Question about Kenmore 24 in. 15689 Built-in Dishwasher
No hot water during wash cycle
Hot water tank is o.k.!
  • 117 Answers
If the dishwasher is connected at the sink and you get hot water there, you have a faulty heater or safety thermostat.
http://tclaundryrepair.com/dishwasher
Posted on Mar 02, 2009
No hot water coming in during the wash cycle.
Hello Stephen Foster - Based on the symptoms you are describing, typically, the unit could possibly have a faulty timer, temperature sensor or water valve. Confirm that the holes are properly connected. Try resetting the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. However, if the issue persists, it is always a good idea to have a service tech properly diagnose your appliance.
Apr 15, 2013 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
Washer only washes with hot water
consult your owner manual about you are unsure about if the machine is acting anormally
Some machines, is running hot water during cycles, other cold water during cycles.
God bless you
Jul 18, 2012 | Washing Machines
Changing washing machine heating elemant
washers dont have heating elements, they use hot water from the hot water tank, most likely clogged screen at either end of the hot water hose, replace or clean screen(s) check for screen at water valve, bad,weak or burned solenoid on water valve, replace valve, reason wash cycle is long----- water restriction during fill and rinse cycles they are controlled by the water level switch
Jul 09, 2012 | Washing Machines
Hot water seems to not enter tub during washing cycle. all connections are correct and the hot water hose is hot up to the back of the washer, im baffled ? does the unit start with cold water on the first...
They start with hot or warm ,what/ever the setting and rinse with cold water. Check the temperature adjustment and the cycle it's on as some do different things on different cycles.
Dec 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
The water isn't getting hot
If the water to your kitchen tap is above 120 to around 145 your machine is getting hot water. If not your need to adjust your hot water heater.
It is fine to open the DW door during the wash cycle. The unit will hold the wash cycle. Open the door during the start of the wash cycle (not rinse) and see it the dispenser door is open. If not it could be the timer is not sending the proper signal to the dispenser on when to open. This would be a timer issue and you would want to replace the timer. I doubt that this is it but it is possible.
Hope this helps.
Mar 22, 2010 | GE Dishwashers
When my machine goes through the rinse cycle it will only fill with hot water. It fills with warm water during the wash cycle.
Your hoses are reversed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 30, 2009 | Washing Machines
AM14 tank heaters--when are they energized?
How hot is the wash temp?It should be 150-165 degrees.The model is an am14 not an am15?I'm hobart tech and repair these units weekly.Let ne know.
Feb 26, 2009 | Hobart AM14-253 Free-standing Dishwasher
Dishes don't get clean. soap still on inside of door. . . water coming up to fill line and hot enough and dishwasher drains after cycle, spray arms are clear. . . help!
Water from the wash arms must be able to reach the detergent cup during the wash. It sounds as though the machine may be over-loaded during the wash and water does not cause the detergent to mix with the wash tank water. Try washing a cycle with nothing in the machine. Does the detergent still stick to the door?
If no, the machine is overloaded. Wash fewer items or smaller items so spray will contact detergent.
If yes, you have probably lost wash pressure. Clean all screens and jets.
Hope this helps,
Kermit
Aug 13, 2008 | Dishwashers
Kenmore 24 in. 15689 Built-in Dishwasher Logo
66 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
