Question about Asko D1716 Built-in Dishwasher
Asko D1716 won't start
I have aquired an Asko D1716. It has been sitting in a garage for about 1 year.I have installed it into my new kitchen hooking it up to a hot water tap the plumber has installed.When i turn the dishwasher on the lights turn on but nothing else happens. Can anybody solve this problem?
  • leroy2126 Jan 31, 2009
    Looks like door switch is the problem, is this easily replaced.
  • 360 Answers
Ensure the water is turned on and the door is fully closed, make sure delay start is not set.....
if DW still won't start, I would begin by checking the door switch.
This link will download the owners manual for your unit. Click here
to download the manual.
Hope this helps.
Please take the time to rate this solution.
Posted on Jan 31, 2009
I have an ASKO D1716. Once started, it does not stop. I tried the rinse cycle and it advanced towards to setting 2. But, it continued to operate long past its normal time limit. (I have two of the...
here is a site with the fault codes and how to check for them.
To start the trouble-shooting programme, press the
Temperature selection button five time within 15 seconds. code chart info click on the link below.. Jay
Asko D1796 Use And Care Manual Fault Indications
Feb 10, 2015 | Asko D1716 Built-in Dishwasher
My Asko D1716 dishwasher works fine apart from the soap dispenser. It won't open to release the soap.
Most likely it's a corroded door catch or a bad solenoid. Hopefully it's not the main control board. You'll need a repair manual or technician. A work around would be to use detergent tablets in the compartment
Mar 02, 2012 | Asko D1716 Built-in Dishwasher
The upper rack support came apart on my Asko d1716 dishwasher
try contacting a good appliance repair and parts shop......or contact the original manfacturer
Jan 23, 2010 | Asko D1716 Built-in Dishwasher
Machine turns on but no water come into diswahser
Ensure there are no kinks in the water feed when you push it back into position and also ensure water is turned on.
May 10, 2009 | Asko D1716 Built-in Dishwasher
Asko d1716 door switch
Below is a link to get a PDF of your washer. Cannot say if the solution is easy to resolve, but with the manual you have numbers and sources to get more assistance. Hope this helps,
Sea Breeze
http://www.retrevo.com/s/Asko-D1716-Dishwashers-review-manual/id/21338ci577/t/1-2/
Jan 31, 2009 | Asko D1716 Built-in Dishwasher
Viking (made by ASKO) Dishwasher Problem
You can find parts, solutions and manuals at link below. Hope this helps, Sea Breeze
Click below
Dec 18, 2008 | Asko D1716 Built-in Dishwasher
Asko D1716 dishwasher problem
I also have an Asko D1716 dishwasher. The water stopped flowing. I replaced the water inlet valve and I have another problem, but the replacement of the fill valve is now letting in water. You can call Asko at 1-800-898-1879 to order the parts. If you order from Asko, I'm told you have some warranty on the parts. Anyway, the screws take a star drive and there is a front plate and back plate you will need to remove. There are approx. 4 screws on the front and 4 screws on the back. Just remember to unplug it before starting any work. The fill valve is in front of the machine. There are 2 screws holding it in place from the front. You will need to remove it out the back though to replace it since the fill tube to the tub is short and it wont allow you to pull it out the front. The repair is really easy once you get started.
Hope this helps,
Sargeantfod
Jun 11, 2008 | Asko D1716 Built-in Dishwasher
ASKO D1716 - blue tinge to stainless
Use any stainless pots cleaner to gat the shine back.
Nov 08, 2007 | Asko D1716 Built-in Dishwasher
Asko D1716 Built-in Dishwasher Logo
279 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
