Question about Sanyo STW0923H2 Air Conditioner Heat Pump
Sanyo ptac problem
Doesn't turn off unless unplug it.
    Problem Solver:
  • 18 Answers
Dont know what model number  it is but sounds like a bad control board,  or a bad switch    If you give the model# and serial# ill be glad to help you more  :)
Posted on Oct 14, 2007
This question for Sanyo PTAC HVAC for Hotel-Motel style unit.Hi, We have Sanyo PTAC STW 1223C2P,in real cold night, heat stripe in not working proper, on left side blow cold air, in center throw hot a
If you are saying this happens on a really cold night, the assumption is that on milder nights, it seems to work adequately.....If that's the case, there is a possibility that it is marginally sized in capacity to heat the space in which it is installed. If it has a "fresh air" damper setting, make sure that is closed completely, because that is air directly from outside the structure that is being brought in through the blower and adds more load to the space and makes the discharge air feel colder.
Dec 08, 2014 | Dryers
GE PTAC 5500 series cooling and then blowing hot
Cooling gas is missing. Call some AC service in near to fill it, ask more of them for price. Do not switch it on until you solve this to prevent higher damage.
Aug 28, 2014 | Heating & Cooling
Sanyo PTAC model STB0823H1 elec. heating element
Try 1st link for Support Request, 2nd link enter zip code
http://shop.panasonic.com/hvac/how-to-buy/distributor-locator.dot
Dec 12, 2013 | GE Zoneline Deluxe Series Cooling &...
Sanyo DP 47460
check for any bulging capacitor at the power supply board and check for leak or shorted FET transistor and regulator.
Aug 30, 2012 | Televison & Video
My Sanyo PTAC heather stop working. ac working, fan working .
It could be the relay or the strip heat....
To figure out what is wrong you will need to check if power is getting to the strip heat or not...should have 220-240 V across the two legs going to the heat strip...when the heat should be on.
heatman101
May 25, 2011 | Sanyo STW0923H2 Air Conditioner Heat Pump
Sanyo television doesn't turn off either by using the remote or by turning it off at the tv.All other fuctions work using the remote or directly on the set.Even using the sleep timer doesn't turn...
Unplug the set and hold the power button for 30 seconds. Plug it back in and see if that fixes it. If it doesn't then it sounds like there is a problem on the board underneath the power button. Something isn't allowing the circuit to be cut.
May 05, 2011 | Televison & Video
TV turns it self off.
your ic reg str (some )need replace and check the cap big at side .
Jan 05, 2008 | Sanyo HT28745 28" TV
Sanyo STW0923H2 Air Conditioner Heat Pump Logo
179 people viewed this question
Top Sanyo Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Dennis Boxerman
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
