Question about Extreme Networks Sentriant (EXT70011) Firewall
Sentria will not start
Cord plugged in start switch placed on on, no reactions.
The light did not come on either.
  • 80 Answers
Try using a different cord to plug it in or outlet in the wall. Hopefully you have not fried it.
Posted on Jan 31, 2009
What is the real meaning of light dependent reaction? Explain what it is? Please.
light reaction (redirected from Light-dependent reaction)
Also found in: Thesaurus, Medical, Encyclopedia, Wikipedia. light reaction n. Any of the chemical reactions that take place as part of the first stage of photosynthesis and require the presence of light, by which energy captured from light is converted to chemical energy in the form of ATP. American Heritage® Dictionary of the English Language, Fifth Edition. Copyright © 2011 by Houghton Mifflin Harcourt Publishing Company. Published by Houghton Mifflin Harcourt Publishing Company. All rights reserved. light reaction n (Botany) botany the stage of photosynthesis during which light energy is absorbed by chlorophyll and transformed into chemical energy stored in ATP. Compare dark reaction Collins English Dictionary - Complete and Unabridged, 12th Edition 2014 © HarperCollins Publishers 1991, 1994, 1998, 2000, 2003, 2006, 2007, 2009, 2011, 2014
Light dependent reactions
Apr 28, 2016 | Cars & Trucks
Will not operate, no reaction when power button pressed. All panels properly locked.
first off does the light come on at all? when the switch is moved to the High Medium or low setting do you see a red light or a green light on the right side of the unit? if there is no light at all, then there is either no power and you have a bad cord or a bad outlet. The only other thing could be the switch that needs to be tripped in order to let the unit run, that switch is closed by the front cover locking in place. that switch could be bad or your cover may have the tip of the pin that pushes the switch closed broken off or deformed and not pushing down enough to close the switch. try pushing a screwdriver down on the switch and see if it comes on. There's nothing that can shock you if you push on that switch, the power wires are concealed inside a plastic covered area that the switch slides into. If you close the switch and it doesn't come on the check the power cord or the wall socket for power. See if the cord has any unusual looking spots or lumps, stretching, cuts or anything that looks suspicious.
Apr 06, 2015 | Oreck XL Professional Air Purifier
Why when I attached the screen cover to the motor like I have in the past onto my sentria vacuum. doesnt the motor fan turn, got any ideas
The vacuum bag's boot and the power head or hose with piece protruding from it must be hooked up or the motor will not start.
There is a switch on the bottom front that must be pushed in at the same time the slider switch where the bag's boot connects and turns must be slid to its max.
That is where it must be very clean for if that switch will not move the motor will not start.
Also, the electrical cords on that model were not a good make and one side only on the plug to the vacuum would always have no continuity.
I hope this helps!
William R!
May 06, 2014 | Kirby G6 Bagged Upright Vacuum
Kirby Vacuum Cleaner on/off switch won't stay switched on
If the motor turns on turns off in the course of the vacuuming, check the cord or the switch This is how you replace your cord on a Sentria vaxuum.
Jan 15, 2013 | Kirby Vacuum Cleaner Switch For G3-Sentria...
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
Oct 12, 2012 | Kirby Vacuums
Spilled a glass of red wine across the table, a little got on my wife's closed laptop, under it and a little on the inside I'm sure. Power cord works, lights up, recognizes the charger and says charging....
Place your laptop in the sun light for 3 or 4 hour ,and again start the laptop .Also you will remove the battery and the dc adapter .press the on of switch for 30 seconds.AGAIN INSTALL THE BATTERY AND THE ADAPTER .I THINK IT SOLVE YOUR PROBLEM.
Dec 16, 2010 | Computers & Internet
Kirby Sentria won't start. I have read there are several safety features on it. Does anyone know the trick to get it to get power?
The bag needs to be locked into place at the base ( the hard part under the cloth bag, called the mini emptor ), and the nozzle must be locked on. If it still won't come on, it probably has a bad cord
Apr 29, 2010 | Vacuums
I cant find fuse on my kirby sentria. Any suggestions?
there isn/t a fuse if not turning on probably a bad switch or power cord
Jul 18, 2009 | Kirby G6 Bagged Upright Vacuum
Extreme Networks Sentriant (EXT70011) Firewall Logo
29 people viewed this question
Top Extreme Networks Computers & Internet Experts
David Payne
David Payne
Are you an Extreme Networks Computer and Internet Expert? Answer questions, earn points and help others
