Question about Maxtor Hard Drive
I can't farmat my hard drive
I'm formating the hard drive but when is doing , this mesaje apears
trying to recover allocation unit
please I need help
  • EricDaniels
    EricDaniels May 11, 2010
    Is this an external hard drive and in what boot environment are you trying to format from? DOS, Linux, Windows? You can not format a drive that is in use of core files for the current system running.
    Problem Solver:
  • 12 Answers
If you have a windows xp cd installer or win98 cd installer, install it, let it format your drive.
Posted on Feb 02, 2009
How to recover lost data's in my computer after i formatted my hard drive
There are applications available that have varying degrees of success in recovering data from formatted hard drives. The bigger problem is whether or not you have written anything else to the drive since formatting it. These applications can recover the partition table and the File Allocation Table if things are pretty much pristine. What ever you do, don't put anything else on the drive you formatted. This will only corrupt things further and make recovery harder. If the data is crucial data, you may be better served getting a data recovery service to do it for you, although this can be very expensive and has no guarantee of success.
This link will take you a listing of many options for recovery. I cannot vouch for any of them.
Google
Sep 05, 2016 | Hard Computers & Internet
Tip
How to fix No Bootable Media Error Message
FAT (File Allocation Table) is one of the most widely used file systems used now-a-days with various versions of Windows operating systems and memory cards. Every logical partition contains a FAT that consists of file allocation information and the information of free allocation units that need to be assigned to files. Although the FAT file system is reliable, corruption still occurs due to various reasons. In such situations of FAT corruption, your system becomes unbootable, resulting into inaccessibility of data saved in FAT based hard drive. To access the data after FAT file system damage, an easy way is to restore the data from an updated backup. But, with inaccessibility of data backup or backup falling short to restore the required data, an ideal option left is to use an advanced FAT Data Recoveryapplication that can recover the lost data.
To illustrate the above scenario, consider a practical case the below error message pops up when you attempt to boot your system:
“No Bootable Media”
As the above error message appears at the time of booting the system, you wont be able to access the data saved in the hard drive.
Cause:
The above error message because the FAT file system has been corrupted. Few main causes for file system damage are improper system shutdown, human errors, and virus attack.
Resolution:
To isolate the above error message and to access the data after the above error message appears, you will need to follow the below steps:
Run CHKDSK utility to repair the FAT file system. If the problem persists, format the hard drive.
While the latter resolution resolves the above error message completely, it also deletes the data saved on your hard drive. In such cases, if the backup is not available, then you can only recover your formatted data by using an advanced third-party FAT Data Recovery software.
A FAT Partition Recovery utility thoroughly scans a FAT based hard drive and recovers almost all data, even after formatting. The data recovery utility can be downloaded from the Internet.
Stellar Phoenix Windows Data Recovery is an efficient FAT Partition Recovery tool that recover lost, deleted, and formatted data from both FAT (FAT12, FAT16, FAT32, VFAT) and NTFS (NTFS, and NTFS5 ) based hard drives. The detailed help manual attached with the tool allows even a new user to perform recovery easily without any technical knowledge. It supports Windows 7, Vista, XP, 2003, and 2000.
on Jun 30, 2010 | Computers & Internet
Reformatting HCS725032VLA380
Is it your primary hard drive ?
Reformat hard drive to NTFS Windows XP allows you to easily format the hard drives with its inbuilt utility. Formatting the hard drive would forever delete all the files stored on it. There are two ways in which you can format the hard disk partition - from My Computer and from DOS. You cannot have a NTFS partition with allocation unit s above 4096.
Click on "Start," and then click on "My Computer." Right-click on the disk partition to format and then click on "Format." Click on the "File System" drop down box and select "NTFS." Click on the "Allocation unit " drop down box and select an allocation . It is recommended that you select the "Default allocation " option. Click on the "Start" button. b> Format the Partition from DOS b> Click on "Start," and then click on "Run." Type "cmd" in the 'Run' dialog box and then press "Enter." Type "format drive_letter: /FS:NTFS" at the command prompt and then press "Enter." Replace the 'drive_letter' here with the letter of the drive that you want to format (for example, format e: /FS:NTFS). For help on advanced formatting options, type "format/?'more" at the command prompt and then press "Enter." Keep pressing "Enter" as you read on. Hope it helps
Jan 24, 2013 | Hitachi CinemaStar 7K500 HCS725032VLA380...
Format HD fails on armada 1592DMT
The safe bet is to go into the bios and choose "load Bios defaults" then restart. If your HD fails on the format command, it is probably bad.
Mar 20, 2009 | Compaq Armada 1592DMT Notebook
USB Drive - Write Protected
Hi.
While formatting chose default allocation unit.
If this doesnt helps the tell me.
Regards
Faraz
Oct 16, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston USB 2g DT101
Hi
Are you trying to format it in ntfs version or fat 32.
Check the allocation unit.
Make it default dont put any value.
Try this and tell me if it helps.
Regards
Faraz
Oct 15, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Undelete/unformat a Mac formatted external hard drive.
The theory to unformat a Mac hard disk is, when you format a Mac HFS+/HFSX Volume or format a external hard disk, the data are not really wiped. Format process just marked your Mac hard disk as available to reuse, no matter it is quick format or complete format. So if you put if you fill in a mount of new data to your hard drive, then the formatted data are overwritten, your will permanently lose your formatted data.
Follow this guide to unformat your mac hard drive or formatted external hard drive on mac.
Jul 26, 2008 | Computers & Internet
How to recover formatted data
Formatting a drive only resets the FAT (File Allocation Table), where it stores the information about the files on the drive. You need to get a utility that can read the data directly from the drive, bypassing the allocation tables. There are many available, most are not free.
Try going to TuCows.com, they are sure to have the utility you need. Be sure not to write any new files to the drive and you should have no problem in recovering your data. Search for: Formatted Drive Recovery
Mar 20, 2008 | Computers & Internet
Metal gear enclosure 3.5 box 2
Sounds like you haven't formatted the external Hard-Drive.
You need to allocate a file-system to the free space on your hard drive. You can do that in Disk Management and use the format option. You can select from two file system formats: FAT32 and NTFS. I would recommend NTFS because it is a journalling file system (recovers quickly in case of a crash).
Oct 20, 2007 | Galaxy External Enclosure - Metal Gear Box...
Maxtor Hard Drive Logo
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
