hi, since when are you facing this problem, did you installed any software or any new hard ware on your machine
1) which operating system are you using windows xp/98 /vista 2) Are you able to see the speaker icon at the bottom right hand side on the screen of your machine 3)
go to start > run > type in devmgmt.msc > ok in the window that opens what do you see, do you see any bang sign next to or any ? sign
awaiting clarificationhi, since when are you facing this problem, did you installed any software or any new hard ware on your machine
go to start > run > type in devmgmt.msc > ok in the window that opens what do you see, do you see any bang sign next to <sound video game controllers> or any ? sign
You can't post conmments that contain an email address.
A 'mass storage device' is any device on which files can be stored (HD,
Memory card, thumb-drive etc.) so that controller is not for the USB
ports as such, but may indeed be for a storage device that plugs into a
USB port (card-reader, external HD). For a laptop, it may be for a
built-in card-reader which is connected internally to the USB bus.
Go here and enter your laptop's serial number to be sure of getting the
proper drivers specific to your machine, as you may be trying to use
the wrong driver. Only by entering the serial number can you be sure of
getting the correct files: http://support.gateway.com/support/d...ter.asp?Tab=My
If the power indicator is flashing that means that it's getting power, but there is not enough power, the first thing you should do is check the adapter power supply with a multimeter and make sure that it's outputing the correct power, if it's not then you need to replace the adapter. If it's then it's more complex.
My goal is to help you find a solution to your problem, if you found this helpful please give it the appropriate rating.
Hi, it depends upon what kind of error s you get, when it is shutting down you should contact gateway for the OS restoration CD if it came preinstalled, but it will depend upon their policy for shipping lost media.
Hi I have two alternatives to solving your problem the first is if your PC is still under warranty have the store replace the said keyboard and everything will be fine failing that the only other solution is to take it to a reputable store for them to fix it for you hope this is of any help
hi,
or any ? sign
3)
