Question about Compaq Presario 5000 PC Desktop
Would this motherboard fint in
Http://www.newegg.com/Product/Product.aspx?Item=N82E16813131318
    President:
  • 2,992 Answers
Yes, the board would physically fit in the 5000 series case. In fact, any micro-ATX form factor board would fit. But you will need a new power supply as well. Motherboards used in those computers did not need the 4-pin power cable required on new boards. You should also consider cooling if you are building a high-performance system. The 5000 series case doesn't offer much room for adding cooling fans - only one place on the rear panel. But they are nice cases. I've built several systems in them.
Posted on Feb 11, 2009
Replacement motherboard
The Aspire x1800 motherboard is Micro-ATX, so you will be able to replace it with a Micro-ATX motherboard compatible with your lga 775 cpu and ddr2 ram. Here's an example relitively inexpensive motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E16813157359 .
Also make sure you use thermal paste (http://www.newegg.com/Product/Product.aspx?Item=N82E16835186020) when reapplying your cpu cooler. Here is a short article describing how to do that: http://www.maximumpc.com/article/howtos/howto_install_cpu_and_apply_thermal_paste
Jun 08, 2013 | Computers & Internet
I want to upgrade the PCI Graphics card for my (Phoenix Bios D888)U8668-DD motherboard. What are the latest graphics cards I can get for it?
Hi there! You can only use PCI graphics on your motherboard, so the best card you can get is a GeForce 8400 by NVIDIA. Jaton makes an excellent card with 1GB of VRAM - it's $194. Here is a link to the card http://www.newegg.com/Product/Product.aspx?Item=N82E16814139047 It is one of the few PCI cards you can get with that much VRAM. You could also look at a GeForce 6200 - http://www.newegg.com/Product/Product.aspx?Item=N82E16814139037 Or a Radeon HD 4350 - http://www.newegg.com/Product/Product.aspx?Item=N82E16814129156 Best of luck! Alex
Jun 01, 2011 | Computers & Internet
I want to purchase a best available core 2 duo motherboard and processor. Please suggest which is the best.
motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128433
quadcore
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115210
dualcore
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115054
Oct 07, 2010 | Intel DG41RQ Motherboard & Core 2 Duo...
Compatible graphic cards
Either an AGP video card......
OR
PCI
(you have no pci express slot, so that limits you)
Here's a couple:
..For AGP Slot -- http://www.newegg.com/Product/Product.aspx?Item=N82E16814102814
..PCI Slot ...
http://www.newegg.com/Product/Product.aspx?Item=N82E16814143218
just sift through the site....you'll find hundreds of them.
Mar 04, 2010 | EliteGroup P4M800PRO-M Motherboard
Which motherboard will suport intell chipset g45
Just a few good ones here. Go to Newegg's site. Theyu have 52 of them, all rated by people who have them and all price ranges and options. If you need help explaining the options just post me here again..
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128348
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128345
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131295
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138127
Dec 04, 2008 | Computers & Internet
Question
First, you will not be able to upgrade the video card on your laptop, since video cards for laptops are specifically designed to fit onto the motherboard and the design of the laptops body.
Secondly, sound cards as well are also deisgined that way, some sound cards on laptops are built in to the mother board and higher end sound card for laptops are specifically designed to fit onto the motherboard and the laptop's body.
Hard Drives on the other hand can be upgraded to a higher capacity but you can't add an additional Hard Drive. I have checked the specs of your laptop has 80GB IDE. You can upgrade to 120GB IDE or higher if you like. Just make sure that you purchase a 2.5" HDD (5400RPM/7200RPM speeds).
Here are examples of Hard drivers that you need for upgrade. I checked newegg.com for available laptop hard drive. You can check other online stores or other computer shops near you if you as well.
links (Hard Drive) :
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136130
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148073
http://www.newegg.com/Product/Product.aspx?Item=N82E16822146200
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136114
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148130
**Since you have installed Windows Vista, I suggest that you upgrade the RAM (Memory) on the laptop for smooth performance for Windows Vista. The maximum memory on your laptop is 2GB DDR SDRAM. Buyin RAM for laptops are a little but tricky so you can just go to the link below for specific memory upgrade for your laptop (I suggest that you purchase 2 pcs of 1GB since your system can accomodate up to 2GB).
Link for RAM (Memory) :
http://www.edgetechcorp.com/memory/upgrade.asp?cid=29695
**If you decied to upgrade the Hard Drive, you can still use you old Hard Drive as an USB external Hard drive for storage purposes. You will just have to purchase a 2.5" External Hard Drive Enclosure. Click on the link below for the example of the product :
http://www.newegg.com/Product/Product.aspx?Item=N82E16817145136
http://www.newegg.com/Product/Product.aspx?Item=N82E16817145329
**If you can't click on the links, just copy the link and paste it to your's browser's address bar.
Oct 28, 2008 | Sony VAIO PCG-GRT360ZG Notebook
Compaq Presario 5000 PC Desktop Logo
103 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
