Question about Refrigerators
Unbalanced fridge Having trouble balancing the fridge (westinghouse virtuoso). Tilts towards the back and I cant really drop the front down to level it. It is about 5 years old (stainless steel with freezer above fridge, and quite large)
  • zorb62 Feb 01, 2009
    Mnay thanks for your help
    Problem Solver:
  • 18 Answers
You need to first remove the bottom kick plate. you will notice two 3/8 bolt heads on each side. These are to raise and lower the rollers in the front and rear of the unit. There are also 2 legs in the front that can screw in. These are usually lowered after the unit is installed to keep it from moving.
Posted on Jan 31, 2009
Why does it always become unbalanced in spin cycle?
how confident are you to get inside it? Check the balance springs and shock absorbers.
Normally it is two simple things.
First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
Dec 26, 2015 | Washing Machines
Westinghouse virtuoso the alarm keeps going off fridge not cooling freezer is not freezing. Help!
Try adding refrigerant or freon. The Alarm just warns you that it's not cooling or freezing and your food is thawing out. Check the fan if you hear the fan running it should be the coolant needs to be put in it. Or it could possibly be both.
Apr 26, 2017 | Angelo Brothers Westinghouse (r) Savona ES...
I have a samsung dryer front loading. it seems that the dryer is not balanced as it wobbles while drying. today the noise got worse, until i pulled the drum toward me then it went back to just wobbling. is...
It is nice these days as many washers and dryers are self leveling with just a little effort. The rear legs have the self leveling setup but if you dryer is old the adjusters maybe rusted. Try this... look at the front from a few steps back you will see the front two legs, they will probably be even. Unplug the dryer and slightly pull away from the wall, not to far as the dryer hose may disconnect. Tilt the dryer forward pivoting on the front legs (just raise the back a couple inches off the floor) and then let it drop. if the legs are self leveling this act may have leveled things. If the legs are rusted a little more aggression is needed maybe with the help of a parts solvent spray (56 or WD-40 etc.)
If your dryer is older then you have adjustable legs that need to be rotated one at a time until the dryer is level.
Feb 02, 2011 | Dryers
Our fisher and pykel always off balance( wont spin at all because of it)disconnect unbalance sensor?
Try to raise your back feet on the washer, so that it tilts forword away from the unbalanced censer
but not to much,or it will bang on the front. Hope this helps
Oct 18, 2010 | Fisher and Paykel WA37T26G Top Load Washer
How do i adjust the level on a westinghouse frost free 422 fridge the right side is higher than the left and won't fit in the space properly
ans / you can adjust the front both l & R / but the back / if floor is not level you will have to use shims . to raise . then adjust front . most important is the door's must have a good balance to each other . or the seal may not be proper ..
Jan 16, 2010 | Refrigerators
Westinghouse fridge freezer alarms keep going off
Try a different web site, where are the solutions on this one????? Great site..... not
Dec 30, 2009 | Freezers
Westinghouse Virtuoso Fridge - Circuit Diagram
It won't be the defrost timer, unusual, it will be the defrost element inside the freezer section behind the back panel or a shorted defrost klixon.
Mar 30, 2008 | Refrigerators
Refrigerators Logo
261 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
