Question about Moen & Posi-Temp Single Handle Shower Or Tub Valve
Moen posi-temp for shower pressure
I have a moen posi-temp faucet in my shower and my hot water heater is an instant hot(gas) There is not enough hot water pressure coming out of the posi-temp to ignite my hot water to its full heating. I have replaced the cartrige and even tried to flip cold and hot controls. I need to have the flow harder and I know there is a govern on the flow rate but I can't take another luke warm shower this winter. If anyone knows how to take out the water restricter it is what my water heater manual suggests it would help alot. Thanks in advance for your time. Hope help is out there.
  • toohandy74 Feb 26, 2009
    just with the posi-temp in the shower. for the water from the spout and the shower head. I removed the water restricter from the shower head still a no go
  • margaret smithe Jan 28, 2013
    did you ever get a response re: the Moen faucet, not the shower head? Plumber changed valve but only warm water - not hot. Working with a tankless as well. thanks.
There is a little "o" ring in the shower inlet that is designed to collapse as the pressure increases, limiting flow. You can safely remove this and then have un restricted flow.
Posted on Feb 24, 2009
    Problem Solver:
  • 4 Answers
Blame President Clinton and the environmentalist. They passed a law that requires all showers to be low flow.
Try turning on another faucet on the same heater to increase the flow through the heater..
Posted on Feb 07, 2009
  • 33 Answers
Is this only happening in your shower? Or through the hole house? Maybe you shower head has a flow restrictor in it. Try removing it!
Posted on Jan 31, 2009
My shower makes a very annoying whistling sound. What's causing this?
you cannot use any other cartridge posi temp only. remove flow restrictor in hand held
Nov 25, 2012 | Moen Posi-Temp Single HandleTub And Shower...
Low hot water pressure on Moen Single-Handle Shower Only posi-temp shower control. Cold water pressure is fine. Hot water pressure elsewhere in house is ok. Cold it be the cartrige -- lime buidlup, etc.?
I think you are on the right track. The first thing I would do is change the cartridge. While you have the valve apart examine the inlet ports as good as you can to see if there is any mineral buildup. You can use a short length of a small gauge mallable wire to run into water ports to se if you can break anything loose. Another thing you can do is to turn supply stop on slightly while you have the valve disassembled to wash any particles out. Hope this helps you and thanks.
May 14, 2011 | Moen Posi-Temp Single HandleTub And Shower...
No hot water on Moen single handle shower faucet. cold ok and shut off is fine
do you have hot water elsewhere? if not, might be that your water heater is not heating.
if you do have hot water elsewhere, did you let the faucet run for a minute or 2.
did you have hot water before? is this a new house? new valve?
need a little more detail.
on posi temp valves, if there were no water coming out of the hot side of the valve, the valve will not operate.
Aug 12, 2010 | Moen 1 Handle Lever Shower Faucet With...
Moen L3175 faucet with low water pressure
IS THIS A SHOWER ONLY? IF SO ,I WOULD REMOVE THE SHOWER HEAD FIRST THEN TURN YOUR WATER ON.THE HEAD JUST MIGHT NEED TO BE CLEANED AFTER 11 YEARS.
May 10, 2010 | Moen L3175 Chrome Legend Single Handle...
Low water pressure
When it was installed was there any copper sweating done? If so, the valve cartridge can get fried if not removed prior to the immense heat from a torch.
Jan 23, 2010 | Moen Posi-Temp Single HandleTub And Shower...
No water flow
Did this unit come with water stops built into the faucet body? Some of the newer faucets have stops built in and they need to be turned on. Also if you aren't going to plumb the hot in, you will need to cap it off but it should run without it unless it has some sort of balance in it. I don't think so though.
Apr 09, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Single handle moen shower not turning far enough
it is your shower cartrige. ace hardware $45. hot always goes first. just check if it is a posi-temp or moan trol
Dec 17, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Moen & Posi-Temp Single Handle Shower Or Tub Valve  Logo
1,451 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
