Question about PPI PCX-2125 Car Audio Amplifier
Cant figure out where to connect the remote wire to
I just got two of these. One is a ppi pcx 2125 and the other is a ppi pcx 480.
  • Sonia Zubia
    Sonia Zubia Dec 18, 2015
    Thanks u help me out with one . If your awnserrs ty
    New Friend:
It goes in between the two speaker outputs, notice there are five wire terminals ( left - , left + , remote , right + , right - ) i have fond this rather akward myself, as it is usually next to the power and ground cables
Posted on Feb 04, 2009
    President:
  • 1,990 Answers
The Remote Wire Connects to the Blue Wire From the Stereo If you have an Aftermarket Stereo. This will control the Amps Power with the Ignition Start and Accessory Positions.
Posted on Jan 31, 2009
  • Travis Humphries
    Travis Humphries Jan 31, 2009
    Please Rate My Response! Thanks!
I HAVE A PPI PCX 2200 THAT IS NOT GETTING ANY POWER AT ALL I CHECKED ALL FUSES STILL NO POWER
1.verify connections...Make sure your ground wire is grounded to a location on the body where you will sand the paint away to make good metal to metal contact. 2.with a volt meter check for battery voltage on the red wire of the amp as close to the amp as possible.verify that your remote or trigger wire from the radio (blue wire) id connected to the remote terminal of the amp.. turn on key switch, turn on radio and see if amp powers up. if no then verify 12 vdc at the remote terminal of amp, very 12vdc at red power wire. verify ground. If all this is good i would suspect you have a faulty amp.
May 05, 2011 | PPI PCX-480 Car Audio Amplifier
I have a PPI PCX-2400 and want to power two TREO subs that handle 2500 watts apiece. What is the best way to ire the PPI to these subs so that I get as much power from the amp to the subs without causing...
That would depend on the impedance (resistance) of the subs. Your best bet would be to use the full power of the amp to one channel (i.e. bridged) instead of to two separate channels (i.e. stereo). Two 4 ohm subs wired in parallel would present a 2 ohm load to the amp, which should allow you to get all 1600w out of it.
This explains series vs parallel quite well:
http://www.termpro.com/articles/spkrz.html
Mar 03, 2011 | PPI PCX-2400 Car Audio Amplifier
Need to know how to bridge the channels on the amp is it left pos and right neg or opposite
If you look at the speaker hookup it will say bridged and have a line going to the two that you should use....If it doesnt then it might be an amp that you cant bridge
Oct 02, 2010 | PPI PCX-280 Car Audio Amplifier
I got a ppi d1000/1 amp cant get any sound out of it?
Make sure your remote wire is hooked up in the right spot, also check your rca plugs and consider replacing them, check all fuses to make sure their not blown, a loose or not good ground wire or power supply wire will also cause this problem. If a power wire has a cut in it, that will also cause fuses to blow, as well as with a ground wire cut, ur amp will not be properly grounded.
Sep 26, 2010 | PPI PrecisionPower D1000/1 Subwoofer Mono...
My ppi 2200 power light flash's on and off
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Feb 03, 2010 | PPI PCX-2200 Car Audio Amplifier
How to bridge a ppi amp
The PCX-1500 is a single channel amp, it can't be bridged. I realize that it has two sets of speaker outputs but electrically it only has one output. The connections are actually paralleled inside. Electrically it only has one output. Physically there are just two sets of terminals to allow more convenient connection of 2 speakers. You can use either one or both. If you use both you need to take into account that they're parallel to each other. Connect 4 ohms to each set the amp sees 2 ohms. Like wise with 2 ohms to each set, the amp sees 1 ohm.
Hope this helps.
Mar 29, 2009 | PPI PCX-1500 Car Audio Amplifier
RODEK AMP PROTECTION
have you checked your speaker connections and any other connection for shorts or multiple ground loops. cause that will definately cause the protection mode.
Mar 03, 2009 | PPI PCX-280 Car Audio Amplifier
PPI AMPLIFIER NO SOUND PSX-280
make sure the remote wire from the deck is in the amp but move your ground wire to a new solid metal location you may have to scrape the paint surface where the ground is going to go but it will stop protect mode and run properly (make sure to bolt it down by its self no other wires just the ground from amp) also make sure the ground wire is bigger than the power wire
hope this helped
Problem in ppi pcx-2400
Check the amplifiers fuses. Some amps have speaker fuses that leave the LED on if blown. Check for continuity on the voice coils of both subs. Check for 12 volts on the remote turn on line from your receiver. If all of the above are good, the amp is probably toast.
Jul 15, 2007 | PPI PCX-2200 Car Audio Amplifier
PPI PCX-2125 Car Audio Amplifier Logo
284 people viewed this question
Top PPI Car Audio & Video Experts
hoyzee1
Are you a PPI Car Audio and Video Expert? Answer questions, earn points and help others
