Question about Zanussi IZ12 Front Load Washer
Zanussi FLE 1015W
Machine starts for a few seconds then the start/pause button flashes and the machine stops. Any ideas??? Thanks
  • Pauline Chatburn Aug 02, 2007
    Im sorry I didnt rate the solution, the reason being that when I went back to the site and it said I had a solution to my problem there was nothing there. So I didnt actually have a solution to read. So I still have the problem.
    Thanks.
  • Anonymous Mar 26, 2014
    started to pause during wash cycle, start button flashes red
Any solution yet ? same problem here Zanussi IZ12
Posted on Jul 30, 2007
SOURCE:
Zanussi 1116
I would call an appliance tech. This definately is an advanced issue required by a tech to diagnose.
May 06, 2012 | Washing Machines
Hi! I have a Zanussi IZ12 washing machine. After I turn it on, the door will not open and start/pause button just flashes. (I can select program and press start/pause, it just beeps, but the machine do...
I've had the same problem. I removed the top lit and found some pressure transmitter and a pressure switch. I suspect that the pressure transmitter is use for measuring the waterlevel in the machine. I think the membrane loses its flexibility over the years.
I pulled of the hose from the transmitter and blowed and sucked a few times on the transmitter. After doing this the machine washes without a problem since then.
Hope it helps for you.
Jul 14, 2010 | Zanussi IZ12 Front Load Washer
Machine won't restart after reset, 'start/pause' button flashing.
When you put it to drain/spin does the pump make any attempt to drain,if not it could be that there is something stuck in the pump,needs draining manually.Another thing to try is to find the fault code.If you hold down the 2 buttons on the far right of panel then press on/off button till lights start chasing,then release the 2 buttons on right hand side.Now the first function button by the on/off button you will need to press until the light above the button reaches the 9th or 10th position this will give you a read out in the display.
E10 = low water press.
E20 = pump or filter.
E30 = press. switch or heater faults.
E40 = Door swich.
E50 = motor.
Some of these numbers can vary there are more but those are the most common.After checking codes switch off machine then back on twice to reset.
Hope this helps.
Jan 26, 2010 | Zanussi FLE1416W Front Load Washer
Door light always on/start button flashing- machine not working
i have just fitted a new pump to my Zanussi FLE 1416w washer, the main power light is on but the start button does not light up.
Can you help.
Oct 14, 2009 | Zanussi FLE1416W Front Load Washer
Hi, my machine starts for a few seconds then stops and pause button wont stop flashing, have tried turning off and on but same thig keeps happenig, please help x
if it is a HE kind of machine it is supposed to stop and start a bunch of times at the beginning of the cleaning cycle. Did you wait for a while to see if it ends up running the cleaning cycle?
the new machines are kind of freaky the way they work.
later
Apr 09, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Zanussi 1000XC Washing Machine - Pause Light Flashing
The ECU is failed. unplug for 40 minutes to try to reset it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Washing Machines
Zanussi FJ1254 W - Machine does not fill
Yes if you remove your soap draw and take a look inside you will see that there is all residue built on the top part of the internal draw, Either you can jet wash it off or replace the soap draw,,
this should solve your problem.. if that does not work then one of your solinoid valves at the back is faulty...
Dec 01, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi IZ12 Pumps, then Pause LED is flashing.
hi i had the same fault, the machine would go onto pause after a couple of seconds.. after nearly a full strip down of the machine and checking the obvious i found there was carbon dust on the pcb which was causing tracking (the circuit board at the top of the machine). The pcb looked like it was burnt out, but after a quick dust down to remove the carbon and refitted back into the machine it worked fine. HTH
Jul 30, 2007 | Zanussi IZ12 Front Load Washer
Zanussi IZ12 Front Load Washer Logo
551 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
