Question about Kicker KX600.1 Car Audio Amplifier
Kicker 6 x 8's
Today I installed (4) after market Kicker 6x8's in a 2000 Ford Ranger. I also purchase after market wire harnesses so I did not have to do any wire stripping, crimping, or splicing. I literally took off all the panels, unscrewed the speakers plugged the + and - on the speaker terminals, and clipped the harnesses together. Simple, right?
Far from. They keep cutting out. I am pretty sure the problem lies within the passenger front door. If I use the back of my fist and lightly hit it, they all turn on. I have taken the speaker out 3 times, flipped it the other way, and checked for any metal grounding.
At this point, I am at a total lost. This was the easiest and most professional install I have ever done and still ended up with a problem. Any thoughts, suggestions, and/or ideas would be much appreciated!
  • Jeff Amstutz
    Jeff Amstutz Jan 31, 2009
    I will try that tomorrow. It is awfully weird though, it doesn't seem that is possible with where the wires connect to the speaker connections (right under the cone), but that IS the only metal showing that I have seen. I appreciate your promptness and I will be more than happy to let you know once I try it.
    President:
  • 1,990 Answers
This is Caused by the Connector on the Back of the Speaker Contacting Door Metal. Wrap Black electrical tape around the Connector and it should stop. Please Rate My Response! Thanks!
Posted on Jan 31, 2009
  • Travis Humphries
    Travis Humphries Jan 31, 2009
    Awesome, Just let me know!
1994 Mazda B4000 abs light flashes 16 times, dash light does not work, and tail lights do not work. No blown fuses for the lights. Unhooked trailer wire harness.
93 ranger 2wd xl abs light blinking 16 times and rear brake light fuse blows when lights on and u hit the breaks but if the lights are off and u hit the brakes it fine i just installed today also the plug and play trailer harness but i didnt think that has anything to do with it.
i drive a 1994 ford ranger 2wd reg cab 4 cyl 2.3
Jan 03, 2017 | Mazda Cars & Trucks
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
Turn signal harness 2002 ford ranger 14a320 diagram turn signal connector wire colors and ppin location
images for Turn signal harness 2002 ford ranger
Ford explorer turn sinal problem got fixed - YouTube
? 3:23
www.youtube.com/watch?v=I2SUGIvYAWc
Jul 12, 2013 - Uploaded by Raybob216 My 04 exployer left turn signal and break light not working fix loose wires behind ... bulb and come to find out wire had popped out of the harness. ... How to Change Ford Explorer 2002 Flasher Relay for Hyper Flasher Relay ... How To Install Replace Turn Signal Wiper High Beam Switch Ford Ranger 95-98 ...
Oct 07, 2015 | Ford Cars & Trucks
I just purchased a JVC KD-S16 CD Player and I can't install it.
Get an adaptor wiring harness. It plugs directly into the plug in the truck. The wires are all labeled and you won't have to hack up the wiring in the truck. You can get the adaptor whereever they sell car stereos.
Apr 01, 2010 | Audio Players & Recorders
Replaced wiring harness on 2000 Ford Ranger now truck won't start
2000 ford ranger wont start off switch if u jump the silanoid it will start. new start and ignition switch
May 06, 2009 | 2000 Ford Ranger SuperCab
After market 6 x 8 speaker problems
it sounds to me you have a short in the wiring or an internal short with-in the speaker itself
Jan 31, 2009 | Dayton Audio Dayton SWC-1CO 1.0 ft³...
Ignition wiring
firingorder6a.gif firingorder6.gif 1991-1994 2.9L and 3.0L Engines Firing Order 1-4-2-5-3-6 1995 And Later 3.0L V-6 With DIS Ignition System Firing Order 1-4-2-5-3-6
4.0L Engines Firing Order: 1-4-2-5-3-6 DIS Ignition System
Nov 22, 2008 | 1995 Ford Ranger Supercab
Wiring color codes for ford 2002 f250 radio
I can email full diagram to your email address...just post it here. I can tell you that power wires are:
1.) memory power (all times) is light grn / violet
2.) power in start position is red / black
3.)power w/ acc. delay is pink
4.) ground is black / light green
Nov 18, 2007 | Car Audio & Video
Kicker KX600.1 Car Audio Amplifier Logo
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
