Question about HP Scanjet 3770 Flatbed Scanner
Scanner 3770 hardware problem
I am using my scanner about 2 years, it is working properly. But after I changed the scanner location from one place to another, it is not working. When I am trying to scan an image from scanning wizard, the carriage is just little come forward and go back , after that the below messege is appreaing. MSG: The current picture could not be copied. To copy this picture, click "Try again" To stop copying, click "Cancel". Many times I clicked Try Again but the above message appears again and again. I also tryed to scan from Microsoft office documet scanning but the below message is appearing. The scan failed because of a scanner hardware error. Feeder may be jammed. Please correct the error and scan again. I will appreciate your help in this regard. Thanks
  • 1 more comment
  • Sayed Ratib Hussaini
    Sayed Ratib Hussaini Jul 30, 2007
    no there is no any knob.
  • irenie2 Jun 09, 2008
    HP all in one 1410v. Error message: Hardware error, may be jammed feeder.
  • falesq Mar 24, 2009
    I get this error message: ''The scan failed because of a scanner hardware error. Feeder may be jammed. Please correct the error and scan again.'' Solve this.
    Brigadier General:
  • 6,966 Answers
Hi, it is possible that your scanner has a transport locking lever or knob underneath which might have been keeping the carriage locked in place. Try checking and release if there is one. Hope this works for you. Pls post again how things turn up. Good luck and kind regards.
Posted on Jul 30, 2007
6ya staff
SOURCE:
Instal drivers and software for windows 7
http://www.driverslib.com/Printer-Scanner/HP/Scanjet-3770/49294.html
Oct 09, 2011 | HP Scanjet 3770 Flatbed Scanner
I have a hp scanjet 3770 & PC with windows 7 64bit, I cannot scan negative from that scanner
http://hpanswers.blogspot.com/2010/02/hp-scanjet-scanners-windows-7-drivers.html
Sep 17, 2011 | HP Scanjet 3770 Flatbed Scanner
Scanjet 3770 drivers for windows 7
There isn't a designated driver for windows 7 for this scanner, but I have seen some other people who have the exact same problem as you, and they were told to download the Vista drivers instead and it worked fine, so feel free to give it a shot. You can download the driver here: http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=391319&lang=en&cc=us&taskId=135&prodTypeId=15179&prodSeriesId=391317
And if the installer fails to begin, use Application Compatibility mode by right-clicking the install file, then click "properties" then click the tab "Compatibility", Check the box for "Run this Program..." and select from the drop down menu "Windows XP (Service Pack 2).
Hope this helps!
Remember to give me 4 Thumbs Up for Helping out the Community :)
~~Dayminner
Jun 03, 2011 | HP Scanjet 3770 Flatbed Scanner
Artec e+48u scanner problem
go to control panel, under device manager uninstall imaging device (scanner) and click scan for hardware changes, if found new hardware occurred click next and choose no, not this time tab / choose install from the list specific location option tab / choose don't search i will choose the driver to install / click show compatible hardware tabs and select scanner type appeared.
Mar 09, 2010 | Artec e+48u Flatbed Scanner
I need instructions for an hp scanjet 3770
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&taskId=120&prodTypeId=15179&prodSeriesId=391317
There u go, there is all that is about that scanner on HPs supporter site
Good luck to you!
If you find my answer helpfull, dont forget to vote
Dec 17, 2008 | HP Scanjet 3770 Flatbed Scanner
Scanjet 3770 installation
now how can i installation thqt driver
Jul 15, 2008 | HP Scanjet 3770 Flatbed Scanner
Scaner is not working of hp3055 color laserjet printer
Step 1:. Check Hardware Driver Installed Properly
- My Computer-Properties-Hardware-Device Manager
- If Yellow mark in printer and Scanner field, the Printer
driver not installed properly.
- So reinstall Printer Software
Step 2: If Scanner Option only not working,
- Go to Scanner Settings(Start-Programs.....)
- Choose Correct Scanner Name.
Or
- Press the Scanner button in hp 3055
- If Hardware driver was installed correctly, its automatically
deduct on your PC
Jul 02, 2008 | HP Color LaserJet 2600n Printer
Problem regarding installing HP scanjet 3770
I am using HP scanjet 3770 for the last 1 year. I was runing it on windows XP, but now i have installed Vista on my pc and itis not installing due to the drivers. Kindly help me in getting the software installed on windows vista. From which site i will get the drivers to download...
The specific ero: Parsing error in file C:\Program file\HP\Digital Imaging\bin\hpqscloc\1033.xml
Please Help (Ayúdame)
Apr 22, 2008 | HP Scanjet 3770 Flatbed Scanner
Color Alignment HP ScanJet IIcx Flatbed
u change the cable of your scanner and connect to new cable and install all the drivers and software properly your scanner working properly
Mar 18, 2008 | HP ScanJet IIcx Flatbed Scanner
HP Scanjet 3770 Flatbed Scanner Logo
953 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
