Question about Frigidaire PLMV169DC Microwave Oven
Frigidere PLMV169DCD I have the exact same problem. My model number is PLMV169DCD. The microwave worked the night before and then in the morning it was completely powerless. I checked the power source and it is fine, but the control panel on the machine has NO power. I can't use any functions.
  • ciovnicu_ion Feb 02, 2009
    I test the fuse and is OK .
    What else can I do ?
    Please Help.
  • satish_ie Apr 13, 2009
    I have Turned on the microwave saw a spark. powered off and tried to turn on. power doesn't come up. nothing works on the control pad.
    Problem Solver:
  • 18 Answers
You most likely had a power surge and blew a fuse. First unplug the unit,then remove the top grill. There will either be one screw on top of the control pad or 2 on the left side. open the control panel and look for a fuse that has a ceramic center and replace it with a 20 amp one. You can find these at the hardware store
Posted on Jan 31, 2009
My model number is PLMV169DCD. The microwave worked the night before and then in the morning the control pad was not working. I checked the power source and it is fine, but the control panel on the machine has power. I can't use any functions.
Posted on Mar 06, 2009
2 Suggested Answers
  • 52 Answers
SOURCE: Frigidere PLMV169
the internal fuse has blown, if your capable undo the screws on the casing and the check all the fuses
Posted on Feb 21, 2009
My plmv169dcd stopped working,looks like it has no power, but there is power at plug in. is there a reset button>
Not quite enough information. But, there is no reset button. Open unit check fuse. test all 3 door switches. They are the number one cause of problems and can take out the fuse or not. Other than that it will take more trouble shooting to find the problem
Dec 03, 2014 | Electrolux Frigidaire Professional Series...
How to repair a Frigidaire PLMV169DCD rangetop microwave oven that no longer heats food
Good Afternoon Friend,
I see you want to know how to repair your Frigidaire microwave, model# PLMV169DCD. Repairs on microwaves are typically not a do it yourself repair. I suggest contacting your local authorized technician for further assistance. They have been trained specifically on your appliance and will know exactly how to repair your microwave. Hope this is helpful.
-Best Regards-
WP
May 13, 2014 | Frigidaire Microwave Ovens
My Frigidaire oven model PLMV169DCD has developed a defect
The only real issue with the control board that could cause that is a failing relay or bad connection, both of which I can repair on a control board for $54.95, which includes insured return shipping.
The first thing I would do is test the outlet. A toaster or hair dryer are good devices to use.
A microwave must be on its own breaker, or at least not on the same breaker as a high-current device (stove) or a device that causes spikes on the line (fridge, freezer).
It's possible you have a failing magnetron or high-voltage transformer, but I would need to discuss it to narrow it down.
For free additional DIY help and details, feel free to e-mail me directly from my site. Remind me of your full model number and detailed symptoms.
William E. ("Ed") Miller
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 26, 2017 | Frigidaire PLMV169DC Microwave Oven
Where is the fuse on my microwave Electrolux PLMV169DCD located?
We have three service manuals covering the PLMV169 series, which you can download free:
http://www.microwavedisplay.com/plmv169dcc_sm.pdf
http://www.microwavedisplay.com/glmv169_plmv169_sm.pdf
http://www.microwavedisplay.com/glmv169_plmv169_late_prod_sm.pdf
They're all pretty similar.
You can usually find parts from the Pros here.
If not, contact Electrolux at the phone number on the front of the service manual.
It may be the C/T fuse (thermal fuse located above the magnetron) or the oven cavity thermal cutout, located on the top of the cavity.
Accessing these two parts for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Electrolux / Frigidaire owner's manuals and installation instructions
here.
It may also be that there was a power surge which damaged the control circuit board, activating the built-in surge protection.
This is not resettable. The circuit board has to be repaired. We do that for $39.95, details here.
Dec 03, 2011 | Frigidaire PLMV169DC Microwave Oven
Frigidaire micro plmv169dcd not working
test it with a meter it has a small wire inside and, sometimes can not be visually checked
May 28, 2009 | Frigidaire PLMV169DC Microwave Oven
Control pad does not repond
hi
i think the timer has to be reset,,and make a hard reset..
than k you............
Mar 06, 2009 | Frigidaire PLMV169DC Microwave Oven
Plmv169dcd handle fell OFF
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If you need more help with disassembly, we have similar service manuals and have uploaded them to our site here, here, and here to help you.
You will need the free Acrobat Reader to view or print them in case you don't have it already.
Feb 13, 2009 | Frigidaire PLMV169DC Microwave Oven
Frigidere PLMV169
Jan 31, 2009 | Frigidaire PLMV169DC Microwave Oven
Microwave plmv169dcd
You may be right.
The hood fan should always be on whenever you're cooking on the stovetop.
If it does not dry out over time, it may need to be manually dried or blown out.
Replacing the keypad is generally not too hard do-it-yourself job.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you need more detailed help, please feel free to follow up directly via the first link.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 11, 2007 | Whirlpool GH7145XF Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
610 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
