Question about Pioneer Dolby Digital 5.1, Pro Logic II and DTS Surround Home Theater System, HTP-2700 System
Cd stalls ,won't play unless I advance cd.
I have cleaned the laser head & have adjusted the height as well , is there a specific height for the laser in order for it to read the cd ? or is this just a common problem with this model ? I have had this problem for quite some time and has just gotten worst recently.
    Problem Solver:
  • 4 Answers
Hallo.IneedPioner CT-WM62R manual(shematik)
Posted on Jan 31, 2009
My dvd player wont read my movies
Hello
Check its Sled Motor. Sled motor is one which get spins the disc we insert into it. If it is faulty, discs won't spin, and the set won't read anu discs, and will show no-disc display. OK.
Dec 12, 2011 | Sanyo DVW-7000 DVD Player/VCR
My unit DVD/ VCR the DVD when I put in DVD it won't play it just flashes a blinking DVD how do u fix?
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor. Also in some cases the central motor base can shift and so the distance to the disc can be more resulting in low detection. You can pull up the spindle to come closer.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Thank you for using Fixya
Aug 27, 2011 | Symphonic Televison & Video
I When Insert a clean disk I get a NO DISk ERROR CODE. I leaned the case with a little alcohol with a cotton square.. II blue can air on the lense to blow the dust away. I tried to use the Maxwell disk...
Aug 09, 2011 | Sylvania SDVD7015 7 in Portable DVD Player
Philips mcm9 system won't read any cds. It says "reading" but nothing else happens and even says that when there is no cd in slot, radio & tape are both working and cd player was working...
If the no disc comes even without a disc in the player you must check and see if there is a mechanical fault specially in the loading section that seems to trigger the CD mode to work.
Also check to see the main motor as it will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor. Also in some cases the central motor base can shift and so the distance to the disc can be more resulting in low detection. You can pull up the spindle to come closer.
Jul 29, 2011 | Audio Players & Recorders
Hi i am just wondering why all of a sudden my dvd wont play normal dvds but will play cds and home made dvds please help many thanks karen
Jul 21, 2011 | Audio Players & Recorders
Won't play a disk
Jul 17, 2011 | Car Audio & Video
DVD in player and it will neither play or eject the disk.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board or the drive mechanism
Jul 14, 2011 | Bush Televison & Video
My DVD player won't read, keeps saying disk error
Jul 12, 2011 | Televison & Video
Cd loading on digital display but rejects cd - will not play
Jun 16, 2011 | Clarion Car Audio & Video
Skips when playing cd
In most cases when the CD does not play or is skipping it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
Apr 15, 2011 | Audio Players & Recorders
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
