Question about Indesit W 123 Front Load Washer
Fuse problem on indesit 1300 washing machine
Hi, the fuse on my machine went and evertime i put a new one in it blows straight away too. Any help would be magic - cheers
    Genius:
  • 2,985 Answers
This is a sure sign of a short in a major component Motor or Pump. It is possible that a spade connector has come off of something- so with the power disconnected a visual inspection may - repeat may reveal such a connector- the High vibration of the spin can cause electronic components to fail and burn out. A visual inspection first and check for burn and scorching marks. Then it will be engineer time - at least you can tell him what has gone wrong- perhaps maybe
Posted on Jul 30, 2007
My Siemens Extraclasse 1300 Washer/dryer just stopped as though no power. Fuse is ok.
check door inter lock by putting mech on leave 4 five mins go and try to open door imeditlaty if if opens straight away its the inter lock
Feb 22, 2015 | Siemens Washing Machines
Thers no power to my washing machine.changed the fuse and theresstill no power.what do i do ? thank you emma
Hi emma... Unplug the machine from it's current outlet and use a heavy duty extension cord to plug it into another outlet that you know works [plug a blow dryer in to check it].
If the washing machine works then you know the problem is in the outlet or the wiring to the outlet. IF the washing machine still doesn't work you know the problem is within the washing machine itself. Possibly the lid switch or a fuse within the machine. J.
Aug 02, 2011 | Indesit Washing Machines
Location of fuse in fisher& paykel washing machine
Fuse is tiny round redish brown thing bout the diameter of a pen.non replaceable in later models,Grey boards & Brown boards.they are soldered in & in most cases other damage is caused when they blow,I don't know why they even bother putting one in.
Earlier models such as Blue,Yellow & Green boards have a glass fuse you can replace but like i said before the minute you put a new one in & turn it on they blow straight away because there is other damage caused when it blew the first time,but some times it actually works.
May 22, 2010 | Fisher and Paykel Washing Machines
Indesit washer wil 103
Check your water inlet valves. Seems like the valves have went away. Also check the computer board and inline fuse to make sure everything is correct. Inlet valve are located behind the supply line hoses. Please rate. Thank you
Feb 14, 2009 | Indesit W 123 Front Load Washer
Indesit washing machine WIXE127 switches off main fuse
Have you added anything else that is drawing juice on the same breaker?
If so try turning those off.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Jan 31, 2009 | Indesit WA 125 Front Load Washer
Indesit washing machine wdg1295w blowing fuse
Proberly carbon brushes in motor,Can be supplied if req.grandadfixer
Oct 11, 2008 | Indesit W 123 Front Load Washer
New washing machine servis M6725,dispenser drawer will not open.only got it yesterday
i have just used my servis washing machine 1300 aa and just went to put a new load in and there is no power to the machine at all i have checked the fuse and the plug wiring what else can i dp please advise???????
Jul 29, 2008 | Washing Machines
Fuse keeps blowing out in my maytag washing machine
the power surge probably shorted out something in the main wire harness or fried your motor. remove the screws from the control panel and look for any wires that are discolored, charred or disconnected. in the event you do't find it there trace the wiring thru the cabinet looking for the same thing. if you don't find that, replace the motor
Nov 16, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Blowing Fuses....
it may be the water inlet valve has expired? use an ohmmeter to check when powered down
May 18, 2007 | Zanussi F1245W Front Load Washer
Indesit W 123 Front Load Washer Logo
102 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
