Question about Pioneer (1186836) System
My remote is not working.. only half of the keys
Hi, I have this Home Theater system but only half of the keys in my remote control is working. I already went to pioneer service center in out location, they tried the remote in their end and every keys is working, I wonder whats wrong?? Thanks..
  • baju abad Jul 31, 2007
    hi thanks for your reply, would you advise me to bring the remote along with the head unit to check?? or should I get a new remote instead. I was there when they tested it in other home theater units and every key is working..
  • baju abad Aug 08, 2007
    hi MakikiChris, you know what actually happened, I was tired of going back to the service center and just let the component sit and when I was about to bring it to the service center today (what a coincidence) it just started to work.. I'm gonna observe this and will post you for updates, thanks a lot... :-)
    Novelist:
    Scholar:
  • 84 Answers
Did you drop off your remote for service, or did you physically see them demonstrate proper operation? If you were not there when it was tested, you're unable to attest that it did work for them. However, if you were there and saw it perform properly, you may have damaged it on your way home. Typical remotes work via IR, and IR breakdowns are not particular as to what key will be defective..in other words, it works or it doesn't. However, some major high-end components use RF remotes, and may be subject to all types of interference that modern homes emit.
Posted on Jul 31, 2007
  • 1 more comment
  • V. Chris Suehiro
    V. Chris Suehiro Jul 31, 2007
    I would definately return to the service ctr. again, and bring along the player so that they're able to test YOUR remote through YOUR system. Generally, remotes are pretty robust, and it would take quite a jolt to crack a board. I have a feeling that your IC board within the player itself may be in need of replacement, in which case, I would think it would be under warranty.....after all..ya can't break the ic board unless ya broke something a wee bit more obvious on the outside too....good luck.
  • V. Chris Suehiro
    V. Chris Suehiro Aug 08, 2007
    Hi baju....I wanted to follow up with you and check if your remote/service center issue has been resolved.?.? If there were any charges, I'd like to know of them as well for my future reference. I hope you have reached a resolution, but please update your post if you have any further questions or issues....Thank You
  • V. Chris Suehiro
    Okay baju...thank you for your follow up, and please update if/when there are changes and/or certain resolution. (sounds like the remote was just mad at you) Hmmm, after typing that, maybe your batteries were low, and when left to sit and rest, now has temporary ample energy to operate......hmmmm Nah...That just makes too much sense, let's stick with "the remote was just mad at you"....okay my friend, I look forward to your future update.
SOURCE:
Hi my remote control doesn`t work, we just change the battery and it did not change. all our system is going thru this remote and now nothing works. remote model rcvit-27
First open your mobile phone camera and point to the LED on the top of your remote and when you press any key if the remote power works you can see a blink light on your phone screen if not check the power of your remote good luck
Sep 05, 2011 | Bose Lifestyle 20 System
I had a IRC 550 starchoice remote and it ran my panasonic home theater system but quit working so I purchased a IRC 551 and couldn't get it to run the audio Shaw suggested i try a ir 600 remote and I found...
SEARCHING FOR YOUR CODE=irc 551
If your home entertainment device does not respond to
the Star Choice IRC 551 IR and Star Choice URC 551 IR/
UHF Remote Controls after trying all of the codes listed
for your brand, or if your brand is not listed at all, try
searching for your code.
For example, to search for a code for your TV:
1. Turn on your TV.
7. To search for the codes of your other devices,
repeat steps 1 through 5, but substitute the
appropriate key (e.g., AUX, DVD, AUD, or SAT)
for the device you are searching for.
Jan 29, 2011 | Panasonic Home Theater System System
HI THERE I GOT THE PHILLIPS MICRO DVD HOME THEATER MCD388 unfortunatelyTHE LAST SUMMER WENT TO THE UK AND THE USA AND I CANT PLAY ANY OF THE DVDs can anyone help me with a region code????
1. Ensure there is No Disc in the player
2.Press Remote Control (RC) "SYSTEM" key to enter DVD system setup menu;
3.Press RC "direction "key to hightlight the forth item "PREFERENCE PAGE" (not
entering the sub-item );
4.Press RC numeric key sequentially 811502(entery code,no display on TV);
5.Press RC "down direction" or "up direction" key to change REGION CODE,"0" is
all code.
6.Press RC "OK" key to confirm.
7.Press RC "SYSTEM" key to exit DVD system setup menu
Jan 15, 2011 | Philips MCD288/37 DVD Micro Theater System...
Would like unlock code to play regions 1-6 on my panasonic sc-bt207
Please follow the steps : To change the player region code
1. Be sure players drive is empty (nodISC)
2. Enter following key sequence using remote control:
Enter, 6, >=10, <<, 00F2, Audio, 8, * requested region code here (1-8) *, Subtitle, 1
3. Player will reset and requested region code will be set.
- For example to set region code to 3 press: "Enter, 6, >=10, <<, 00F2, Audio, 8, 3, Subtitle, 1"
To set the player to RCE proof region free
Enter, 6, >=10, <<, 00F2, Audio, 8, 1, Subtitle, 4
3. Player will reset and set to "region-free" and "RCE-free" mode
To restore players factory region code
Enter, 6, >=10, <<, 00F2, Audio, 8, 9, Subtitle, 1
3. Player will reset and set to factory region code
Regards, Jay__g6
Dec 11, 2010 | Panasonic SC-BT200 Home Theater Systems....
No remote control
If you are looking for remote control of Genesis G-506 theater system then click Remote.com to buy substitute remote control for $30 as original remote control is no longer available.
Let me know if I missed any thing.
Thanks.
Jul 28, 2010 | Genesis G-506 Theater System
Region 1 DVDs will not play on my recently purchased panasonic blu ray. is there any input code to allow play
Regards, Jay__okp9
Dec 01, 2009 | Panasonic SC-BT200 Home Theater Systems....
The remote isn't working at all with the home theater system. The tv is also a samsung i disconnected everything and reconnected but the problem still exist. any ideas of what i should do?
First of all, what is the remote control that you're using?
If you are using the remote control that came with the HTS unit and it's not working with the home theater, press the DVD RECEIVER button. That should work.
If not try this. Take out the batteries on the remote control and hold down the POWER button (without the batteries!!).
Hope this helps!
Jun 26, 2009 | Samsung HT-TZ312 Theater System
Ican't get my remote control working
hi ost,
well this remote wont wok with this model number of home theater.
the remote that comes with this is of model no: RM-ADU002
u will have to purchase this.
u can purchase it from the following:
http://www.findremotes.com/remote-controls-1/remote-controls-adu002-control-14749.htm
http://www.espares.co.uk/parts/remote-controls/sony/rmadu002/p/1090/763/0/1040449
good luck! and please rate this solution.
Jan 18, 2009 | Sony DAV-DZ100 System
Remote control
1) Try new batteries
2) Get a replacement remote from Philips
3) If original not available, get a universal remote for home theater systems
Oct 20, 2007 | Philips HTS3450 System
Pioneer (1186836) System Logo
418 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ben Armstrong
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
