Question about Magellan SporTrak Pro GPS Receiver
I need an instruction manual for a magellan 315 unit
Can anyone help me locate one.
  • 214 Answers
Sure, here's a link for the manual..
http://www.magellangps.com/assets/manuals/gps_310_315_en.pdf
Good luck, if this helps you plz rate this. Thank you knidly.
Posted on Jan 31, 2009
Magellan gps 315 will not connect to satellites
i have the same problem too, anyone has any idea. please share with us.
Dec 01, 2011 | Magellan GPS 310 GPS Receiver
I HAVE A MAGELLAN 315 IS THIS A WOODS AND TRAIL OR FOR A BOAT. I ALL SO NEED A MANUAL
Hi
The 315 was originally intended to be for woods and trail AND a marine application. The default is marine. Be WARNED! The battery life max is 15 hours.
Your owners manual can be viewed/downloaded here:
http://www1.magellangps.com/assets/manuals/gps_310_315_en.pdf
Be PATIENT! The Magellan site is fairly slooooow.
Hope this helps.
Mar 27, 2011 | Magellan GPS
Magellan 315 frozen
Occasionally, a unit will need to be reset. This can be due to software errors, firmware updates or simply at the command of technical support staff. A reset either will restart the unit, possibly clearing up any minor errors, or will restore the unit to the settings it was built with. There are three major Magellan units, which utilize different methods to perform this task.
Things You'll Need:
  • A thin object (such as a paper clip)
Using the stylus, tap "Main Menu" and select "View."
Tap "Settings," and select "Restore Factory Settings." You will be given the option to confirm this action. Be sure that you want to reset to the settings that the GPS was built with. This action is irreversible.
Tap "Confirm," and the unit will begin to reset.
Maestro/Roadmate GPS Units
Locate the button marked "Reset" on the left, right or bottom of the unit.
Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
Tips & Warnings
  • Do not attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
Jul 20, 2010 | Magellan GPS 315 GPS Receiver
AM LOOKING FOR A MANUAL FOR MAGELLAN GPS 315
(magellangps.com/support/product.asp?prodid=2)
You can use this link to download manual.
Apr 24, 2010 | Magellan GPS 315 GPS Receiver
Firmware Update Fails
I'm not sure this will help, but per Magellan (see below), the firmware update must be run twice as your firmware is earlier than version 3. I have a GPS 315 with v2.03 and can't find a cable to update mine. My GPS 315 does not appear to have a cable connection either, just a screw port on the back for a carrying strap. Was your homemade cable wireless? How did you make it?
You must follow instructions exactly to avoid corrupting your unit's flash memory.
  1. Select the .zip file and save it to your hard drive. Open the .zip file using WinZip.
  2. Connect your receiver to your PC using the PC or Power/Data Cable.
  3. Turn on the receiver and press the NAV key.
  4. Make sure the batteries are at least 50% full.
  5. Select the MAGUP executable file from your PC.
  6. Follow the instruction until you see the message Upload Complete.
  7. If your unit's software version is earlier than 3.00, you will be prompted to turn the unit on again and load the software a second time. Follow the instructions.
Jul 19, 2008 | Magellan GPS 315 GPS Receiver
Case cracking Magellan 315
The only method I have found is with a dremmel tool and cut it open along the original split line.
All the electronics are clear of the case mid line. The case is a bit less than 3mm thick.
The antenna is closest with maybe a 2 mm clearance all round and the various (6) rear conector wires (on the right looking from the back) have a similar clearance but sit below and away when the unit is assembled. Cheers
Dec 16, 2007 | Magellan GPS 315 GPS Receiver
Magellan 315 won't find satellites.
I have one of these units and it too is experiencing the same problem. I have talked to one geocacher and he thinks it could be the connection to the antennae that is now broken. He has a different Magellan unit and he had to fix the antennae connection. I was going to try that on my unit, but I need to figure out how to open it. Hopefully this helps. If I find out more I will let you know. Greg
Aug 15, 2007 | Magellan GPS 315 GPS Receiver
Problem with Magellan GPS 315
I own Two Magellan 315. They both have failed in exactly the same way as yours, will not lock on too a satillite. I have concluded that this is their design life and that is the end. I did post one to the Magillan repair centre in France but that disappeared. I have replaced the two of them from EBay and will see how I get on with those
Oct 19, 2006 | Magellan GPS 315 GPS Receiver
Magellan SporTrak Pro GPS Receiver Logo
216 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
