads which I removed cleaned dried and replaced. It was a long job the first time and you need the manual in order to figure out how to do it. My pads were only about 1/3 used but I live in a dry climate. So punch those override buttons and keep going. You might put a plastic sheet or pan under the printer to catch the waste ink when it actually does leak out.
Posted on Jan 18, 2009
Rx620 thank for you !! error critical spok reset
Posted on May 10, 2008
Has anyone tried simply opening the small 'hatch' held by a single screw found on the back, cartridge side, of the RX620? Through here you can see the corner of the ink pad tray - why not press some blotting paper onto this to absorb the excess waste ink before resetting the counter?
Or am I missing something?!
Posted on Apr 02, 2009
Thank you Gregory it works Epson wanted me to take the printer to a service center.
Posted on May 27, 2010
Thats cause loyality is spell loyalty and you still want to clean out those pads pal.
Posted on Aug 08, 2007
Please follow the steps below to resolve your issue.
  1. Turn off the printer.
  2. Lift the scanner cover.
  3. Toggle the transportation lock five times.
  4. Make sure that it is in the unlocked position.
  5. Turn on the printer, and the error should be cleared.
Posted on Oct 30, 2009
  • Pier Filippo Jan 28, 2012
    you guys are great!!! tried all of the above, and especially the toggling advice, now printer seems back to normal, I also sprayed compressed air all over before restarting, printer, a bit messy but finally the error message is gone...to bad I had just bought a new HP printer thinking this one had died on me...all in all it seems resetting has cost me a full batch of ink cartridges, but if it keeps the printer going so be it!!! Thanks from Milano, Italy, Filippo acquafil@mac.com
And it's still working in May, 2010. I was getting tired of living with the "service" warning and it is nice to have it gone! Lee
Thanks Georgy
Regards Darymave
Posted on Aug 31, 2008
Had the very same problem and this fix worked perfectly. Gerogy, "Thank You" you saved me time and also the cost of bringing it in for repair!
Perfect!
Posted on Jul 30, 2008
Hold down the 'Stop' AND the 'B&W' button while powering up. This seems to clear the error message and restore the printer. Worked for me--dunno how long it will last tho! Regards. gordon
  • Joan Stangler
    Joan Stangler Dec 29, 2013
    does not work for me
I had the same problem yesterday, and I found someone's idea. First, turn off the printer, and hold down 4 buttons at the same time - 'Power,"  'Stop', 'B&W' and 'Colour' buttons . This reset the printer. Now I am trying to clean ink pad my self - will keep posted when I find out how to.
Posted on Dec 12, 2007
The message is, printer error see your documentation and call service if necessary. The Epson tech group seems to have no solution. Every thing on this PHOTO RX500 is ok.
Posted on Dec 11, 2007
Message "Service required. Parts inside your
You'll probably find that that the print head is worn out (according to Epson) and it needs to be replaced. It's cheaper to buy a new printer.
Mar 13, 2011 | Epson Stylus Photo RX700 All-In-One InkJet...
Changing ink reservor on Epson rx620
Are you often to used refilled cartridge? That's possible your waste tank has been fulled. Hold down the 'Stop' AND the 'B&W' button while powering up. This seems to clear the error message and restore the printer. Worked for me--dunno how long it will last tho!
Please rate me SOLVED.
Regards.
Nov 20, 2007 | Epson RX620 All-In-One InkJet Photo...
Brought c5180 two 1/2 years ago. starting using product 8 months ago, printed maybe 500 pages. replace ink when needed. now printer say i need to replace cyan ink which i did twice. brought it in for...
Complete the steps below in the order presented to resolve the problem. It might not be necessary to complete all of the steps.
NOTE: The printer will not operate unless all six ink cartridges are installed. Also, HP cannot guarantee the quality of refilled or remanufactured ink cartridges. Step one: Reset the printer CAUTION: Do NOT perform any other type of reset on the printer before the ink initialization process has been completed.
  1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
  2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
  3. Check the printer for the error message. If the error message still displays, go to the next step.
Step two: Clean the cartridge contacts
  1. Lift the top cover. Figure 1: Lifting the top cover c00372271.gif
  2. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch and then lift the latch. Figure 2: Unlatching the cartridge c00372272.gif 1 - Black cartridge 2 - Color cartridges
  3. Remove the cartridge indicated in the error message. Figure 3: Removing the cartridge c00372273.gif
  4. Gather the following cleaning materials:
    • Distilled, filtered, or bottled water. Do not use tap water, alcohol, or platen cleaners.
    • Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.
  5. Lightly moisten the swab or cloth and squeeze out the excess moisture.
  6. Holding the cartridge by its handle, wipe the copper contacts. Figure 4: Wiping the contacts c00372274.gif 1 - Copper contacts
  7. Replace the cartridge and then close the latch and the printer top cover.
  8. Check the printer for the error message. If the error message still displays, go to the next step.
    NOTE: The printer may take up to 15 seconds to clear the error and recognize the cartridge after closing the cover.
Step three: Replace the cartridge If the error message still displays, replace the indicated cartridge with a new cartridge.
Or Please let me know what is the exact error message you are getting.
Mar 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Epsom Rx620 states use originals for ink cartridges
Try to hold down both 'stop' and 'B&W' button when you press the 'on' button to start the printer machine. This should erase the error message and let you print.
Regards.
Gordon
Sep 25, 2008 | Epson RX620 All-In-One InkJet Photo...
Service repair printer
I had this problem also. What i did was hold down the 'stop' and the 'B&W' buttons while powering up. this erased the error message and now I am up and running fine again.
Aug 24, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
Service required error
Try unplugging it for an hour first.
Thanks,
Lee
Jun 18, 2008 | Epson Stylus Pro 4800 Color Photo Printer...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Rx620 stylus printer
Where are you located? US or UK? if you are in US go to this link so that it will give you the information for that error message
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Please read the FAQ then fill forms so that you can Download a utility for it
If helpful, pls dont forget to rate solution. Thanks!!
Apr 22, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
On printer screen
When turning power on, hold down STOP and B&W buttons together and this should fix error.
Oct 07, 2007 | Epson RX620 All-In-One InkJet Photo...
Epson RX620 All-In-One InkJet Photo Printer Logo
6,320 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
