Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 plus series: heavy duty super capacity won't agitate
Moter is running but no agitation at all. i think the last load was too heavy.
Model # 110.28932790 Stock 28932 Stylemaster No.4217018 Kenmore 90 Plus Series Heavy Duty Super Capacity Plus Quiet Pak Plus top loading washer started out not spinning and now it will not agitate at all. The motor is running but nothing is happening. Where can I find an on line fix it manual if you can't figure it out?
  • Joy Desrosiers Jun 04, 2013
    I thought so also so i tried a small load with one towel and it did the same thing
  • 318 Answers
This is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Posted on Jan 31, 2009
    Problem Solver:
  • 12 Answers
If it doesn't agitate you need new agitater dogs. If you pull out the agitater assembly there's these 4 little hard plastic pieces with ridges. After many uses with heavy loads those ridges wear down and will stop your washer from agitating. Does the washer spin out? If not then you need a motor coupling. For more info and a parts list go here and type in yor model number. Good luck.
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer 90 Series Super Capacity will not agitate or spin.
http://appliancejunk.com/forums/index.php?topic=3437.0
Yes, you have a direct drive coupling problem. Use this video to replace your part.
EZPZ.
Aug 13, 2009 | Kenmore Washing Machines
Doesn't agitate or spin. Motor runs
model number not found. If it is a direst drive model you need to see www.youtube.com/watch?v=WLPGs2UMUJc
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 80 top loading washer that doesn't spin or agitate
Unplug machine, remove water pump and motor, behind the motor is a coupler, take broken parts to your local appliance parts store. Costs 16 bucks, replace the broken parts with new ones, reassemble machine. Never ever do a blanket/comforter in your machine again!!
Mar 31, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
5,086 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
