I took the back panel off to check it out and i seen that 8 capacitors were bad on one of the circuit boards. Would that cause the problems that i am having?
SOURCE: Power but no picture or sound
Hi, could be the main board but first you need to look for swollen capacitors on the power supply, here is the process:
, the solution to fixing your TV is most likely the power supply, if you are wanting to repair it yourself and can solder, it is most likely going to need (2) 1200 or 2200mf at 35volts electrolitic Capacitors, or you can replace the whole power supply. The back is held on with a few screws around the back and edge and then you need to pop the edges loose starting at the bottom side corners. once the back is removed the power supply is mounted inside a rectangle metal shield , remove the screws around it and the little ones going into the jack/input section (using a short philips there), there is a wire running from a circuit board to the USB input be careful not to pull on it, unplug its wire from the CBA. then look at the power supply (top center board) the cylinder looking capacitors that are bad will be bulged on top, usually there are two 2200mfd at 10 or 25volts. changing them should get it working. A repair shop will charge you around $250 for this job, FYI
hope this helps
thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
SOURCE: Bad backlight inverter on 42" RCA LCD
Does the backllght go out after a few seconds? Could still be a lamp or something else on the inverter boards. You could try used inverter boards from the same set with other problems (broken screen), Or a complete working backlight from another set but very delicate operation to swap the LCD display from one panel to another.
SOURCE: PLASMA TV PROBLEM
The problem with this set, is defective YSUS board, to avoid future same problem, you must change the following boards: YSUS, ZSUS & Control.
Verify with LG if your serial Number is included within
lots production that were recalled by this design defect
Testimonial: "I'll try to contact LG dealers. Very hank you sir"
SOURCE: We have Samsung LCD model LN26A450C1D, which is
The tv Tuner board is dead,that the board,where the brocasting incomming signal cable connected into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Testimonial: "Thanks for quick response! I will try. "
