Question about EliteGroup P4VMM2 Motherboard
RAM Support I have a DDR 256MB PC266 RAM attached to my board, I got a 128 MB PC333, is it possible for me to have both in one board?? Tried it once it was working but I might bust my board.. Thanks...
  • baju abad Jul 30, 2007
    hi, thanks for your reply, so what would be my total speed?? 128+256= 384 minus the shared memory?? I'm sorry didn't get what you mean by "it always runs on the slowest speed. Do you mean the 266 Mhz processing speed?? Thanks...
    President:
  • 2,961 Answers
If it works there is no problem, as the system would not boot up, but your memory will run at the slower of the two speeds, which will be PC266 and not PC333, as the faster speed ram is backward compatable because it always runs on the slowest speed.
Posted on Jul 30, 2007
  • andrew pester
    andrew pester Jul 30, 2007
    Yes your total ram will be 384mb, but the speed will be DDR pc266 as this is the slower of the two peices of ram, or the old equivelant to pc133
SOURCE:
I have heard that a PC333 DDR ram can also run in a PC266 DDR ram supported motherboard but in a "slower speed", what does this mean? Let's say that If I use a 512MB PC333 on a PC266 DDR Ram...
You will get 512 Mb of memory but it will run at the slower bus speed. Think of it like this. Your memory is your car. Your car has the ability to go faster, depending on how fast the motor allows it to go. Unfortunately, everywhere you drive has a speed limit. Regardless of how fast your car CAN go, you are only able to drive the speed limit. That's kind of what is going on with the bus speed situation.
Bus speed determines how fast the memory and cpu can transfer data between one another. The higher the bus speed, the more information it can transfer at a quicker rate. If your memory is capable of transferring at a rate of 333 MHz but your motherboard can only support 266 MHz you will surely have the 512 Mb of ram but it will only transfer at the motherboard supported speed of 266 MHz as opposed to the full speed that the memory is capable of.
Hope this helps. If it did help you, please give it a thumbs up.
Aug 24, 2011 | Gigabyte Computers & Internet
Wanting to findout what kinda ram i need to get for an upgrade. this computer only has 256mb.
SDRAM (Synchronous DRAM)
Almost all systems used to ship with 3.3 volt, 168-pin SDRAM DIMMs. SDRAM is not an extension of older EDO DRAM but a new type of DRAM altogether. SDRAM started out running at 66 MHz, while older fast page mode DRAM and EDO max out at 50 MHz. SDRAM is able to scale to 133 MHz (PC133) officially, and unofficially up to 180MHz or higher. As processors get faster, new generations of memory such as DDR and RDRAM are required to get proper performance.
DDR (Double Data Rate SDRAM)
DDR basically doubles the rate of data transfer of standard SDRAM by transferring data on the up and down tick of a clock cycle. DDR memory operating at 333MHz actually operates at 166MHz * 2 (aka PC333 / PC2700) or 133MHz*2 (PC266 / PC2100). DDR is a 2.5 volt technology that uses 184 pins in its DIMMs. It is incompatible with SDRAM physically, but uses a similar parallel bus, making it easier to implement than RDRAM, which is a different technology.
May 15, 2010 | Computers & Internet
I want to upgrade my PC's RAM from 128 to 512 MB Is is possible to add only single RAM or two 256 MB RAM?
Depending on your mobo, you can do either, add one stick of 512MB or two sticks of 256MB. If you're sure you get matching sticks if your mobo is DDR capable.
Jan 03, 2010 | Intel Motherboard
Getting POST Error "Beep" message (3 Long); on a Gateway 500SE Desk Top with an Intel (Nimitz 4000792) P4 1.8Ghz CPU . Can't run machine to ascertain BIOS; thus to determine that manufacture's unique POST...
Dear Frind i think your second ram 512MB Have PC400 Buss Speed, I think also *********** board doesn't support PC400 buss Ram, Please try Ram with PC266 Or PC333 Buss speed. Best Regards sumon
Mar 20, 2009 | Computers & Internet
Hp system board
the machine uses ddr 1 memory and hold a max of 2 gb of ram
RAM 128/2700 MB DDR SDRAM
Maximum 2 GB (2x1024MB DDR SDRAM)
Sockets Two 184-pin DDR DIMMs
Size 128, 256, 512 and 1024 MB DDR DIMMs
the motherboard is a socket 478 board , the Dual-Core chips are socket 775 so you couldnt use them unless you change the motherboard
Dec 08, 2008 | HP Computers & Internet
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
P4vmm2 wont boot up
Disconnect power cord, remove the button cell battery, press the power button to dissipate any stray volts, replace button cell, plug in cord and re-boot, this will reset bios to default settings.
You will get a check sum error so enter bios to re-set date time and other settings.
May 13, 2008 | EliteGroup P4VMM2 Motherboard
Memory chips
You can use PC2100, see below for example http://www.amazon.com/Memory-Upgrade-PC266-PC2100-AA32C12864-PC266/dp/B00009OYBA
Sep 21, 2007 | Intel Motherboard
Ddr ram for my motherboard
PC2100 is DDR266 memory. PC2700 is DDR333 memory. PC3200 is DDR400 memory All are backward-compatible with PC2100. Memory is designed to be backwards compatible, so generally you can safely add faster memory to a computer designed to run slower memory, but... your system will operate at the speed of the slowest memory module or system component. Keep in mind that the memory does need to be the same type, for example, SDRAM cannot be mixed with DDR, and DDR cannot be mixed with DDR2. ZT3000 "Beta tester of "0"s and "1's"
Aug 25, 2007 | EliteGroup P4VMM2 Motherboard
CMOS Setup Problem
your cmos battery is bad,try and change it
Feb 26, 2007 | ASUS P4GE-MX Motherboard
EliteGroup P4VMM2 Motherboard Logo
77 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
