Question about Dayton Audio Dayton SWC-1CO 1.0 ft³ Subwoofer Cabinet w/Cutouts Speaker
After market 6 x 8 speaker problems
Today I installed (4) after market Kicker 6x8's in a 2000 Ford Ranger. I also purchase after market wire harnesses so I did not have to do any wire stripping, crimping, or splicing. I literally took off all the panels, unscrewed the speakers plugged the + and - on the speaker terminals, and clipped the harnesses together. Simple, right?
Far from. They keep cutting out. I am pretty sure the problem lies within the passenger front door. If I use the back of my fist and lightly hit it, they all turn on. I have taken the speaker out 3 times, flipped it the other way, and checked for any metal grounding.
At this point, I am at a total lost. This was the easiest and most professional install I have ever done and still ended up with a problem. Any thoughts, suggestions, and/or ideas would be much appreciated!
  • Jeff Amstutz
    Jeff Amstutz Feb 04, 2009
    Thank you for your help. I think you are right. On Saturday we took the door panels back off and removed the speakers. It seems like the transistors on the tweeters had bare metal exposed. Our assumption was that as the speaker vibrated, it would ground out on the basket. We put electrical tape behind the transistors so it wouldn't touch and also taped around the speaker opening on the door to prevent any grounding problems that could be caused. So far so good (knock on wood). Thanks again.
  • 24 Answers
It sounds to me you have a short in the wiring or an internal short with-in the speaker itself
Posted on Feb 04, 2009
1994 Mazda B4000 abs light flashes 16 times, dash light does not work, and tail lights do not work. No blown fuses for the lights. Unhooked trailer wire harness.
93 ranger 2wd xl abs light blinking 16 times and rear brake light fuse blows when lights on and u hit the breaks but if the lights are off and u hit the brakes it fine i just installed today also the plug and play trailer harness but i didnt think that has anything to do with it.
i drive a 1994 ford ranger 2wd reg cab 4 cyl 2.3
Jan 03, 2017 | Mazda Cars & Trucks
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
Turn signal harness 2002 ford ranger 14a320 diagram turn signal connector wire colors and ppin location
images for Turn signal harness 2002 ford ranger
Ford explorer turn sinal problem got fixed - YouTube
? 3:23
www.youtube.com/watch?v=I2SUGIvYAWc
Jul 12, 2013 - Uploaded by Raybob216 My 04 exployer left turn signal and break light not working fix loose wires behind ... bulb and come to find out wire had popped out of the harness. ... How to Change Ford Explorer 2002 Flasher Relay for Hyper Flasher Relay ... How To Install Replace Turn Signal Wiper High Beam Switch Ford Ranger 95-98 ...
Oct 07, 2015 | Ford Cars & Trucks
How to install a Kenwood kdc 138 in a 1992 Ford Escort LX?
if its anything like my 92 ranger you take the dash apart around the radio and the stereo should unscrew, in my ranger the new cd player went in without any extra harness as it was the same size as the stock, if not you can but harnesses to go where your old stereo did, to connect the speakers you can buy a ford wiring harness from walmart or any store with an audio department. these plug in to your vehicles wiring harness so you don't have to cut it out, after that you simply match colours from the wires of the new cd player to the wiring harness
Dec 25, 2013 | Kenwood DISCONTINUED - KDC-138 In-Dash CD...
I have a 1990 Ford murcuery and i just got a 2010 Pioneer super tuner 3 D 2200UB but i cant seem to get any power to the DEH and i was wondersing if you could help me solve this problem?
Did you use a factory wire harness in conjunction with the after market wires included with the Pioneer? You might have a bad ground. The basics behind the factory should look like this: Constant 12V+ Green/Yellow Switched 12V+ Yellow/Black Ground Red/Black Illumination n/a Dimmer Blue/Red Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Orange/Green Left Front (-) Black/White Right Front (+) White/Green Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Green Left Rear (-) Pink/Blue Right Rear (+) Pink/Blue Right Rear (-) Green/Orange
The best thing to do is to use an after market harness if you didn't before. Just in case you aren't sure, the Pioneer wires are color coded to the after market wires. You wire the two harnesses together, and then plug that into the factory wires. This would help on the chance that you decided later on to sell the car, but want to keep the Pioneer until. I hope this helps, and let me know what you come up with.
Apr 12, 2011 | Car Audio & Video
I need to find the diagram for the wires of the car stero AM/FM Cassette 1999 Ford Ranger XLT
1999 Ford Ranger Pickup Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Light Green
Car Radio Switched 12V+ Wire: Yellow/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Blue/Red
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger N/A
Car Radio Amp Trigger Wire: Blue
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): Dark Green/Orange
Right Front Speaker Wire (-): White/Light Green
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
pls rate
Aug 17, 2010 | Buck Ford Econline Van 1998-2006 Stereo...
I have 97 for ranger with tape deck with cd player
This should help you wire up your new stereo. 97 Ranger stereo wiring diagram. They do make a plug in harness for your truck. Metra part number 70-5600.
May 10, 2010 | 1997 Ford Ranger SuperCab
How do i wire a 8 ohm kicker comp 10" sub inside the box? and what is the best way to get more bump with a 600 w mtx amp and kicker comp 10" sub?
Ok, for an 8 Ohm sub, it is advisable to get another 8 Ohm sub. wire them in parallel down to a 4 Ohm load. You would wire both + wires together, and both - wires together to yield a 4 Ohm load at the amp. Majority of the amplifiers on the market are designed to give more power at a lower impedence, or Ohm load. You just have to make sure that your amp will take a 4 Ohm load. Without knowing the model of the MTX amp, I can't give more advise. However, this should be able to give you and idea of where to start. The main problem is that you have a single 8 Ohm sub in the Kicker Comp.
Apr 30, 2010 | Kicker CompVX CVX104 Subwoofer - 10" Dual...
Looking for 1996 ford mustang wiring diagram for stereo
things to consider:
Does it have a factory amplifier?
Is the factory harness still present?
Does it still have the speakers present?
You are going to only have a certain amount of wires... If the factory harness is still there you can simply purchase an aftermarket or just look at one in a local store on what wires are what.
you would have your:
gray and gray w/ black
purple and purple w/ black
green and green w/ black
white and white w/ black
these are normally used as an after market clip on harness for that factory wiring. (left front, right front, left rear, right rear)
Obviously your going to have the constant (yellow), ignition (red) and the ground (Black);
so the others would be either a remote (amp or power antenna) usually white with blue strip and dimmer normally orange for the after market harness, and the others will be the speakers.
What you COULD try is using a 9v battery and picking up the wires that are solid and striped and touching them to the 9v battery.
When you find the two that make that speaker make a popping sound you have found that speaker.
Once you have found the speaker that pops, you should be able to take it out and look at the color of the wires to make sure you will have the pos and neg for each speaker correctly set.
You dont want some speakers being in phase while other are out of phase. if so the sound wont be right.
Mar 27, 2009 | 1996 Ford Mustang
Kicker 6 x 8's
This is Caused by the Connector on the Back of the Speaker Contacting Door Metal. Wrap Black electrical tape around the Connector and it should stop. Please Rate My Response! Thanks!
Jan 31, 2009 | Kicker KX600.1 Car Audio Amplifier
Dayton Audio Dayton SWC-1CO 1.0 ft³ Subwoofer Cabinet w/Cutouts Speaker Logo
139 people viewed this question
Top Dayton Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Dayton Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
