Wireless problem sir i have dell latitude 520 laptop with xp os and i wan't to switch over to ubuntu but when i did so the wireless driver did'nt work further i don't know how to configure it so kindly help please reply me at coolsolid.aditya@gmail.com
  • adityagreat Jan 31, 2009
    thanks a lot sir but i have ubuntu 8.10.....so please give a hand to solve this problem of wireless driver....
  • 4 Answers
I'm Guessing your using Ubuntu 7.04... Due to a bug in the native driver shipped with Ubuntu, the wireless card on this laptop is detected and installed but you cannot find any wireless networks. Here’s how to fix it.
* Let’s disable the native Ubuntu driver. Type this in a terminal:
gksu gedit /etc/modprobe.d/blacklist
and insert at the very end of the file:
# buggy broadcom wireless driver
blacklist bcm43xx
* Next, do this in a terminal:
sudo rmmod bcm43xx
* Now, let’s download and install the windows driver for the wireless card. You have to download it from the Dell support website. Click here to download it.
Or you can use the direct link to the executable:
http://ftp.us.dell.com/network/R140747.EXE
Since it’s a windows self-extracting executable, you need wine to use it:
sudo apt-get install wine
then:
wine <path_to_R140747.EXE>
Replace <path_to_R140747.EXE> with the actual physical path to the file you downloaded from the Dell support website. Follow the instructions and extract the files to a folder of your choice. Alternatively, you could extract the files on a windows machine and copy them over to your ubuntu system.
* Now, let’s install ndiswrapper. We need it to load the windows driver.
sudo aptitude install ndisgtk ndiswrapper-common ndiswrapper-utils-1.9
* Let’s install the windows driver:
sudo ndiswrapper -i <location_of_bcmwl5.inf_file>
Replace <location_of_bcmwl5.inf_file> with the path to the bcmwl5.inf file you extracted earlier.
* Let’s make sure the driver is installed:
sudo ndiswrapper -l
You should get something like this:
bcmwl5 : driver installed
device (14E4:4311) present (alternate driver: bcm43xx)
* Now we need to set up ndiswrapper to load our new driver automatically:
sudo gedit /etc/modules
and add a new line that says:
ndiswrapper
That’s it, restart your laptop. During the restart, the wiFI LED should light up. If it doesn’t, try the Fn + F2 key combination. After the reboot, configure your network settings:
System -> Administration -> Networking
Enable the wireless connection and tinker with the connection settings if you need to. You may have to disable the wired connection because wireless and wired connections may not work simultaneously - your mileage may vary in this regard.
Note:
It seems Network Manager prevents the card from connecting to detected wireless networks. I advise you to remove it if you can detect wireless networks but cannot connect to them. To do this, type the following in a terminal:
sudo apt-get –purge remove network-manager network-manager-gnome
Alternatively, you can open Synaptic and remove these two packages.
* Summary:
1.) Install ndiswrapper
sudo apt-get install ndisgtk ndiswrapper-common ndiswrapper-utils-1.9
2.) Install the windows wireless driver
Remember to replace <location_of_bcmwl5.inf_file> with the actual path to the location of the bcmwl5.inf file
3,) Make sure the card has been detected and installed
ndiswrapper -l
4.) Disable the native ubuntu wireless driver
Insert at the very end of the file:
blacklist bcm43xx
5.) Remove Network Manager if it gives you problems
Reboot
You wireless card should be working flawlessly now.
I Hope this helps :)
Cheers
Jasonjohn89
Posted on Jan 31, 2009
  • jasonjohn89 Feb 02, 2009
    it should be the same, try it and let me know the outcome
Can connect to router via LAN but not wireless.
Try updating wireless driver software. OR wireless driver for ur router might not installed while on LAN conn install them with UBUNTU SOFTWARE CENTER. Still nt works? check ur hardware for problems by experts.> ??? Try updating OS. OR installing another great open source OS with great hardware support.Follow the following link...
www.opensuse.org/
Dec 09, 2011 | 3Com OfficeConnect Wireless 11g Cable/DSL...
How can i get sound drives for dell laptop latitude D610 using window 7 os.
Unfortunately this computer is not windows 7 compatible, this means that sony is not gonna issue drivers for the laptop base on win7, however the os can be installed and you try using the drivers for windows xp, it is not sure but probably win7 would take those drivers.
give it a try it has worked for me, i include the xp drivers download link
xp drivers
Aug 19, 2010 | Dell Latitude D610 Laptop Computer -...
My wireless wont turn on on my dell d600
PLEASE CHECK IN DEVICE MAMAGER IF WAN CARD IS DETECTED OR NOT IF IT IS NOT UPDATE THE LATEST WAN DRIVERS FROM SUPPORT.DELL.COM IF IF STILL NOT ABLE TO DETECT GO TO SUPPORT SITE SEARCH FOR MANUALS OF THE PRODUCT RESEAT THE WAN CARD AND TRY IT AGAIN , IF STILL NOT WORKING WAN CARD HAS GONE BAD CHANGE THE WAN CARD ,
IF WAN CARD IS DETECTED IN DEVICE MANAGER JUST UPDATE THE LATEST DRIVERS AND TRY IT AGAIN AFTER RESTARTING THE COMPUTER ,
May 14, 2010 | Dell Latitude D600 Notebook
Dell Latitude D410 - OS won't boot only after a few minutes
Seeing that both OS's (Windows XP and Ubuntu) are having a problem booting up, I also think the problem is with your HDD. I think you have a pretty good idea about computers from your use of terms :) There may be some corruption with the HDD. I would check that out first.
Good luck with your problem and thanks for using FixYa.com!!
Apr 18, 2010 | Dell Latitude D410 Notebook
Can not connect in XP on local card but can if I
if ubuntu is able to use the wired and wireless, then the hardware is not the issue. Check windows tcpip stack for the wired card. Sounds like a windows driver/setting issue.
Oct 26, 2009 | Dell Latitude D410 Notebook
DOWNLOAD OF DELL LATITUDE D610 SOUND DRIVERS
You can download the DELL D610 driver from the link below. You can also download all other drivers and utilities from this link.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WLH&osl=en&catid=&impid=&SystemID=LAT_PNT_PM_D610
Sep 16, 2009 | Dell Latitude D610 Laptop Computer -...
Wireless adapter random disconnection problem
is it the same when you try with the Ethernet cable? if yes, it can be a problem with your router. check if the wireless light goes off.. wen u get disconnected..
May 02, 2009 | Dell Latitude X300 Notebook
Same wireless problem
Check with your laptop's manual. The wireless switch is usually hidden in a spot that makes it difficult to find, basically so that you cannot hit it by accident.
For example, a Compaq Presario R3000 has a button on the exact left hand corner of the front of the notebook, such that it cannot be seen easily, but when you push it to activate wireless, you will see a very faint light blue icon near the right front button.
On an HP laptop,the wireless button is on the bottom.
On my ACER, there is not button. It is an automatic switch between wire and wireless.
So look carefully for the switch, because if there is such a switch, it will be difficult to find. But it is most likely that there is no switch at all.
Cheers!
-a.
Jan 31, 2009 | Dell Latitude D520 - Celeron Intel Celeron...
D6OO DELL LATITUDE DRIVER
The Dell website under the support section will have the drivers you need. Hope this helps.
Dec 23, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
478 people viewed this question
David Payne
David Payne
