Question about Optoma HD72 Multimedia Projector
The optoma hd72 projector lamp goes out after 30 seconds.. the big game is this weekend... what can I do?
  • Anonymous Feb 19, 2009
    Hey, Hexum... although it sounds rediculous, I will try it... hopefully I'll get the same results you did...
    FYI, I ended up having to borrow a projector for the big game... I'm glad I did - We, Steeler fans, celebrated our 6th!!!! Thanks for the info!!
    Problem Solver:
  • 5 Answers
I had this exact same problem. I have changed bulbs gotten 1000 or so hours from new bulb, changed the lamp driver and gotten about 600 more hours from new lamp driver. New lamp cost me $350, lamp driver cost me $120. Then I read on a page to try and flip it right side up, because I had it ceiling mounted upside down. I flipped it right side up and it works perfectly and has been working perfectly for 2 months now. I know it sounds stupid, but it actually worked for me, and it costs you nothing to try it. For some reason, gravity effects this unit.
Posted on Feb 05, 2009
Optoma hd72
It sounds like you bulb is ready to die. First clue is picture quality. That happen to me and a new bulb remedy the problem. Bulbs are expensive though.
Jan 28, 2014 | Optoma HD72 Multimedia Projector
Hello, I am having a problem with my hd72/hd6800. My projector is on its original bulb and has about 500 hours over 5 years. Today i was able to turn it on, but the lamp wont light up. I hear the fan start...
Despite the relatively few hours on the lamp, the fact is it's over 5 years old. It is not uncommon for a lamp to age and be too weak to fire. Replace the lamp, you should be fine.
Jan 25, 2011 | Optoma HD72 Multimedia Projector
My Optoma HD72 projector operates for about 1 minute and then shuts off. I kept my old bulb around "just in case", I've replaced the bulb with the old one and have the same problem.
The problem is not over-heating. The Optoma HD72 has a known problem that Optoma won't advertise. The lamp driver is faulty. They simply have to replace the lamp driver. I purchased a spare lamp with my original purchase. I had the exact same experience as you at around 1200 hours on the lamp in ECO mode. I used the spare lamp. Same thing happened at about 1200 hours. I had a friend at Optoma. he confided to me the problem. I sent it in and they replaced the lamp driver at no charge. I got another 800 hours out of the first lamp and am now using my second lamp and have about 600 hours on it. The pic quality is so good with this projector (used Digital Video Essentials to calibrate) that I'll just order a bare lamp or two and use the existing lamp housings when I need a new bulb.
Apr 12, 2010 | Optoma H30 Multimedia Projector
Lamp flashing, hd72 projector
In most projector menus there will be an option to reset the lamp timer, it's usually under the "settings" area of the menu. Try resetting the lamp timer and the light should stop flashing.
Jan 17, 2010 | Optoma HD70 DLP Projector
Lamp light is solid orange/red; No Image on screen when pj on
Sounds like bulb to me best way to check is take it to a service centere and they will use a replacement or test bulb to find out for you , it may not be your bulb it may be your ballast circuit . ... regards Vortash
May 10, 2009 | Optoma HD72 Multimedia Projector
Optoma HD72 flashes red and green. I changed the lamp but the problem wasn't resolved. Any input would be greatly appreciated.! Greg
I had the same problem with flashing colors after playing for awhile. The following helped:
1. turn off bright mode from menu.
2. keeping the back side of the projector flat. I had it raised up about 3" on the backside before, not sure why but it worked fine when flat.
Hope these help you also.
Apr 11, 2009 | Optoma HD72 Multimedia Projector
I have taken apart my optoma hd72 to replace the lamp driver board. I have loosened the screws on the main board to remove it so I can get to the lamp driver board underneath but its seems to still be...
The board under the mainboard plugs into the top board like a cartridge. You have to disconnect all the cables from the mainboard then pull up on board to detact it from bottom board then you should see lamp driver in the back. Make sure hands are clean from static. Good luck.
Dec 15, 2008 | Optoma HD72 Multimedia Projector
HD72 - LAMP GOES OUT IN 30 SECONDS
The projector is sensing the amp draw from the bulb and shutting down due to out of spec draw...replace the bulb.
Oct 21, 2008 | Optoma HD72 Multimedia Projector
Microtek cx6
I've had the same problem with my projector three times (usually whenever there's a sports championship). You just need to call optoma, get an RMA number, and ship it to them. Theoretically they'll fix it under warranty and send it back free.
May 02, 2008 | Optoma HD72 Multimedia Projector
Optoma hd72 bulb turning off
This is NOT a bulb problem unless your "lamp" LED is lit, which you say it is not. Many people have reported this problem with the Optoma 72. You can send it in for warranty service (it has a 2-year warranty) to get the lamp controller chip replaced, but the problem may recur. Optoma does not appear to have a permanent solution to this problem. My projector has broken exactly like yours TWICE in a year. I haven't even needed to replace the original bulb yet. :(
Nov 05, 2006 | Optoma HD72 Multimedia Projector
Optoma HD72 Multimedia Projector Logo
1,016 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
