I need to show the intersection of the following equations on the calculator. y = 3x and y = 5(x-10)
Just open the Y= editor, and type in the two functions, one on each line. Make sure that the = signs remain highlighted when you move cursor on some other lines (Y3, or Y4).
Then open the Window utility and set Xmin=0
After graphs are drawn you can use the CALC utility to find the Intersection of the two lines.
SOURCE: how to graph linear equation in two variables
I am not quite sure what you are asking...
(1) if asking for graphing y= -2/3x+2, then press [diamond] [F1: Y=] type in .2/3x +2, see graph by [diamond][graph]
(2) if asking for graphing y= -2/3x+a, where a=3x, then first archive a=3x in Home screen by [home], type 3x [sto] a, then go back to y= menu, and type -2/3x+a in Y1
(3) if asking for graphing an equation that is dependent on 2 variables at the same time, use x-y-z axis (aka, change mode to graphing 3-D by [mode]graph [5:3D]) then enter desired equation in y= menu using Z function in terms of x and y aka z(x,y)= ...)
SOURCE: graphing
The first solution will allow you to watch your
calculator graph two equations simultaneously rather than finishing one
before graphing the next; it won't solve the problem of having the
calculator unselect one equation when you select a second. To fix
that problem, try the following:
In order to select additional graphs, the Transformation Graphing App
will need to be uninstalled from the TI-83 Plus Family and TI-84 Plus
Family. Uninstalling the App does not erase it from the calculator, it
disables it from interfering with the normal graphing modes. Below are
the steps to successfully uninstall the App.
The illustration and solution are courtesy of
Jesse Phillips, who cites
this
page from the Texas Instruments
support site
- doug garfinkel, Children's Day School
SOURCE: My calculator will only graph one graph at a time.
This is simple... Back up all RAM, (press second+, then 2, then 1, press enter to back up something if backed up it will have a star by it) Then clear your RAM (pull out your batteries while the calc is still on or press second+, then 7, then 1)
Hope this helps!
SOURCE: ti 84 plus problem
The calculator only displays from -10 to 10 on the x and y axes, and both of your lines are outside of that range. However, it is easy to change that.
1. Hit the gray "WINDOW" button that is directly under the screen
2. Change "Xmax" to 150
3. Change "Ymax" to 200
Remember to change both of those values back to 10 when you are done with this problem!
Here's how to graph it:
1. Hit the "Y=" button
2. Enter your first equation after Y1, and your second equation after Y2
3. Look over both the equations to make sure you typed them correctly
4. Hit the "GRAPH" button
5. If you don't see the intersection you will need to adjust Xmax and Ymax again
6. Hit Hit "2ND" and the "TRACE" to bring up the "CALC" menu
7. Scroll down to "intersect" and hit enter
8. Hit enter 3 times (You use the first and second curve options when you have more than 2 lines)
9. It should display the coordinates at the bottom
10. I got (76, 142.1) for the intersection
Thanks for asking this question! I used to do this a much harder way, but while I was calculating the answer to your question I hit a wrong button and accidentally found this method!
