Can't find the voltage specs for terk 9330 tower fm antenna
    Problem Solver:
  • 19 Answers
Product Specs: General: Product Type Radio antenna Recommended Use Indoor Width 3 in Depth 16.9 in Height 3.5 in Color Black Localization English Antenna: Wave Band AM, FM / FM: 87.5 - 108 MHz, 540 - 1700 kHz Impedance 75 Ohm Gain Level 42 dB Amplifier Built-in Included Accessories Connector coupler, impedance transformer Connections: Connector Type 1 x FM antenna ¦ 1 x AM antenna Power: Power Device Power adapter - external Manufacturer Warranty: Service & Support 1 year warranty Service & Support Details Limited warranty - 1 yearlet me know how this works out for u
Posted on Jan 31, 2009
How do we set up the tv to pick up air channels with the indoor amplified antenna?
Terk FDTV2A HDTV Indoor Antenna Unboxing Setup Test Part 1
double check your TV is set to the correct input before scanning.
the link above shows installation
press the helpful button
Jan 22, 2016 | Sharp LC52E77UN 52 in TV
How do I improve my reception on a Bos Wave Radio with single CD player
The Bose uses its power cord as an antenna. The cord has to be stretched out (not coiled) to pick up stations. It also helps if it's oriented the right way -- try changing the direction (having the cord running east to west, say, instead of north to south). Moving the radio and the power cord closer to a window can help, too, especially in a commercial building. These structures often have a steel frame which can block radio signals. If all the above fail, your best bet is to buy an indoor FM antenna, which can be as simple as a piece of wire made into a dipole antenna or as fancy as one of the Terk mini-towers with built-in amp. Bose sells one for their radio, though it's kind of expensive for a simple length of wire. You can get the same thing from Radio Shack, but if you do, be sure to pick up their adapter (catalog 278-257) to plug it into the non-standard Bose jack. All together you'll spend half what Bose wants. Move it around like you did the power cord and you should see a big improvement.
Aug 05, 2014 | Bose Wave Radio / Cd With Remote model...
What kind of wire or cable should i use between my receiver and amplified fm antenna?
Your Terk antenna has a round F connector for 75 ohm coax cable. Unless your receiver is really old, it has an F connector for the antennaas well
Feb 16, 2013 | Terk Televison & Video
Where can I order an antenna forthe CD BA 2100 stereo
Hi,you can find it any Electronic Store or even Hardware store..Just ask for " FM antenna Cable " of course this is a passive antenna.
.if you have any reception problem to get FM signals on your location ,than you need to buy" Active FM antenna" with amplifier.....before go to store pls take a look at the rear panel of your stereo to see and decide what kind of FM antenna plug you have it..
if you want to buy these thru ordering you can find thousands available in EBAY web site..
Below are 2 URL as different type..TERK is a successful antenna.
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
http://cgi.ebay.com/Terk-Audiovox-AM-FM-Indoor-Stereo-Antenna-Gamma-Loop-/110716385684?pt=LH_DefaultDomain_0&hash=item19c735f994
http://cgi.ebay.com/New-DTV-HD-FM-Rotating-Indoor-Digital-Antenna-Remote-/230517606660?pt=LH_DefaultDomain_0&hash=item35abeb8904
Jul 23, 2011 | Sharp CD-BA2100 CD Shelf System
Could my Terk XM antenna be bad right out of the blister pack?
Yes, it is possible, but go outside and face the SW and try it that way to make sure. If you have an unplugged or bad antenna, if will usually say "CHECK ANTENNA". Make sure you don't have a chunk of metal, or even your hand over the top of the mini antenna, or you WILL block the signal. Let me know how it works for you. good luck!
Jul 02, 2010 | Terk XM Commander Satellite Radio Receiver
My xm plays extremely loud thru my car stereo.no matter what i set the volume at.it is either off when volume is set to zero or loud at any other setting.changing the output level on the xm receiver does...
Are you playing it directly thru your FM antenna connection, or using the RCA jacks? You have to set the FM modulator level. It is also possible that you have a new FM radio with a type of ALC that will raise the lever regardless, but your regular car radio volume control should work. do not wire this directly to a power amp, as you won't have the control that you need. Good luck, let me know more.
Apr 01, 2010 | Terk XM Commander Satellite Radio Receiver
Need to know how to go cable free. Have TERK digital antenna
Shouldn't do, just connect the antennas into the Belling-Lee TV antenna socket at rear of set, tune channels. If you antenna won't fit, you may need an "F" connector to "Belling-Lee" converter plug. You will need an "Ordinary" Yagi VHF/UHF antenna installed though. Is that what that digital one is?
Feb 14, 2010 | Hitachi 51G500 51" Rear Projection...
I bought a digital converter and a terk fdtv2a antenna. I placed the antenna on my window and I am only able to receive 2 stations, one informerical and one in spanish. Does this antenna just not work for...
You live too far away from the stations transmitters. In this case,you need an outdoor ant. to do the job.(roof top).I live in Orlando area and I get 35+ channels.
Jan 24, 2010 | Terk WF-R Dual Band High Gain Replacement...
Can not get certain radio stations, when you turn yes
Hello, your solution is to simply upgrade the antenna. this is especially true if you are using the wire loop antenna that came with your unit.
Do a search for "Terk FM antenna" on ebay or amazon. They range anywhere from $20 to $100 depending on how strong you need it to be.
You can also check out radio shack or see what your local wal-ly world (walmart) has just remember you want an AMPLIFIED antenna
Hope that helps
Jan 14, 2010 | Technics Audio Players & Recorders
External FM antenna
The fix for the problem is simply go to Radioshack and purchase their part number 278-267 which is an "F" jack to 1/8" Male Plug. The cost is $6.09. This should solve your problem. The 75-Ohm antenna plug can now be screwed or connected to the "F" connector.
Aug 31, 2008 | Bose Wave Music System CD Shelf System
132 people viewed this question
 Grubhead
Grubhead
