Question about Philips Magnavox 27MS343S 27" TV
36 INCH MAGNAVOX TUBE STYLE TV. SHUTS ITSELF OFF
MY TV TURNS ON BUT WITH IN A FEW SECONDS IT SHUTS ITSELF OFF.I CAN TURN IT BACK ON BY PRESSING ANY OF THE BUTTONS ON THE FRON ,VOLUME,CHANNEL..ETC......I HAVE A PICTURE AND SOUND ...BUT THE TV ACTS LIKE ITS TRIPPING A BREAKER OF SORTS...
  • 308 Answers
SOURCE: 36" tube tv. picture fuzzy and out of focus
It sounds like you may have a G1 intermittent short in the picture tube, which unless it is still in warranty would not be worth repairing.
Posted on Jan 03, 2007
tvtek
  • 1284 Answers
SOURCE: TV Volume turns down by itself - Philips 29PT8319 Matchline 27"
Most likely the volume down button on the front of the TV or the switch that it activates is sticking. Should be an easy fix otherwise.
Posted on Feb 05, 2007
  • 1779 Answers
SOURCE: magnavox Mod. # HD 2715 C 202
Your set in in closed caption mode text 1....Go into your menu and un-do the closed caption mode.
Posted on Feb 18, 2008
  • 52 Answers
SOURCE: mAGNAVOX mODEL 27ms3404/17 shuts down
first place to start on this chasss is with a known failure in the horizontal circuit. there is a capacitor 2455 and 2 transistors locations 7461 and 7463 that have caused a wide variety of failures. i would recommend replacing these components before proceeding as they could be the whole of the problem.
Posted on Aug 20, 2008
SOURCE: 36 magnavox tv shuts off by itself
MAGNAVOX TV ONLY. 5-10 SECONDS AFTER TURN ON AUTO TURNS OFF-NO LIGHT STAYS ON-I AM FRUSTRATED BUT IT SEEMS LIKE THE OFF ON SWITCH JUST CLICKS BACK TO OFF-ALSO DOES SAME THING BY REMOTE
Posted on Sep 04, 2010
Magnavox television won't stay on
I know this is going to sound strange but I have something to check. If you have LED lights in your house turn them all off. When they are off turn on your TV and see if your TV stays on. Yes, there could be many problems but this one is cropping up quite a bit. If this does not work then you need to take a look at the power supply board.
Feb 15, 2015 | SNK Magnavox 42MF438B/27 42 in. LCD TV
I have 20MC4306. Recently when you turn it off it turns itself back on. Also when you turn it on shuts off after 2 seconds. Tried putting in a video vhs then press play and wait few seconds and hit...
Sometimes when the TV recives a brodcast signal for a new update to the mainframes firmware, it will have to turn itself on to install/recive the update and aslong as it is connected to a power source it can do this. hope this helped answer your question. Have a good day :)
Jan 03, 2011 | Philips Magnavox 20MC4306 20" TV/VCR/DVD
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
36 inch tube tv - Screen flickers
my problem is don't sound in my mobile LG CE 0168 please help me.
Aug 17, 2009 | Toshiba Televison & Video
Magnavox 19" TV shuts itself off.....won't stay on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jun 04, 2009 | Philips Magnavox 27MS343S 27" TV
Turns off on its own after a few second clicks on and off for about 5 sec. until it turns itself off but the power light is still on
This is point to a fly back issue and a flyback fr this would run you $95 plus labor good luck with your TV
May 23, 2009 | Philips Magnavox MS3652S 36" TV
36" toshiba suddenly turns off and the little red light flashes
Some el.components are loose on tv circuit board.I have removed the back cover,supported tv picture tube 45 deg.against wall.This tv is heavy!One screw on left holds the circuit board to bottom case.Removed and supported this board on few heavy books.Turned tv on and gently probed all the componets on top of the board with plastic drinking straw.In my case transistors Q-830 and Q-421 needed resolder loose joints.These components are mounted on flat aluminium heat sink strips located sligtly left of center of the circuit board.Also blobed bit of silicone into base hole and foot of alu.heat sink to support it.
Apr 15, 2009 | Toshiba 36A50 36" TV
36 tv shuts off after few minutes
have power board checked -- sounds like a short in the transformer
Dec 10, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tv powers on, but turns off after a few min
somone with some sort of tv knowledge told me that sometimes people dont realize t but moisture builds up inside and it needs to be dried back out
Jan 28, 2008 | Televison & Video
Jan 16, 2008 | Philips Magnavox MS3652S 36" TV
Philips Magnavox 27MS343S 27" TV Logo
488 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
