Question about Kenwood DV-505 Multi-disc DVD Player
DVD disappeared in DVD Player after viewing movie
Watched two movies this afternoon on Kenwood DVD Player 505 Multi Disc (5) . All was great, till we went to remove the disc, opened the player & it's nowhere to be found! If the movie played fine, so obviously was properly inserted - where did it go? When we examined the inside a little, we saw it couldn't fall down - and figure it must have gone up?? But how? And how do we go about finding it?
Any help would be greatly appreciated!
Get the dummy cd disc, put a blue tac on it. Insert it. Then after few seconds, eject it. Your dvd disc should stick with it when they came out. It worked for me and hope it will work for you.
Posted on Feb 14, 2009
I download free movies to hard drive, than I burn them, and my dvd player says no playback available or a big red x shows on tv screen, what am I doing wrong/
You probably have burnt the dvd disc using a video format that is not compatible with your player.
A lot of DVD players will not play .AVI or DIVx files that are commonly downloaded.
Your DVD player manual should list the formats it will play.
Convert downloaded movies to a compatible format before burning to disc.
There are several conversion programmes available via the web - at a cost of approx $50.00.
AVS4U works ok.
Oct 13, 2009 | Kenwood DV-6050 Multi-disc DVD Player
I have a kenwood dvd player
Are you sure it´s the laser the problem?
Because sometimes the motor disc spindle are the guilty of the failure of the dvd.Good luck
Jun 12, 2009 | Kenwood DV-505 Multi-disc DVD Player
Always says bad disc
Try to clean the DVD lens using a lens cleaner.
Feb 16, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Disk error with Kenwood DV-605 multi-disc DVD player
Try the following
when the error is on the screen, press the number 1 key on the remote, this should take you to the fist chapter of your DVD no matter which region it is
Miguel
Jan 03, 2008 | Kenwood DV-605 Multi-disc DVD Player
Dont know what to do
Probably not much help. but the 1st thing I would do is check to see if the disc is even turning...put it in with label straight up, then when it fails, eject...odds are severely against the disc being oriented the same way if it spins, so if it hasn't moved, the main drive motor is bound up or dead. Either way, return it.
Dec 29, 2007 | Coby DVD-233 DVD Player
Dvd video player
Your DVD player is having a problem reading the disc. This is what is accounting for the pausing and the slow loading times...especially if it plays other movies without hitches. Even if the DVD is cleaned, some scratching on the disc will prevent it from being viewed properly. Blockbuster shoudl give you another disc to try of the same movie if you ask. Also, you can try getting a cleaner for your DVD player to remove dust and help it read discs better.
Dec 26, 2007 | Toshiba SD-3980 DVD Player
DVD player
Clean the pickup using a commercial cleaner disc.That's the only quick,cheap fix.
Dec 12, 2007 | Toshiba MW20FM1 20 in. Combo
Trying to view a movie
Locate the input or source button one the face of the Tv and see if you can change the source that way and let me know..
Bill
Nov 25, 2007 | Sony DVP-NS325 Multi-disc DVD Player
Disc Error
try to clean the lens with 100% cotton.or maybe you have defective flex ribbon wire! or laser eye!
Sep 23, 2007 | Durabrand DVD-1002 DVD Player
Kenwood DVR - 7000
Hi, same thing happened to my one of the above. I bought a cheap dvd player to view movies and run the audio through the kenwood to use the surround speakers.
Feb 21, 2007 | Kenwood DVR-505 DVD Player
Kenwood DV-505 Multi-disc DVD Player Logo
102 people viewed this question
Top Kenwood Televison & Video Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Kenwood Televison and Video Expert? Answer questions, earn points and help others
