Question about Teac (DW224E/S) CD-RW/DVD-ROM (Combo) Burner
Teac DW-224E CD-rw/ DVD rom in Toshiba Satellite Pro M15-405
I was downloading CDs to iTunes and the disk drive quite reading. Now it will not read anything and the light on the drawer is always yellow. I went to My Computer and the drive shows as the "D" drive but does not show anything in it when a cd or dvd is in the drive. Is there a way to test this drive other than putting a disk in the tray?
    Novelist:
  • 198 Answers
Hello konagold, Yes there may be some ways to test it. Let's try the following. When you open your laptop, open the cd rom's tray and check to see where the lens mechanism is positioned. Normally it should be near the main central motor. Try to turn off the laptop, but leave the tray opened. When the laptop is turned off, use one one hand to move the lens assembly away from the main motor. Move it to the middle of the distance from the center to the edge. Carefull not to touch the lens when you do this. Now place a bootable cd (like the ones that come with your operating system or anything else you can find) and start the laptop back again and instruct it to boot from the cd-rom. It should make it try to boot from there. If this fails, the cd-rom is indeed damaged and most likely will need to be replaced. You may try to clean the lens assembly but I can't be sure this will help, based on your problem. Please run these instructions first, then reply to me in order to see what's next to do. Bogdan
Posted on Jul 31, 2007
SOURCE:
I have a TEAK DW-224E-A CD-RW/DVD-ROM combo drive in a toshiba A25-S207 Laptop computer. Everything used to work, now the DVD won't work but the CD stilll works fine. Any suggestions or solutions?
Hello sanhill665, try "Updating the Drivers"
Go to this "Website," and "Fill-in" or {Choose} any information needed to get the "Drivers" you need. Than you'll be able to "Download the Drivers."
!Attention: The 'Part No." is a "letter off. ie: "Yours= [R] Theirs = [V]. "I will say. its 'safe' to try!"
"Please let me know if you 'need' further assistance, or the 'solution' helped?
"By posting a 'Comment" or 'Rating' the solution.
Thank you; your 'response' is important to me!"
paul7of9
Click here: http://www.teac.co.jp/dspd/index.html
Mar 02, 2011 | Teac Dw 224E-R Disk Drive CD-RW / DVD-ROM...
Problem is that my DVD combo TEAC-DW-224E-A reads cds but not DVD kindly help
Download VLC (google it) for free, see if that plays the dvd. Most likely your player has an issue, VLC plays ANYTHING (pretty much!) without issue.
If that doesnt work then you'll have a problem with the actual drive.
Feb 11, 2011 | Teac (DW-224E) DVD Drive
Completely dead, will not even try to read the disk. Device Manager says its working correctly, and the driver is correct.
Hello.
First try a disk drive cleaner.
If still a problem, the only solution is to replace the drive.
Hope this helps.
Oct 15, 2010 | Teac Dw 224E-R Disk Drive CD-RW / DVD-ROM...
Teac Dw 224E-R WONT BURN ON A DVD - Is it a DVD Writer?
hi no its only a CD RW, and not a CD/DVD-RW its just a CD writer and a dvd( rom )..read only memory which means it only reads dvd's but does not write them...hope this helps
Jun 14, 2010 | Teac Dw 224E-R Disk Drive CD-RW / DVD-ROM...
No audio on toshiba sat pro
MAY BE THE ONE YOU TRANSFER THE HARDWARES TO DOES NOT HAVE SOUND DRIVER YOU NEED TO LOAD SOUND CARD DRIVER ON IT BEFOR YOU CAN HEAR SOUND.check the below site and see if it can solve the problem
http://www.driverfiles.net/Notebooks/Toshiba/Satellite-Pro-6100/download/page,sh,31303,221,19,.html
Dec 24, 2008 | Teac DW 28E CD-RW/DVD-ROM Burner
Teac dw-224e-a dvd rom will not read dvd +r -rw data
Here's the newest driver for your burner. Go to Control Panel, then Device Manager, then click on the + symbol next to disk drives, and double click on the TEAC device. Click the Driver tab and press Update Driver, then choose the 'Let me find the driver' option, and navigate to the folder where you unzipped the file to. Double click and Install. Reboot.
http://www.softwaredriverdownload.com/download/driver/DW224E.ZIP
For burning, I would recommend Nero, Alcohol 120% or ImgBurn.
Good luck and Season's Greetings!
Chris (ziraffa)
Nov 13, 2008 | Teac (DW-224E) DVD Drive
Teac DW-224E-c - cannot burn DVD's
The answer is what you profess. The drive can burn CD's, read CD's and also read DVD's. Everytime I try and burn a DVD I have an unrecognized drive and the properties always show no disk: The drive burns CD's ie;music, but cannot burn DVD it can only read DVD like you say!
Sep 10, 2007 | Teac DW 28E CD-RW/DVD-ROM Burner
Open Questions:
See all Teac (DW224E/S) CD-RW/DVD-ROM (Combo) Burner Questions
Teac (DW224E/S) CD-RW/DVD-ROM (Combo) Burner Logo
145 people viewed this question
Top Teac Computers & Internet Experts
Ekse
k24674
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
