Question about Brother IntelliFAX 2800 Laser Fax
I need a transmision verification report. from my fax number; 516 358 7643 registered arbay ,john Faxed to; 732 981 0928 this fax number dated; August, 21. 2002 MY ADRESS ; 139 JERICHO TURNPIKE, FLORAL PARK . NY 11001
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my understanding a "transmission verification report" is generated by the sending Fax machine (if enabled). This would have to be initially set in the Menu settings/configuration under the SEND or REPORT or PREFERENCES feature. Additionally, you may want to correct the DAY/DATE/TIME setting since the date sent would show as "August, 21. 2002". Further, you may want to verify that your Fax Number is correctly entered as the FAX identity.
Procedures are better explained in the users manual here.
Good luck and thank you for using FixYa.
Posted on Jan 31, 2009
    Genius:
  • 2,035 Answers
Connect the fax line to a phone and check if there is dial tone , if yes then connect line to fax machine and then set the machine to
  1. Try setting the Compatibility to BASIC.
    1. Press Menu/Set key on the control panel.
    2. Press the up or down navigation key until MISCELLANEOUS appears and press Menu/Set.
    3. Press the up or down navigation key until COMPATIBILITY appears and press Menu/Set.
    4. Press the up or down navigation key to select BASIC.
    5. Press Menu/Set.
    Then try to send a to a friend..and shesk if he gettingthe fax
    1. Press Stop/Exit.
    President:
  • 1,990 Answers
Welcome to Fixya!
Please Wait. I am Locating your Solution.
Hi could you tell me how to print the report for sending please to keep as proof to a number it was sent
Customizing the Transmission Verification Report You can use the Transmission Report as proof that you sent a fax. This report lists the time and date of transmission and whether the transmission was successful (OK). If you select On or On+Image, the report will print for every fax you send. If you send a lot of faxes to the same place, you may need more than the job numbers to know which faxes you must send again. Selecting On+Image or Off+Image will print a section of the fax's first page on the report to help you remember. NOTE:When the Verification Report is turned Off or Off+Image, the Report will only print if there is a transmission error, with NG in the RESULT column. 1 Press Menu/Set, 2, 4, 1. 2 Press ? or ? to select Off+Image, On, On+Image or Off. Press Menu/Set. 3 Press Stop/Exit.
Jul 21, 2011 | Brother MFC-620CN All-In-One InkJet...
HOW TO PRINT FAX CONFIRMATIN PAGE MFC440CN
To print fax send confirmation report:
You can use the Transmission Verification Report as proof that you sent a fax. This
(OK). If you choose On or On+Image, the report will print for every fax you send.
Choosing On+Image or Off+Image will print a section of the fax's first page on the report
When the Transmission Verification Report is turned Off or Off+Image, the Report will
Apr 12, 2011 | Brother MultiFunction Center MFC-440CN...
Brother IntelliFax-2820 Plain Paper Laser Fax does not automatically print a transmission report each time we send a fax. Is there a way to automatically have that happen. We can't find it.
You need to set up the Transmission Verification Report and Journal Period in the menu table.
-OR-
Press Menu/Set, 2, 4, 2.
Note
is a transmission error, with ERROR in the
RESULT column.
2 Press ? or ? to select On, On+Image,
Off or Off+Image.
Press Menu/Set.
3 Press Stop/Exit.
Printing reports
1.XMIT Report
2.Journal Period
Nov 15, 2010 | Brother IntelliFax-2820 Laser Fax
Fax will not print the right report
You must to reset this one at first/ Then to try a litl to switch on/ If it one will not be no well? make it off/ Then//press the buttom Programm and to find the menu date and make some changes
Mar 14, 2010 | Brother IntelliFAX 560 Plain Paper Fax
Intellifax 770 print transmission verification report for multipl
You can print an activity report by pressing FUNCTION, 7, 2, START. That will give you the last 30 faxes sent and received, It will only show that you dialed though, it will not be a true verification report. In case you need it, you can download the manual for your fax here:
http://pdf.textfiles.com/manuals/FAXMACHINES/Brother%20IntelliFAX%20770%20Home-Office%20Fax%20Machine.pdf
Dec 05, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
How do I get a faxed printed report of all letters faxed from a specific date?
You can only print out a JOURNAL or activity sheet that shows the last 50 numbers sent to or received from.
Oct 15, 2009 | Samsung SF-560 Plain Paper Laser Fax
I need to get a copy of a document that I faxed.
No, the JOURNALS will only tell you the fax number it was sent to.
Feb 13, 2009 | HP LaserJet 3330 All-In-One Printer
Need a copy of faxed document to be included on printed verificat
print out a copy of the help page this should give you all the options and what keys to press to give you the option that you want
Jan 16, 2009 | Brother IntelliFax-2820 Laser Fax
Not connecting to fax out
Do you have a DSL or other digital phone line?
Jul 10, 2008 | Brother IntelliFax-2820 Laser Fax
Brother fax machine
You should be able to catch it on the journal if you print one out.
Jun 12, 2008 | Brother FAX 930 All-In-One Thermal Printer
Brother IntelliFAX 2800 Laser Fax Logo
19 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
