Question about Jensen GPS
Gps won't turn on
My gps will not turn on. could the problem be the battery? what battery does it use and how do i replace it?
    Sergeant:
    Champion:
  • 373 Answers
Did you try pluggin in the adator and see if it comes on
and if it does not start charging then I would have it checked out at best buy or some other outlet that will.
Posted on Jan 31, 2009
When i plug it in the only thing it does is says callaway on the screen, also unit won;t turn on
It is possible that the replacement battery is defective, especially if it won't charge.
Jan 31, 2015 | Callaway Golf Company uPro Handheld GPS...
My Tom Tom XXL won't turn on when plugged in.
The GPS device runs off the battery ... so, you need to charge the battery (fully, or enough to power the GPS) before you start using it again. For clarity, if the battery is not charged, the GPS will not run when plugged into a power source.
Feb 19, 2013 | Tomtom ONE GPS Receiver
Garmin won't switch off
Open unit disconnect battery and speaker wait 3-4 min Re connect battery while opened .This should reset and clear any faults. ..reassemble
Feb 06, 2013 | Garmin Edge 705 Handheld GPS Receiver
My Garmin nuvi 295W won't turn on at all.?
Did you get the battery reinstalled correctly? The battery and a question mark means there's a battery problem.
Garmin Nuvi Gps
Aug 19, 2012 | Garmin Nuvi 295W 3.5 in. Car GPS Receiver
My sgx is locked up and won't do anything - won't
Remove the battery and the unit will shut down. Wait 1 minute, install battery and the unit should power up and work as normal.
Sep 18, 2011 | SkyGolf SkyCaddie Handheld GPS Unit
Won't power up
Is this the first time you have ever tried to turn it on?
Sometimes the battery drains too much, you need to let it plugged into a charger for a little while - at least 20 mins, then try turning it on again.
May 21, 2011 | Garmin Nuvi 285WT GPS Receiver
Has never charged, even after extended time periods - both with car charger and usb. Any tricks I'm missing. I've tried "ejecting" it but it just goes back to showing computer connection....
Sounds like the internal battery won't hold a charge and needs to be replaced. If you're "handy" you could do this yourself, but it's not for the faint of heart, and replacement batteries are available on the Internet. Here's a video that shows the procedure for disassembling and reassembling it to install the replacement: http://www.youtube.com/watch?v=PwAbKYOgiZg
May 11, 2011 | Garmin nuvi 255W GPS Receiver
My camera automatically turns off and won't turn back on when i use the flash. the only way i can get it to turn on again is by putting the battery back in the charger, this also happens when the...
it would appear the battery is "weak" and needs to be replaced. although testing it with a battery tester may show it is fine. when you turn on the camera you are putting the battery under a load and the voltage may drop too low. quick test would be to test the battery voltage after you take it out of the charger and then again after you have used it to power on the camera. ebay would likely be your most inexpensive source for a replacement battery.
as a side note i suggest you go to the canon website to find out if there is a recall on that particular battery. i realize this is about camera's but my garmin gps battery was recalled (and the gps was about 4 years old) and it was replaced for free.
May 09, 2011 | Canon EOS Rebel XSi Digital Camera
Garmin nivi 200 won,t turn on
The mini-USB jack needs to be either resoldered or replaced. When the jack is loose, you will not be able to charge the internal battery. The jack becomes loose from overuse. The jack needs more mechanical support to the pronted circuit board. I have fixed this problem many times.
- Jim
Aug 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
Pn-20 fails to start
Here's delorme's forum page on reset options and firmware updates if you so choose:
http://forum.delorme.com/viewtopic.php?t=10995
Mar 15, 2009 | DeLorme Earthmate GPS PN-20 for PC, Sun
GPS Logo
175 people viewed this question
Top Jensen GPS Experts
Will Halftowaite
Are you a Jensen GPS Expert? Answer questions, earn points and help others
