Question about Whirlpool 24 in. GU980SCG Built-in Dishwasher
Leaks at bottom of door when starts to wash
Whirlpool gu980scgt 3
    Problem Solver:
  • 18 Answers
This problem is most likely caused by a faulty pump seal. You need to remove the lower spray arm and then you will see 8 torx bit screws securing the top of the pump. remove this and you will see a rubber gasket that has blown out. You can replace with a new one or carefully cut enough of the stretched seal out to reset it in it's track and reinstall cover. while spray arm is off inspect it for plugged holes or even cracks as these can also cause leaks.
Posted on Jan 31, 2009
During wash or rinse cyle, water leaks from the bottom
open the door,check the rubber boot for any holes,ussually that's where it leaks,also wipe the inside of the door,i've found hair and lint stuck on the inside bottom of the door and water leaks out but pull open the rubber boot and run your fingers all around it to check for any holes.you can remove the bottom panel and then run the machine to see where the leak is coming from.
Apr 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Our dishwasher has leaked out the bottom front on two of the last 3 washing cycles
Make sure that the seal is not pinched in the bottom of the door. this happens very often, open the door all the way and check for a pinched or mislaid seal.
Dec 23, 2010 | Whirlpool Dishwashers
Whirlpool fron loader washer leaks at the door
The water should be able to come up to the door level without leaking. Chances are you have build up on the bottom side of the glass on your door. If so take a razor blade and scrape the build up off. Your door will quit leaking.
Aug 12, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Our whirlpool is leaking from the bottom during
our door gasket was leaking and running out the bottom... not sure how the gasket got holes in it but it had five or six holes and it is not that old. the gasked was over a hundred dollars and the water bill ran over a hundred dollars before I found the leak
Jul 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door seal leaks cant how to remove and reinstall
1: remove the top panel
2: remove the lower front panel
3; remove the control panel
4: remove the screws holding the door switch
5: remove clamparound the door seal and remove front panel (2 screws bottom and 2 up)
6: remove clip around door seal that holds tothe tub
7: replace seal....
there you go!!!
Jul 04, 2009 | Whirlpool Washing Machines
Leak
Hi, If you remove the lower half of the front panel, you will be able to see the pump and hoses. Another option is the bellows around the door. Please let me know if this helps or if I can assist you further.
Thank
Vic
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking from the door and front panel of my Duet washer
Check the rubber door seal, sounds like its split which is common after 2-3 years use.
You can find the general area of the leak by placing dry newspaper on a dry floor beneath the machine.
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaking
It may have torn the gasket or just have a sock stuck in it.
you can remove the bottom panel to help look.
(3 screws on bottom front lip)
remove ac power
you cannot operate with bottom door removed as it has a safety switch.
While you are down there open the filter and look for trapped debris.
ready for some water , have towels ready.
Feb 02, 2008 | Whirlpool GHW9100L Front Load Washer
Whirlpool 24 in. GU980SCG Built-in Dishwasher Logo
158 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
